| Home » Archived » BIRT » Wrong results in crosstab
 Goto Forum:|
| Wrong results in crosstab [message #337434] | Mon, 28 January 2008 08:43  |  |
| Eclipse User  |  |  |  |  | Hi people,
 I have a crosstab that shows some summarized fields, (A, B, C), when I
 preview the results (at preview's tab), all goes fine, but viewing the
 results in xls or web viewer, it results in strange data. The C field
 shows strange numbers, very very big numbers. I have tried with a new
 report file, but happens the same problem.
 Any ideas?
 Hans.
| Re: Wrong results in crosstab [message #341937 is a reply to message #337434] | Mon, 28 January 2008 08:51   |  |
| Eclipse User  |  |  |  |  | I forgot to add that I have two crosstabs. The problem happens sometimes in first crosstab and other times it happens in the second crosstab
 Hans escribió:
 > Hi people,
 > I preview the results (at preview's tab), all goes fine, but viewing the
 > Any ideas?
 > Hans.
| Re: Wrong results in crosstab [message #341938 is a reply to message #337434] | Mon, 28 January 2008 09:00   |  |
| Eclipse User  |  |  |  |  | Originally posted by: tigeleo.yahoo.com
 Hans ?????:
 > Hi people,
 > Any ideas?
 > Hans.
 May be you display rowid or time in milliseconds
| Re: Wrong results in crosstab [message #347950 is a reply to message #341938] | Mon, 28 January 2008 09:19  |  |
| Eclipse User  |  |  |  |  | Nope, and after a many crazy things, I can fix the problem. The solution was to change all the report parameters to String. I've never had this
 problem with crosstabs, indeed, I've worked with a template with the
 same report parameters and same crosstabs, it's the first time that I
 see this strange behaviour. Could be a bug?
 Hans.
 tigeleo escribió:
 > Hans ?????:
 >> Hi people,
 >> when I preview the results (at preview's tab), all goes fine, but
 >> viewing the results in xls or web viewer, it results in strange data.
 >> The C field shows strange numbers, very very big numbers. I have tried
 >> with a new report file, but happens the same problem.
 >> Any ideas?
 >> Thanks,
 >> Hans.
| Re: Wrong results in crosstab [message #352548 is a reply to message #341938] | Mon, 28 January 2008 09:19  |  |
 Hans.
 tigeleo escribió:
 > Hans ?????:
 >> Hi people,
 >> Any ideas?
 >> Thanks,
 >> Hans.
 Current Time: Fri Oct 31 00:02:16 EDT 2025
 Powered by FUDForum . Page generated in 0.03405 seconds |
