Home » Eclipse Projects » Eclipse Platform » [DataBinding] DataBindingContext doesn't call dispose on used IObservables
[DataBinding] DataBindingContext doesn't call dispose on used IObservables [message #337048] Thu, 23 July 2009 21:36 Go to next message
Hi All,
I'd thought I'd ask first before filing a bug report.
I sometimes add ListChangeListener to the DataBindingContext#getBindings()
to track bindings being added and removed, so I can add generic behaviour
to them with out manually adding the listeners to each binding. However,
cleaning up is a hassel as I can't detect when the DataBindingContext gets
disposed. The DataBindingContext itself doesn't have a addDisposeListener
method and the underlying IObservableList that it uses are not disposed
when DataBindingContext#dispose is called. (dispose is called on each Bind
held in the IObservableList, but not on the IObservableList itself).
Would it be possible to modify DataBindingContext#dipose() so that it
called dispose on the IObservables it used?
bindings.dispose()
unmodifiableBindings.dispose() //(Calling dipose on a wrapping collection
doesn't call dispose on the wrappee)
validationStatusProviders.dispose()
unmodifiableStatusProviders.dispose()
validationStatusMap.dispose()
Is there another way to do it?
Ashley Cambrell
Re: [DataBinding] DataBindingContext doesn't call dispose on used IObservables [message #337073 is a reply to message #337048] Sun, 26 July 2009 11:52 Go to previous message
No because you can in theory share observables between databinding
contexts. In 3.5 a new class named ObservableTracker was added but
because we discovered a late bug it's not useable until 3.5.1.
Tom
Ashley Cambrell schrieb:
> Hi All,
> DataBindingContext#getBindings() to track bindings being added and
> removed, so I can add generic behaviour to them with out manually adding
> the listeners to each binding. However, cleaning up is a hassel as I
> can't detect when the DataBindingContext gets disposed. The
> DataBindingContext itself doesn't have a addDisposeListener method and
> the underlying IObservableList that it uses are not disposed when
> bindings.dispose()
> collection doesn't call dispose on the wrappee)
> Cheers,
> Ashley Cambrell
Previous Topic:Workbench layed out incompletely after restoring a view
Next Topic:Eclipse Modeling 64bit for Mac
Current Time: Wed Nov 05 15:33:24 EST 2025
Powered by FUDForum. Page generated in 0.03298 seconds
