| Does BIRT 2.2 support "named" parameters of data sets? [message #340942] | Fri, 25 January 2008 10:17  |  |
| Eclipse User  |  |  |  |  | I saw a few postings in the newsgroup about this with no direct answer. Is there a way in BIRT 2.2 to use named parameters in data sets? The APIs and
 the help pages imply it is doable, but when I tried to do it in my custom
 ODA driver, the parameters are only bound by "position" and not "name" in
 the query implementation. The only work around i could think of is to ask
 the user to use a naming convention in naming the params (that include the
 position) like "param1, param2...etc", which is ugly. If there is right way
 to do this properly? If not, is it scheduled to be done in an upcoming
 version of BIRT? I appreciate your help.
 Maged
| Re: Does BIRT 2.2 support "named" parameters of data sets? [message #346606 is a reply to message #340942] | Mon, 28 January 2008 21:05  |  |
| Eclipse User  |  |  |  |  | Maged,
 Support of "named" parameters defined by an ODA driver has been added since
 BIRT 2.2.1.
 See the comments in Bugzilla
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=122194#c7 on the specifics.
 Linda
 "Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
 news:fncuj9$9dh$1@build.eclipse.org...
 > Maged
| Re: Does BIRT 2.2 support "named" parameters of data sets? [message #346681 is a reply to message #340942] | Mon, 28 January 2008 21:05  |  |
 BIRT 2.2.1.
 Linda
 > Maged
| Re: Does BIRT 2.2 support "named" parameters of data sets? [message #350974 is a reply to message #340942] | Mon, 28 January 2008 21:05  |  |
 BIRT 2.2.1.
 Linda
 > Maged
| Re: Does BIRT 2.2 support "named" parameters of data sets? [message #351050 is a reply to message #340942] | Mon, 28 January 2008 21:05  |  |
 BIRT 2.2.1.
 Linda
 > Maged
FUDForum. Page generated in 0.05757 seconds
