Home » Eclipse Projects » DSDP - Target Management » Is TM/RSE right for us?
Is TM/RSE right for us? [message #2979] Fri, 12 January 2007 10:32 Go to next message
Greetings All!
I've been given the task of adapting Eclipse to the needs of our
developers and have identified that one of our requirements is to
simplify the process of configuring and launching a debug session on an
embedded target (or simulator). Since this is exactly the sort of thing
that TM/RSE is supposed to handle I thought I would give a shout on this
mailing list to see if anyone can offer any suggestions.
The basic problem is that setting up a debugging environment for us is
much more complicated than the default CDT (+ Zylin patches) launch
configuration allows. In particular it might involve starting several
different processes (each with specific options, sometimes on a remote
target) in the correct order and finally connecting a gdb process.
From scanning the available documentation I get the impression that TM
and RSE provide a basic framework which could be used to automate much
of this, but I'm still unclear on exactly how it could be achieved. For
example might it be possible to create a new debug configuration type
tailored to each of our debugging scenarios and leveraging the RSE
functionality? I'm keen to create as general a framework as possible for
starting auxiliary process and would love to contribute back any code I
produce (subject to the agreement of management / legal bods.).
Does anyone have the slightest idea what I am talking about? If so, can
you offer any comments or suggestions?
Robert Norton
DSL Unit, Broadcom UK
Re: Is TM/RSE right for us? [message #2995 is a reply to message #2979] Fri, 12 January 2007 11:37 Go to previous messageGo to next message
Originally posted by: torkildr.resheim.no
Hi Robert
Robert Norton wrote:
[snip]
This should not be a problem. You can subclass the CDT launch delegate and
do all of the starting before letting it continue with gdb.
TM provides the remote capabilities.
Yes, this is what you'd want to do.
Yes, I've implemented something very similar to what you want. I'm not at
liberty to reveal any details but I know it's possible using the
aforementioned methods.
> Cheers,
> Robert Norton
Med vennlig hilsen / Kind regards
Torkild Ulvøy Resheim
Re: Is TM/RSE right for us? [message #3012 is a reply to message #2995] Fri, 12 January 2007 12:27 Go to previous messageGo to next message
Torkild U. Resheim wrote:
> <snip>
OK. Thanks a lot for the reassurance it's good to know I'm not starting
off on a wild goose chase!
Robert
Advanced Remote Launching (was: Is TM/RSE right for us?) [message #3049 is a reply to message #2979] Mon, 15 January 2007 11:21 Go to previous message
Hi Robert,
it's great to hear that you want to extend the TM / RSE Launching
mechanism, and also think about contributing back your enhancements.
As Torkild has already pointed out, adding Shell Operations to a Launch
by adding them to the LaunchDelegate "hardcoded" should be fairly easy.
If you want to have your shell commands independent of the protocol
(ssh, telnet, dstore, or whatever contributed), you might want to
consider extending
org.eclipse.rse.subsystems.shell.core.model.SimpleCommandOpe ration .
For some sample code that deals with running commands on the remote
side, see org.eclipse.rse.examples.tutorial/ShowJarContents
as well as the MontaVista ssh processes contribution, which is currently
available from Bugzilla at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=159522
With respect to making such shell (or download) actions as part of a
Launch generic, we already have a concept for this. The idea is to have
an additional tab in the Launch, where you see a list of entries. Each
entry is of type ILaunchAction, where implementations of ILaunchAction
can be contributed through plugin.xml. Each ILaunchAction brings an
associated UI for configuring it.
Examples of ILaunchAction could be a RunShellCommandLaunchAction, or a
DownloadFileLaunchAction, each of which could use RSE services in turn.
The LaunchActionSequencer, which runs one action after the other can
even be generic (independent of RSE), just like the LaunchActionManager
which would be responsible for persisting the ILaunchAction data into
ILaunchConfiguration instances.
Unfortunately, this excellent idea isn't currently being implemented due
to lack of resources. If you like this idea, please get in touch with us
on the dsdp-tm-dev@eclipse.org mailing list for further exchange of
concrete design ideas. It would be great if you could work in this
direction and contribute some code. The online place for more details is
at http://wiki.eclipse.org/index.php/DSDP/TM/Launching
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Greetings All!
> Cheers,
> Robert Norton
Re: Is TM/RSE right for us? [message #565469 is a reply to message #2979] Fri, 12 January 2007 11:37 Go to previous message
Hi Robert
[snip]
> Cheers,
> Robert Norton
Re: Is TM/RSE right for us? [message #565491 is a reply to message #2995] Fri, 12 January 2007 12:27 Go to previous message
> <snip>
Robert
Advanced Remote Launching (was: Is TM/RSE right for us?) [message #565536 is a reply to message #2979] Mon, 15 January 2007 11:21 Go to previous message
Hi Robert,
consider extending
Martin Oberhuber
> Greetings All!
> Cheers,
> Robert Norton
Previous Topic:EclipseCon TM Tutorial: What do you want to hear?
Next Topic:Extending org.eclipse.rse.core.systemTypes
Current Time: Sun Nov 09 04:39:23 EST 2025
Powered by FUDForum. Page generated in 0.03793 seconds
