Home » Eclipse Projects » Eclipse Platform » lightweight label decorator lazy instantiation problem
lightweight label decorator lazy instantiation problem [message #337010] Mon, 20 July 2009 20:09
I am trying to programmatically access my ILightweightLabelDecorator using
PlatformUI.getWorkbench().getDecoratorManager().getBaseLabel Provider(id)
This returns null sometimes, seemingly because the actual class is lazily
instantiated by the decoration process. Is there a way for me to make this
more deterministic?
I am trying to access the decorator to inform it an IObservableSet of
elements that it is decorating so it can fire LabelProviderChangeEvents
appropriately when the elements change. Is there a better way to do this?
Will
Previous Topic:re-target copy command wtih handler
Next Topic:Which setting files should/must/shouldn't be under version control?
Current Time: Thu Nov 06 03:40:38 EST 2025
Powered by FUDForum. Page generated in 0.03419 seconds
