Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] CSPEC Location
Re: [buckminster-dev] CSPEC Location [message #3139] Mon, 11 February 2008 17:27
Hi Evan,
The 'componentTypes' attribute tells Buckminster what the provider
should expect in the components that it finds. In your case, you have
specificed three possible types: "osgi.bundle,eclipse.feature,buckminster"
The 'osgi.bundle' component type assumes that meta-data can be found in
files like META-INF/MANIFEST.MF, plugin.xml, or fragment.xml. The
eclipse.feature will look for the 'eclipse.xml' file. The 'buckminster'
type looks for the 'buckminster.cspec.
If none of these files are present in the component, a provider with
your setting for the 'componentTypes' attribute will fail.
If you don't have any meta-data at all and if you are happy using the
project name as the component name, then you can use
componentTypes="unknown"
How are your components structured? Do they have any meta-data that
describes things like name, version, and dependencies? If it does, and
if Buckminster has no component type that recognizes it, such a type is
fairly easy to add.
Thomas Hallgren
brodericke wrote:
> Hi All,
> I just started playing around with buckminster today and I was wondering if
> someone could answer a couple questions for me.
> I've been trying to create a cquery and rmap for a project which lives in
> our cvs repository. Here's my provider configuration:
> <provider
> readerType="cvs"
> componentTypes="osgi.bundle,eclipse.feature,buckminster"
> source="true" mutable="false">
> <uri format=":pserver:brodericke:*****@********:/opt/cvsroot,{0} ">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> It seems to me like I'm only able to materialize my cquery when there is a
> cspec file in the root of my project in cvs. When I take out the cspec file,
> I see errors like:
> ERROR [0001] : No suitable provider for component
> buckminster_project:buckminster was found in searchPath default
> ERROR [0001] : Provider
> cvs(:pserver:brodericke:*****@********:/opt/cvsroot,buckmins ter_project): No
> match found for component buckminster_project
> Is this observation correct or am I just missing something? Do I need to
> have a cspec file checked in under the root of my project in cvs? If that's
> true, is there any way to point buckminster to a cspec file that's located
> somewhere else?
> Evan
Previous Topic:[buckminster-dev] CSPEC Location
Next Topic:[buckminster-dev] Project meta data is out of date for tools.buckminster
Current Time: Tue Nov 04 05:50:47 EST 2025
Powered by FUDForum. Page generated in 0.03495 seconds
