Home » Archived » EPF » EPF Composer and ClearCase
EPF Composer and ClearCase [message #3125] Fri, 17 February 2006 03:11 Go to next message
Originally posted by: I.Sergeev.gmail.com
Is any way to intagrate this tools?
Re: EPF Composer and ClearCase [message #3195 is a reply to message #3125] Fri, 17 February 2006 12:25 Go to previous message
Currently, there is no direct integration between those tools. That may be a
great enhancement for the future.
However, you could make use of:
- ClearCase (as IBM did while creating the initial code and content donated)
- CVS (as it is the version control system being used now, since it is
provided as infrastructure by Eclipse organization) or
- your preferred version control tool.
In any case, simply stating, the procedure is: check-out files externally
(from your version control tool), work on them on EPF Composer, and check
them back in. There are some rules of thumb to follow though. We should post
something on that soon.
Ricardo Balduino
IBM | EPF Committer
"I.Sergeev" <I.Sergeev@gmail.com> wrote in message
news:6a5417ecad980992b9322e66d39c0b13$1@www.eclipse.org...
Re: EPF Composer and ClearCase [message #561427 is a reply to message #3125] Fri, 17 February 2006 12:25 Go to previous message
Ricardo Balduino
IBM | EPF Committer
Previous Topic:BUP and/or EUP
Next Topic:RMC and EPF
Current Time: Tue Jul 22 09:05:23 EDT 2025
Powered by FUDForum. Page generated in 0.03512 seconds
