Home » Archived » DSDP - Native Application Builder (NAB) » Mouse cursor hovering "under" WSCvbtn buttons?
Mouse cursor hovering "under" WSCvbtn buttons? [message #304] Tue, 08 January 2008 05:00 Go to next message
Originally posted by: lars.uffmann.dlr.de
Hey everyone!
After managing to configure NAB plugin, and creating a first
application, I found that most of the time (not always) after a first
program run, whenever I hover the hotspot of my mouse cursor over the
two buttons of my test application (both class WSCvbtn), the cursor
vanishes. It is displayed correctly on top of the button as long as the
hotspot (arrowtip) is hovering over the form background.
This happens both in the NAB/MWT Editor as well as in the running
application.
Does anyone have the same problem and/or know a fix for it?
Thanks & Best Regards!
Lars
Re: Mouse cursor hovering "under" WSCvbtn buttons? [message #312 is a reply to message #304] Wed, 09 January 2008 20:15 Go to previous messageGo to next message
Hi Lars,
It seems unknown problem.
But, if you set the WSNmouse property of the WSCvbtn then mouse cursor
behaves like that.
Please check it.
Shigeki
Lars Uffmann wrotes:
> Hey everyone!
> application.
> Lars
Re: Mouse cursor hovering "under" WSCvbtn buttons? [message #318 is a reply to message #312] Thu, 10 January 2008 05:20 Go to previous message
Hi Shigeki!
> behaves like that.
Thanks a lot! That solved the problem :) However, I couldn't find
WSNmouse as a property anywhere in the WSCvbtn -> WSCvlabel -> WSCnwbase
-> WSCbase hierarchy - not according to
http://www.widestudio.org/EE/ht-ref/objects.html at least. But I
eventually found it elsewhere and saw that it is equivalent to the
"Mouse No." Property in the NAB plugin properties window - setting that
from 1 (default) to 0 makes the mouse cursor hover "over" buttons.
Cheers! :)
Lars
Re: Mouse cursor hovering "under" WSCvbtn buttons? [message #569188 is a reply to message #304] Wed, 09 January 2008 20:15 Go to previous message
Hi Lars,
behaves like that.
Please check it.
Shigeki
> Hey everyone!
> application.
> Lars
Re: Mouse cursor hovering "under" WSCvbtn buttons? [message #569224 is a reply to message #312] Thu, 10 January 2008 05:20 Go to previous message
Hi Shigeki!
> behaves like that.
Cheers! :)
Lars
Previous Topic:Mouse cursor hovering "under" WSCvbtn buttons?
Next Topic:How to create a background process to listen for network traffic
Current Time: Fri Nov 21 12:07:22 EST 2025
Powered by FUDForum. Page generated in 0.03961 seconds
