Workbench layed out incompletely after restoring a view [message #337059] |
Sat, 25 July 2009 05:30  |
Whenever I restore a minimized view, the workbench doesn't seem to
complete to relayout its contents. It seems like the view gets its
position, but the other components don't adapt to the new layout of the
workbench. As part of another post I already hosted this screenshot,
that shows the situation:
http://img9.imageshack.us/img9/5183/screendqe.png
If you look at the console view in the bottom, it's just painted over
the editor, hiding for example the editors lower corners and its lower
scroll bar button.
I can fix the layout by dragging the afffected view around a bit.
The described behaviour occurs whenever I restore *any* minimized view.
Also happens in RCP apps.
Some feeling tells me that this is OS specific. I am with Eclipse 3.5 on
XUbuntu ( uses libgtk 2.16.1-0ubuntu2 )
Should I report a bug?
Felix
Re: Workbench layed out incompletely after restoring a view [message #337062 is a reply to message #337059] |
Sat, 25 July 2009 08:31   |
Felix Dorner wrote:
> scroll bar button.
> Felix
Minimized views behave similar to fast views. In the lower right hand
corner, you have icons for all views in the tab folder that was
minimized. If you select an individual view icon, only that view is
displayed. When displayed, it is displayed on top of the rest of the
workbench window. At the left end of the icons is the restore button.
This button returns the tab folder to its pre-minimized state and
incorporates it into the workbench window.
FUDForum. Page generated in 0.09150 seconds
