Home » Eclipse Projects » Eclipse Platform » How to Add menu contribution when an specific editor is active - using org.eclipse.ui.menus
How to Add menu contribution when an specific editor is active - using org.eclipse.ui.menus [message #337029] Wed, 22 July 2009 05:46 Go to next message
Originally posted by: lennart.x.akobson.analogix.com
Hi all,
I need to add a sub menu into the existing File menu in the Main menu when
when at least one instance of my editor is open. I have
found that should be possible to do programmaticly using the
contributorClass in the org.eclipse.ui.edtors extension point schema.
But I have also found that org.eclipse.ui.menus can do sort of this, but
I',m not sure how to set this up.
The scenario is as follows: When an instance of a specic editor is active
there should be an additional sub menu available in
the File Menu meny. This sub menu should have a couple of menu entries.
Can anyone share how to do this?
BR
L
Re: How to Add menu contribution when an specific editor is active - using org.eclipse.ui.menus [message #452948 is a reply to message #337029] Sat, 01 August 2009 10:35 Go to previous message
You use a visibleWhen on your menu contribution commands from org.ecilpse.ui.menus.
<with variable="activeEditorId"><equals value="your.editor.id"/></with>
PW
Previous Topic:Select command handler based on where it's triggered from?
Next Topic:CVS history display branch names
Current Time: Sat Nov 22 06:36:07 EST 2025
Powered by FUDForum. Page generated in 0.02805 seconds
