Home » Eclipse Projects » Plugin Development Environment (PDE) » Re: 3.5M3 crashes Invalid memory access of location
Re: 3.5M3 crashes Invalid memory access of location [message #34763] Thu, 27 November 2008 01:14 Go to next message
Originally posted by: ekkehard.gentz-software.de
I made some more tests
seems that the IDE and the workspace - projects itself are are all well
so 3.5M3 at IDE - level works
....think there's something wrong in my target platform,
which I also tried to build new from 3.5M3
now a question:
is there a way to startup a workspace without using last Target Platform
? something like -cleantargetplatform
ekke
ekke schrieb:
> dont know if this is the right newsgroup
> I'm just trying to make my projects run under 3.5M3
> MacOSX 10.5.5, JDK 1.5, carbon
> just thaught I was ready, but after restarting my workspace
> (was a fresh workspace and all projects new copied into the workspace)
> eclipse crashes
> I can open a new workspace, but switching to the problematic workspace
> it crashes again
> its a workspace with a target platform and many project
> if no one has an idea I'll try tomorrow again to build the workspace
> perhaps someone has an idea ?
> THX
> ekke
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367]
> org.eclipse.core.runtime.AssertionFailedException: assertion failed:
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367] at
> org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
> org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
> org.eclipse.jface.text.source.AnnotationModel.getRegionAnnot ationIterator(AnnotationModel.java:741)
> org.eclipse.jface.text.source.AnnotationModel.getAnnotationI terator(AnnotationModel.java:699)
> org.eclipse.jface.text.source.AnnotationRulerColumn.doPaint1 (AnnotationRulerColumn.java:699)
> org.eclipse.jface.text.source.AnnotationRulerColumn.doubleBu fferPaint(AnnotationRulerColumn.java:513)
> org.eclipse.jface.text.source.AnnotationRulerColumn.access$3 (AnnotationRulerColumn.java:489)
> org.eclipse.jface.text.source.AnnotationRulerColumn$1.paintC ontrol(AnnotationRulerColumn.java:280)
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:217)
> org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1566)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1590)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1575)
> org.eclipse.swt.widgets.Control.drawWidget(Control.java:850)
> org.eclipse.swt.widgets.Canvas.drawWidget(Canvas.java:114)
> org.eclipse.swt.widgets.Widget.kEventControlDraw(Widget.java :1069)
> org.eclipse.swt.widgets.Canvas.kEventControlDraw(Canvas.java :191)
> org.eclipse.swt.widgets.Widget.controlProc(Widget.java:370)
> org.eclipse.swt.widgets.Display.controlProc(Display.java:862 )
> org.eclipse.swt.internal.carbon.OS.ShowWindow(Native Method)
> org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:17 92)
> org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1764)
> org.eclipse.swt.widgets.Shell.open(Shell.java:1298)
> org.eclipse.jface.window.Window.open(Window.java:797)
> org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:778)
> org.eclipse.ui.internal.Workbench$61.runWithException(Workbe nch.java:3394)
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3342)
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3071)
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
> org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:333)
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> java.lang.reflect.Method.invoke(Method.java:585)
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367] Invalid memory
> access of location 00000009 eip=910e9d14
Re: 3.5M3 crashes Invalid memory access of location [message #34831 is a reply to message #34763] Thu, 27 November 2008 09:10 Go to previous messageGo to next message
> now a question:
If you launch with -Dpde.nocache=true that should cause PDE to rebuild
its state of the world.
I highly doubt that this has to do with your target platform though.
~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #34866 is a reply to message #34831] Thu, 27 November 2008 09:46 Go to previous messageGo to next message
>> now a question:
>> Platform ? something like -cleantargetplatform
> Cheers,
> ~ Chris
thx for the pde.nocache ;-)
yes, its the target platform
rebuild the workspace - using the old 3.4 target platform all works well
also tried pde-export with build-cycles allowed - works great
....but still some work to rebuild my target platform
....more work with all the 3.5M3 downloads then using RCP-packages ;-)
will try it again later
ekke
Re: 3.5M3 crashes Invalid memory access of location [message #34901 is a reply to message #34866] Thu, 27 November 2008 12:55 Go to previous messageGo to next message
Can you be more specific with the problem Ekke? I would like to know if
its PDE's fault somehow. It would be weird for PDE to cause an invalid
memory access. A full stack trace and dump would be appreciated in a bug
report.
Thanks!
~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #34925 is a reply to message #34901] Thu, 27 November 2008 14:15 Go to previous messageGo to next message
> report.
I'll try to figure it out and report
ekke
> Thanks!
> Cheers,
> ~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #34959 is a reply to message #34901] Thu, 27 November 2008 14:19 Go to previous message
> report.
> Thanks!
> Cheers,
> ~ Chris
Chris,
if a target platform is wrong - is there a way to start the workspace
again with the IDE as self-hosting target platform ?
something like ignoreTargetPlatform or useSelfHostingTargetPlatform
or have I to delete some thing from the configuration, so the IDE
forgots that there was a targetplatform applied ?
would be helpful while testing and searching the reason
thx again
ekke
Re: 3.5M3 crashes Invalid memory access of location [message #585988 is a reply to message #34763] Thu, 27 November 2008 09:10 Go to previous message
> now a question:
~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #586007 is a reply to message #34831] Thu, 27 November 2008 09:46 Go to previous message
>> now a question:
> Cheers,
> ~ Chris
ekke
Re: 3.5M3 crashes Invalid memory access of location [message #586019 is a reply to message #34866] Thu, 27 November 2008 12:55 Go to previous message
report.
Thanks!
~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #586032 is a reply to message #34901] Thu, 27 November 2008 14:15 Go to previous message
> report.
ekke
> Thanks!
> Cheers,
> ~ Chris
Re: 3.5M3 crashes Invalid memory access of location [message #586050 is a reply to message #34901] Thu, 27 November 2008 14:19 Go to previous message
> report.
> Thanks!
> Cheers,
> ~ Chris
Chris,
thx again
ekke
Previous Topic:Re: 3.5M3 crashes Invalid memory access of location
Next Topic:ClassNotFoundException with classes inside jre/lib/ext
Current Time: Tue Oct 28 18:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.10400 seconds
