| Ctrl doesn't work defining an keyschema [message #337055] |
Fri, 24 July 2009 18:59  |
Two examples from my plugin.xml.....
the first one works fine, the second with the M1(Ctrl) doesn't work at
all.
I tried it also with Alt, this works fine, too.
What's wrong with my example - or is this an bug in eclipse???????
<key sequence="M3+K" commandId="org.eclipse.ui.newWizard"
schemeId="xxx.keys.idea.id">
<parameter id="newWizardId"
value="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/ >
</key>
<key commandId="org.eclipse.jdt.ui.navigate.open.type"
schemeId="vsa.keys.idea.id" sequence="M1+N"/>
Greetings
Markus
| Re: Ctrl doesn't work defining an keyschema [message #337077 is a reply to message #337065] |
Sun, 26 July 2009 17:23  |
Hi Lars,
thank you for your greatful help. It was not this Keybinding that caused
an conflict. It was Ctrl+X, Alt+X from Multiclipboard plugin :-((
I disabled this plugin and now my keybindings work.
Just one thing:
When I change my keybinding-scheme in properties dialog the whole
shortcuts from the new scheme, were I change to, disappear. I have to
click Restore defaults to see them again.
Is this a bug?
Greeting, Markus
FUDForum. Page generated in 0.03636 seconds
