| Set a XML DataSource Programmatically [message #339999] | Tue, 29 January 2008 03:57 |  |
| Eclipse User  |  |  |  |  | Originally posted by: pari.gandhi.gmail.com
 Hello World,
 Here is what I am trying to do:-
 I have created a report called test.rptdesign. I have specified a XSD file
 as the datasource of my report and the report's dataset contains the
 elements in the XSD schema.
 right, now I am want to invoke this report programmatically. I have a Java
 Object that I have converted to XML (using JAXB) and I now want to set the
 XML as the datasource for this report at runtime.
 ie., While design time, I have specified a XSD schema as my datasource,
 but while run time I want the report to point to a XML file. Makes sense?
 How would I go about doing this?
String xmlString = "<application>.................</application>";
ReportDesignHandle reportDesignHandle =
(ReportDesignHandle)design.getDesignHandle();
    SlotHandle dataSets = reportDesignHandle.getDataSets();
 How can set the xmlString as my dataSource? Any ideas / pointers?
 Mikey
FUDForum. Page generated in 0.03614 seconds
