Home » Eclipse Projects » Eclipse Platform » Common Navigator fails to refresh on addition/deletion
Common Navigator fails to refresh on addition/deletion [message #337098] Mon, 27 July 2009 19:28 Go to next message
Dear All,
I subclassed CommonNavigator in my plug-in. The navigator content is not
local resource, but resource on the server side. Therefore I created
domain model for them. The tree viewer can be populated properly.
But, the CommonViewer fails to refresh its tree view after
addition/deletion. I use the content provider as model listener. For
add/delete/update events, I use source code like below. Any idea how to
enable the refresh function? Any input is appreciated.
new UIJob("refresh"){
public IStatus runInUIThread(IProgressMonitor monitor) {
// ...... test if viewer is disposed
viewer.refresh(element);
return Status.OK_STATUS;
}.schedule();
By the way, I also tried other way: find my CommonNavigator instance, and
then use CommonViewer to refresh the tree. It doesn't work either.
Best Regards,
Frank Du
Re: Common Navigator fails to refresh on addition/deletion [message #486791 is a reply to message #337098] Sat, 19 September 2009 00:52 Go to previous message
Frank Du wrote on Mon, 27 July 2009 19:28
Dear All,
}.schedule();
Best Regards,
Frank Du
Have you stepped through the CommonViewer refresh call in the debugger? It should refresh things properly. Try to see what's going wrong if you can.
Previous Topic:How to override in Common Navigation Framework
Next Topic:usage of dropAssistant for org.eclipse.ui.navigator.navigatorContent
Current Time: Tue Nov 11 04:34:18 EST 2025
Powered by FUDForum. Page generated in 0.14134 seconds
