| Compatibility between 2.2.1 and 2.3 [message #337740] | Mon, 28 January 2008 12:34  |  |
| Eclipse User  |  |  |  |  | Hi, I'm using now birt 2.3 m4, but I have some reports with crosstabs at
 2.2.1, when I open this, Birt shows a message about compatibility
 problems on some components (crosstab). When I run the report, this
 throws exceptions about CubeQueryDefinition.
 In the other hand, I would like to use the web viewer servlet for
 display the reports with 2.3 runtime, but, what would happens with
 reports with crosstabs at 2.2.1 version?.
 Hans.
| Re: Compatibility between 2.2.1 and 2.3 [message #342320 is a reply to message #337740] | Mon, 28 January 2008 20:29  |  |
| Eclipse User  |  |  |  |  | Hi Hans
 Crosstab has some changes in 2.3.0, So please check is there any unused
 bindings in your crosstab? If has, please remove them. Also check the
 datetime type dimension(Year-Quarter-Month...Levels) in Cube and Crosstab.
 The type of the levels should be Integer. In 2.2.0, they are not Integer
 type. If you like, please attached your report, I'd like to help you to
 check the issue.
 Tianli
FUDForum. Page generated in 0.04569 seconds
