Home » Archived » DSDP - Real-Time Software Components (RTSC) » Memory fill using configuration file
Memory fill using configuration file [message #3109] Thu, 07 May 2009 13:23 Go to next message
Hello.
I have a separate linker command file with this directive:
.data:DSPLINK_shmBaseAddress: fill=0xC3F05000 {} > SDRAM
Ideally I could subsume this into my .cfg file but I don't know if this is
possible. Last I checked (Oct 2008) it wasn't possible but on the list of
future features.
Intuitively this might be done via Program.sectMap but "fill" isn't an
option per:
http://rtsc.eclipse.org/cdoc-tip/xdc/cfg/Program.html
Martin
Re: Memory fill using configuration file [message #3181 is a reply to message #3109] Wed, 13 May 2009 12:54 Go to previous messageGo to next message
Martin,
the functionality you are looking for is not there yet. We do have plans
to extend Program.sectMap[], but that did not make it to 3.15. Some of the
features supported in linker command files could be hard to support
through Program.sectMap, but 'fill' is not that difficult to add. I'll add
it to the list for the next patch or a release.
Re: Memory fill using configuration file [message #3215 is a reply to message #3109] Wed, 13 May 2009 13:27 Go to previous message
Martin Ambrose wrote:
> Hello.
> is possible. Last I checked (Oct 2008) it wasn't possible but on the
> list of future features.
The TI linker will accept multiple linker command files in the command
line. You can add your custom linker command file via lopts attribute
if you are using xdc to build or via the CCS4 linker options.
rm -f package/cfg/Hello.x64P.map
lnk6x -w -q -u _c_int00 foo.cmd -q -o Hello.x64P \
package/cfg/Hello_x64P.o64P package/cfg/Hello_x64P.xdl -c \
-m package/cfg//Hello.x64P.map \
-l rts64plus.lib
$cat foo.cmd
foo=3;
$grep foo package/cfg//Hello.x64P.map
00000003 foo
00000003 foo
If you need to modify the generated linker command file, the best way is
to simply supply a different template for its generation. This can also
be done relatively easily. See the linkTemplate attribute of
Executables:
http://rtsc.eclipse.org/cdoc-tip/index.html#xdc/bld/Executab le.html#.Attrs
Note there is also an --linkTemplate command option for configuro that
does the same thing.
You can copy the existing template from the ti.targets package
(linkcmd.xdt) and make the necessary changes.
> option per:
This would be a good addition to Program.SectionSpec. It's quite useful
for initializing stacks as well.
> Martin
Previous Topic:Creating a buffer in .cfg
Next Topic:To Rebuild the Package ... or not
Current Time: Sat Nov 08 13:23:22 EST 2025
Powered by FUDForum. Page generated in 0.05516 seconds
