| JBoss Deployment [message #339146] | Fri, 25 January 2008 20:05  |  |
| Eclipse User  |  |  |  |  | I am looking for a document on what to do to deploy my own BIRT 2.2 test project report under currently working JBOSS project.
 I found a description of deployment but all it says copy birt.war into
 deploy directory. But I need to know what BIRT related files are needed
 and where, to deploy under currently existing war file.
 Alex
| Re: JBoss Deployment [message #344192 is a reply to message #339146] | Mon, 28 January 2008 09:37  |  |
| Eclipse User  |  |  |  |  | Originally posted by: pmills.systemcore.ca
 I don't know if there's an automatic way to make it happen, but what I did
 was to make a copy of BIRT's "ReportEngine" directory inside the config
 directory of my JBoss server (so that I wouldn't be redeploying them
 whenever I modified my application).  I then wrote a bit of code to look up
 that directory, using the JBoss ServerConfigImplMBean, and create the
 report engine with that path.  This is happening within a ReportManager
 stateless session bean that then handles report requests by calling into
 the engine API.
 Things would probably be a lot nicer if BIRT could exist as a service that
 was referenced through JNDI, but I'm not that ambitious just now.  :-)
| Re: JBoss Deployment [message #344250 is a reply to message #339146] | Sat, 26 January 2008 02:46  |  |
| Eclipse User  |  |  |  |  | I've copied a bunch of BIRT related files that seemed to be needed for JBOSS deployment.
 Now when I click a link to my BIRT report(on a page I created to call my
 test report) I see an empty screen in browser but there is no any errors
 from JBOSS output.
 Any suggestions?
 Alex
| Re: JBoss Deployment [message #344267 is a reply to message #339146] | Mon, 28 January 2008 09:37  |  |
 the engine API.
FUDForum. Page generated in 0.04083 seconds
