Home » Eclipse Projects » Eclipse Platform » Galileo x86_64 OSX crash while printing
| Galileo x86_64 OSX crash while printing [message #336991] |
Mon, 20 July 2009 05:43  |
I'm running the x86_64 version of Galileo.
When I try to print a file in the XML Editor (CMD-P or File->Print), I
always get:
Process: eclipse [3075]
Path:
/Applications/eclipse_3.5_x64/Eclipse.app/Contents/MacOS/ecl ipse
Identifier: org.eclipse.eclipse
Version: 3.5 (3.5)
Code Type: X86-64 (Native)
Parent Process: launchd [101]
Interval Since Last Report: 1950244 sec
Crashes Since Last Report: 68
Per-App Interval Since Last Report: 1159630 sec
Per-App Crashes Since Last Report: 6
Date/Time: 2009-07-20 10:54:21.597 +0200
OS Version: Mac OS X 10.5.7 (9J61)
Report Version: 6
Anonymous UUID: 9CC68933-D57E-4884-BCA9-704DA0CC1AD4
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000c08
Crashed Thread: 0
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0x00007fff83d67ee3
Java VM: Java HotSpot(TM) 64-Bit Server VM (11.3-b02-83 mixed mode
macosx-amd64)
Current thread (0x0000000112001000): JavaThread "main"
[_thread_in_native, id=1886709504,
stack(0x00007fff5f400000,0x00007fff5fc00000)]
Stack: [0x00007fff5f400000,0x00007fff5fc00000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.eclipse.swt.internal.cocoa.OS.objc_msgSend(JJJ)J
j
org.eclipse.swt.internal.cocoa.NSPrintPanel.runModalWithPrin tInfo(Lorg/eclipse/swt/internal/cocoa/NSPrintInfo;)J+19
j
org.eclipse.swt.printing.PrintDialog.open()Lorg/eclipse/swt/ printing/PrinterData;+377
j
org.eclipse.jface.text.TextViewer.print(Lorg/eclipse/swt/cus tom/StyledTextPrintOptions;)V+51
j
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor$11.run ()V+165
j
org.eclipse.jface.action.Action.runWithEvent(Lorg/eclipse/sw t/widgets/Event;)V+1
j
org.eclipse.ui.commands.ActionHandler.execute(Ljava/util/Map ;)Ljava/lang/Object;+64
j
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(Lorg/eclipse/core/commands/ExecutionEvent;)Ljava/lang/Obje ct;+79
j
org.eclipse.core.commands.Command.executeWithChecks(Lorg/ecl ipse/core/commands/ExecutionEvent;)Ljava/lang/Object;+115
j
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(Ljava/lang/Object;Ljava/lang/Object;)Ljava/lang/Object; +21
j
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(Lorg/eclipse/core/commands/ParameterizedCommand;Lorg/ecli pse/swt/widgets/Event;)Ljava/lang/Object;+6
j
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(Lorg/eclipse/core/commands/ParameterizedCommand;Lorg /eclipse/swt/widgets/Event;)Ljava/lang/Object;+6
j
org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(Lorg/eclipse/swt/widgets/Event;)V+79
j
org.eclipse.ui.menus.CommandContributionItem.access$10(Lorg/ eclipse/ui/menus/CommandContributionItem;Lorg/eclipse/swt/wi dgets/Event;)V+2
j
org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(L org/eclipse/swt/widgets/Event;)V+51
J
org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
j
org.eclipse.swt.widgets.Display.sendEvent(Lorg/eclipse/swt/w idgets/EventTable;Lorg/eclipse/swt/widgets/Event;)V+24
j
org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/wi dgets/Event;)V+9
j
org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;Z)V+73
j
org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;)V+4
j
org.eclipse.swt.widgets.Widget.notifyListeners(ILorg/eclipse /swt/widgets/Event;)V+19
j
org.eclipse.swt.widgets.Display.runDeferredEvents()Z+96
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+115
j
org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j
org.eclipse.ui.internal.Workbench.runUI()I+393
j
org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/i nternal/Workbench;)I+1
j
org.eclipse.ui.internal.Workbench$5.run()V+55
j
org.eclipse.core.databinding.observable.Realm.runWithDefault (Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/R unnable;)V+12
j
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+18
j
org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j
org.eclipse.ui.internal.ide.application.IDEApplication.start (Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Ob ject;+84
j
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/ lang/Object;)Ljava/lang/Object;+135
j
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+149
j
org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v
~StubRoutines::call_stub
j
sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j
sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j
sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j
java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+161
j
org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lan g/String;[Ljava/net/URL;)V+211
j
org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/Strin g;)V+114
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+ 4
v ~StubRoutines::call_stub
Java Threads: ( => current thread )
0x000000019207f000 JavaThread
"org.eclipse.jface.text.reconciler.MonoReconciler" daemon
[_thread_blocked, id=-1895202816,
stack(0x000000018ef98000,0x000000018f098000)]
0x0000000192068800 JavaThread "LongIdleFileChangedNotifier -
(1000ms)" [_thread_blocked, id=-1897570304,
stack(0x000000018ed56000,0x000000018ee56000)]
0x0000000192068000 JavaThread "IdleFileChangedNotifier - (200ms)"
[_thread_blocked, id=-1898631168,
stack(0x000000018ec53000,0x000000018ed53000)]
0x0000000112772800 JavaThread "[ThreadPool Manager] - Idle Thread"
daemon [_thread_blocked, id=-1899692032,
stack(0x000000018eb50000,0x000000018ec50000)]
0x00000001125ac000 JavaThread "CommandLineArgsServer"
[_thread_in_native, id=-1915777024,
stack(0x000000018dbf9000,0x000000018dcf9000)]
0x00000001125c8000 JavaThread "SVN Kit 1.2 Connector"
[_thread_blocked, id=-1893842944,
stack(0x000000018f0e4000,0x000000018f1e4000)]
0x0000000112478800 JavaThread "Worker-10" [_thread_blocked,
id=-1904275456, stack(0x000000018e6f1000,0x000000018e7f1000)]
0x0000000112478000 JavaThread "Worker-9" [_thread_blocked,
id=-1909710848, stack(0x000000018e1c2000,0x000000018e2c2000)]
0x0000000112477000 JavaThread "Worker-8" [_thread_blocked,
id=-1910771712, stack(0x000000018e0bf000,0x000000018e1bf000)]
0x0000000112476800 JavaThread "Worker-7" [_thread_blocked,
id=-1911832576, stack(0x000000018dfbc000,0x000000018e0bc000)]
0x0000000112279000 JavaThread "Worker-6" [_thread_blocked,
id=-1912893440, stack(0x000000018deb9000,0x000000018dfb9000)]
0x0000000112475800 JavaThread "Worker-5" [_thread_blocked,
id=-1917952000, stack(0x000000018d9e6000,0x000000018dae6000)]
0x0000000112267000 JavaThread "Worker-4" [_thread_blocked,
id=-1919012864, stack(0x000000018d8e3000,0x000000018d9e3000)]
0x00000001121c6000 JavaThread "Worker-3" [_thread_blocked,
id=-1973735424, stack(0x000000018a4b3000,0x000000018a5b3000)]
0x0000000112446800 JavaThread "ContinuationBayeux-0" daemon
[_thread_blocked, id=-1853841408,
stack(0x000000019170a000,0x000000019180a000)]
0x0000000112442800 JavaThread "Timer-0" daemon [_thread_blocked,
id=-1854902272, stack(0x0000000191607000,0x0000000191707000)]
0x0000000112442000 JavaThread "btpool0-1 - Acceptor0
SocketConnector@127.0.0.1:8500" [_thread_in_native, id=-1855963136,
stack(0x0000000191504000,0x0000000191604000)]
0x0000000112441000 JavaThread "btpool0-0 - Acceptor0
SocketConnector@127.0.0.1:8600" [_thread_in_native, id=-1857024000,
stack(0x0000000191401000,0x0000000191501000)]
0x0000000112408800 JavaThread "derby.rawStoreDaemon" daemon
[_thread_blocked, id=-1859874816,
stack(0x0000000191149000,0x0000000191249000)]
0x00000001123db800 JavaThread "derby.antiGC" daemon [_thread_blocked,
id=-1907904512, stack(0x000000018e37b000,0x000000018e47b000)]
0x0000000112315800 JavaThread "Java indexing" daemon
[_thread_blocked, id=-1864167424,
stack(0x0000000190d31000,0x0000000190e31000)]
0x00000001122c7800 JavaThread "Bundle File Closer" daemon
[_thread_blocked, id=-1905336320,
stack(0x000000018e5ee000,0x000000018e6ee000)]
0x0000000112235000 JavaThread "Worker-2" [_thread_blocked,
id=-1902579712, stack(0x000000018e88f000,0x000000018e98f000)]
0x00000001121ed800 JavaThread "Worker-1" [_thread_blocked,
id=-1913954304, stack(0x000000018ddb6000,0x000000018deb6000)]
0x00000001121b6000 JavaThread "Worker-0" [_thread_blocked,
id=-1981980672, stack(0x0000000189cd6000,0x0000000189dd6000)]
0x0000000112118800 JavaThread "[Timer] - Main Queue Handler" daemon
[_thread_blocked, id=-1984720896,
stack(0x0000000189a39000,0x0000000189b39000)]
0x00000001120d0800 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=-1999564800,
stack(0x0000000188c11000,0x0000000188d11000)]
0x000000011207b000 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=-1991761920,
stack(0x0000000189382000,0x0000000189482000)]
0x00000001120c6000 JavaThread "State Data Manager" daemon
[_thread_blocked, id=-1992859648,
stack(0x0000000189276000,0x0000000189376000)]
0x0000000112046800 JavaThread "Low Memory Detector" daemon
[_thread_blocked, id=-2044833792,
stack(0x00000001860e5000,0x00000001861e5000)]
0x0000000112044800 JavaThread "CompilerThread1" daemon
[_thread_blocked, id=-2045894656,
stack(0x0000000185fe2000,0x00000001860e2000)]
0x0000000112043800 JavaThread "CompilerThread0" daemon
[_thread_blocked, id=-2046955520,
stack(0x0000000185edf000,0x0000000185fdf000)]
0x0000000112042000 JavaThread "Signal Dispatcher" daemon
[_thread_blocked, id=-2048016384,
stack(0x0000000185ddc000,0x0000000185edc000)]
0x0000000112041800 JavaThread "Surrogate Locker Thread (CMS)" daemon
[_thread_blocked, id=-2049077248,
stack(0x0000000185cd9000,0x0000000185dd9000)]
0x000000011202a000 JavaThread "Finalizer" daemon [_thread_blocked,
id=-2050232320, stack(0x0000000185bbf000,0x0000000185cbf000)]
0x0000000112029000 JavaThread "Reference Handler" daemon
[_thread_blocked, id=-2051350528,
stack(0x0000000185aae000,0x0000000185bae000)]
=>0x0000000112001000 JavaThread "main" [_thread_in_native,
id=1886709504, stack(0x00007fff5f400000,0x00007fff5fc00000)]
Other Threads:
0x0000000112021800 VMThread [stack:
0x00000001859ab000,0x0000000185aab000] [id=-2052411392]
0x0000000112048000 WatcherThread [stack:
0x00000001861e8000,0x00000001862e8000] [id=-2043772928]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 37248K, used 25149K [0x0000000115810000,
0x00000001181a0000, 0x00000001181a0000)
eden space 31936K, 62% used [0x0000000115810000, 0x0000000116b6f430,
0x0000000117740000)
from space 5312K, 99% used [0x0000000117740000, 0x0000000117c6fff8,
0x0000000117c70000)
to space 5312K, 0% used [0x0000000117c70000, 0x0000000117c70000,
0x00000001181a0000)
concurrent mark-sweep generation total 743872K, used 146558K
[0x00000001181a0000, 0x0000000145810000, 0x0000000172c10000)
concurrent-mark-sweep perm gen total 103424K, used 103250K
[0x0000000172c10000, 0x0000000179110000, 0x0000000182c10000)
Virtual Machine Arguments:
JVM Args: -Xdock:icon=../Resources/Eclipse.icns -XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts -Xms768m -Xmx1492m
-Dorg.eclipse.swt.internal.carbon.smallFonts -XX:MaxPermSize=256m
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 4096M, Free = 438M
Thread 0 Crashed:
0 libSystem.B.dylib 0x00007fff83d67ee3
small_free_list_remove_ptr + 158
1 libSystem.B.dylib 0x00007fff83d64afc szone_free + 2552
2 ...ple.CoreServices.CarbonCore 0x00007fff8258a12b CSMemDisposePtr + 23
3 ...ple.CoreServices.CarbonCore 0x00007fff8258a0f9 CSMemDisposeHandle + 81
4 ...ple.CoreServices.CarbonCore 0x00007fff8258a09f DisposeHandle + 9
5 com.epson.printer.page.APF2003 0x000000018f352562 Mem_Free(void**) + 34
6 com.epson.printer.page.APF2003 0x000000018f302459
photo_create_deleteEnhance(E_PARAM*) + 425
7 com.epson.printer.page.APF2003 0x000000018f31821c
CUIGetTone(tagCUIApf*) + 572
8 com.epson.printer.page.APF2003 0x000000018f31720a UIProcApf + 650
9 com.epson.printer.page.pde 0x000000018f23f3a3 -[PDEPhotoEnhance
procAPFUI] + 135
10 com.epson.printer.page.pde 0x000000018f23fb1f -[PDEPhotoEnhance
apfInitProc] + 73
11 com.apple.AppKit 0x00007fff80c21291 -[NSIBObjectData
nibInstantiateWithOwner:topLevelObjects:] + 1490
12 com.apple.AppKit 0x00007fff80c17569 loadNib + 244
13 com.apple.AppKit 0x00007fff80c16f49
+[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:]
+ 836
14 com.apple.AppKit 0x00007fff80c16b24
+[NSBundle(NSNibLoading) loadNibNamed:owner:] + 355
15 com.epson.printer.page.pde 0x000000018f23ea4a -[PDEPhotoEnhance
initWithUIManager:parentPanel:] + 166
16 com.epson.printer.page.pde 0x000000018f23afc4
-[PDEAdvancedSetting awakeFromNib] + 432
17 com.apple.AppKit 0x00007fff80c21291 -[NSIBObjectData
18 com.apple.AppKit 0x00007fff80c17569 loadNib + 244
19 com.apple.AppKit 0x00007fff80c16f49
+ 836
20 com.apple.AppKit 0x00007fff80c16b24
21 com.epson.printer.page.pde 0x000000018f23adfe
-[PDEAdvancedSetting initWithUIManager:parentPanel:] + 166
22 com.epson.printer.page.pde 0x000000018f240323 -[PDEColorView
awakeFromNib] + 132
23 com.apple.AppKit 0x00007fff80c21291 -[NSIBObjectData
24 com.apple.AppKit 0x00007fff80c17569 loadNib + 244
25 com.apple.AppKit 0x00007fff80c16f49
+ 836
26 com.apple.AppKit 0x00007fff80c16b24
27 com.epson.printer.page.pde 0x000000018f24028a -[PDEColorView
initWithUIManager:parentPanel:] + 158
28 com.epson.printer.page.pde 0x000000018f2348cf -[PDETabView
awakeFromNib] + 583
29 com.apple.AppKit 0x00007fff80c21291 -[NSIBObjectData
30 com.apple.AppKit 0x00007fff80c17569 loadNib + 244
31 com.apple.AppKit 0x00007fff80c16f49
+ 836
32 com.apple.AppKit 0x00007fff80c16b24
33 com.epson.printer.page.pde 0x000000018f234673 -[PDETabView
34 com.epson.printer.page.pde 0x000000018f232482 -[EPSONPagePDE
initWithCallback:] + 767
35 com.epson.printer.page.pde 0x000000018f22fefe
-[EPSONPagePDEPlugIn PDEPanelsForType:withHostInfo:] + 151
36 ...int.framework.Print.Private 0x00000001897038fc 0x1896ff000 + 18684
37 ...int.framework.Print.Private 0x0000000189702dc4 0x1896ff000 + 15812
38 ...int.framework.Print.Private 0x0000000189701803 0x1896ff000 + 10243
39 ...int.framework.Print.Private 0x00000001897119f7 AskUserForFile + 31007
40 ...int.framework.Print.Private 0x0000000189711507 AskUserForFile + 29743
41 com.apple.AppKit 0x00007fff80cba391
-[NSWindowController _windowDidLoad] + 531
42 com.apple.AppKit 0x00007fff80c56160
-[NSWindowController window] + 111
43 com.apple.AppKit 0x00007fff8112edb9 -[NSPrintPanel
runModalWithPrintInfo:] + 604
44 libswt-pi-cocoa-3550.jnilib 0x00000001891c69fc
Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend__JJJ + 54
45 ??? 0x00000001128c4215 0 + 4606149141
46 ??? 0x00000001128041c9 0 + 4605362633
47 ??? 0x00000001128041c9 0 + 4605362633
48 ??? 0x0000000112804253 0 + 4605362771
49 ??? 0x00000001128045d4 0 + 4605363668
50 ??? 0x00000001128040fa 0 + 4605362426
51 ??? 0x00000001128045d4 0 + 4605363668
52 ??? 0x000000011280472d 0 + 4605364013
53 ??? 0x000000011280472d 0 + 4605364013
54 ??? 0x0000000112804253 0 + 4605362771
55 ??? 0x0000000112804253 0 + 4605362771
56 ??? 0x000000011280472d 0 + 4605364013
57 ??? 0x000000011280472d 0 + 4605364013
58 ??? 0x00000001128040fa 0 + 4605362426
59 ??? 0x00000001128040fa 0 + 4605362426
60 ??? 0x0000000112a427d0 0 + 4607715280
Thread 1:
0 libSystem.B.dylib 0x00007fff83d5ddf6 mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff83d65433 mach_msg + 59
2 libSystem.B.dylib 0x00007fff83dcb100 mach_msg_server + 436
3 libclient.dylib 0x00000001119cfcbb
JNI_CreateJavaVM_Impl + 39699
4 libclient.dylib 0x00000001119cfc87
JNI_CreateJavaVM_Impl + 39647
5 libclient.dylib 0x00000001119cec82
JNI_CreateJavaVM_Impl + 35546
6 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
7 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 2:
2 libclient.dylib 0x00000001119cf3c1
JNI_CreateJavaVM_Impl + 37401
3 libclient.dylib 0x00000001119cf294
JNI_CreateJavaVM_Impl + 37100
4 libclient.dylib 0x0000000111c9a964 JVM_RaiseSignal + 418534
5 libclient.dylib 0x00000001119cefb1
JNI_CreateJavaVM_Impl + 36361
6 libclient.dylib 0x00000001119ced22
JNI_CreateJavaVM_Impl + 35706
7 libclient.dylib 0x00000001119e298c jio_vsnprintf + 408
8 libclient.dylib 0x00000001119e2847 jio_vsnprintf + 83
9 libclient.dylib 0x00000001119cec82
10 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
11 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 3:
Thread 4:
2 libclient.dylib 0x00000001119cf428
JNI_CreateJavaVM_Impl + 37504
3 libclient.dylib 0x00000001119e7c67 jio_vsnprintf + 21619
4 libclient.dylib 0x0000000111c9a973 JVM_RaiseSignal + 418549
7 libclient.dylib 0x0000000111ad2ef4 JVM_Available + 222694
8 libclient.dylib 0x0000000111ad2e7f JVM_Available + 222577
9 libclient.dylib 0x00000001119e7ac4 jio_vsnprintf + 21200
10 libclient.dylib 0x00000001119cec82
11 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
12 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 5:
7 libclient.dylib 0x0000000111a43b63 JVM_Lseek + 141957
8 libclient.dylib 0x0000000111a438ad JVM_Lseek + 141263
Thread 6:
4 libclient.dylib 0x0000000111a5163d JVM_MonitorWait + 3241
5 libclient.dylib 0x0000000111a50c2c JVM_MonitorWait + 664
6 libclient.dylib 0x0000000111a50a2d JVM_MonitorWait + 153
7 ??? 0x000000011280f852 0 + 4605409362
8 ??? 0x000000011288e02c 0 + 4605927468
Thread 7:
8 ??? 0x000000011288cc40 0 + 4605922368
Thread 8:
6 libclient.dylib 0x00000001119ced62
JNI_CreateJavaVM_Impl + 35770
7 libclient.dylib 0x0000000111a5cb68
JVM_IsPrimitiveClass + 5572
8 libclient.dylib 0x0000000111bddbff JVM_ResolveClass + 319495
9 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
10 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
11 libclient.dylib 0x00000001119cec82
12 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
13 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 9:
0 libSystem.B.dylib 0x00007fff83d5de32 semaphore_wait_trap + 10
1 libclient.dylib 0x0000000111a5cec1
JVM_IsPrimitiveClass + 6429
2 libclient.dylib 0x0000000111c9f323 JVM_RaiseSignal + 437413
3 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
4 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
Thread 10:
7 libclient.dylib 0x0000000111a601cb
JVM_IsPrimitiveClass + 19495
8 libclient.dylib 0x0000000111a5db9e
JVM_IsPrimitiveClass + 9722
9 libclient.dylib 0x0000000111ccbf3d JVM_RaiseSignal + 620735
10 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
11 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
12 libclient.dylib 0x00000001119cec82
13 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
14 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 11:
Thread 12:
7 libclient.dylib 0x0000000111a60749
JVM_IsPrimitiveClass + 20901
8 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
9 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
Thread 13:
3 libclient.dylib 0x0000000111a61375
JVM_IsPrimitiveClass + 24017
4 libclient.dylib 0x0000000111a61072
JVM_IsPrimitiveClass + 23246
Thread 14:
3 libclient.dylib 0x0000000111a612b8
JVM_IsPrimitiveClass + 23828
4 libclient.dylib 0x0000000111b2c798 JVM_Sleep + 218
5 ??? 0x000000011280f852 0 + 4605409362
6 ??? 0x00000001128040fa 0 + 4605362426
7 ??? 0x00000001128045d4 0 + 4605363668
8 ??? 0x00000001128013eb 0 + 4605350891
9 libclient.dylib 0x0000000111a44a3e JVM_Lseek + 145760
10 libclient.dylib 0x0000000111a447f3 JVM_Lseek + 145173
11 libclient.dylib 0x0000000111a5053f JVM_InternString + 1167
12 libclient.dylib 0x0000000111a50446 JVM_InternString + 918
13 libclient.dylib 0x0000000111c2d0c2 jio_printf + 588
14 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
15 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
16 libclient.dylib 0x00000001119cec82
17 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
18 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 15:
10 ??? 0x0000000112804253 0 + 4605362771
11 ??? 0x00000001128013eb 0 + 4605350891
12 libclient.dylib 0x0000000111a44a3e JVM_Lseek + 145760
13 libclient.dylib 0x0000000111a447f3 JVM_Lseek + 145173
14 libclient.dylib 0x0000000111a5053f JVM_InternString + 1167
15 libclient.dylib 0x0000000111a50446 JVM_InternString + 918
16 libclient.dylib 0x0000000111c2d0c2 jio_printf + 588
17 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
18 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
19 libclient.dylib 0x00000001119cec82
20 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
21 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 16:
Thread 17:
4 libclient.dylib 0x0000000111a5164f JVM_MonitorWait + 3259
10 ??? 0x00000001128013eb 0 + 4605350891
11 libclient.dylib 0x0000000111a44a3e JVM_Lseek + 145760
12 libclient.dylib 0x0000000111a447f3 JVM_Lseek + 145173
13 libclient.dylib 0x0000000111a5053f JVM_InternString + 1167
14 libclient.dylib 0x0000000111a50446 JVM_InternString + 918
15 libclient.dylib 0x0000000111c2d0c2 jio_printf + 588
16 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
17 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
18 libclient.dylib 0x00000001119cec82
19 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
20 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
10 ??? 0x00000001128045d4 0 + 4605363668
Thread 23:
Thread 24:
9 ??? 0x0000000112804322 0 + 4605362978
Thread 25:
0 libSystem.B.dylib 0x00007fff83de214e accept + 10
1 libnet.jnilib 0x000000018692aacd
Java_java_net_PlainSocketImpl_socketAccept + 277
2 ??? 0x000000011280f852 0 + 4605409362
3 ??? 0x00000001128040fa 0 + 4605362426
4 ??? 0x00000001128040fa 0 + 4605362426
5 ??? 0x00000001128040fa 0 + 4605362426
6 ??? 0x0000000112804253 0 + 4605362771
7 ??? 0x00000001128040fa 0 + 4605362426
8 ??? 0x00000001128045d4 0 + 4605363668
9 ??? 0x00000001128013eb 0 + 4605350891
10 libclient.dylib 0x0000000111a44a3e JVM_Lseek + 145760
11 libclient.dylib 0x0000000111a447f3 JVM_Lseek + 145173
12 libclient.dylib 0x0000000111a5053f JVM_InternString + 1167
13 libclient.dylib 0x0000000111a50446 JVM_InternString + 918
14 libclient.dylib 0x0000000111c2d0c2 jio_printf + 588
15 libclient.dylib 0x0000000111a5033e JVM_InternString + 654
16 libclient.dylib 0x0000000111a4ffd7 JVM_StartThread + 1107
17 libclient.dylib 0x00000001119cec82
18 libSystem.B.dylib 0x00007fff83d8be8b _pthread_start + 316
19 libSystem.B.dylib 0x00007fff83d8bd4d thread_start + 13
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
6 libclient.dyli
| Re: Galileo x86_64 OSX crash while printing [message #336998 is a reply to message #336991] |
Mon, 20 July 2009 09:33  |
It looks like a bug, so I've logged
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284002 .
In the meantime, if none of your plugins require a 1.6-level JRE then you
could try the 32-bit cocoa download to see how it does. If it also crashes
then the only other workaround is to use the carbon download instead while
waiting for this to be fixed.
Grant
"roos" <roos@symentis.com> wrote in message
news:h41e7v$vbv$1@build.eclipse.org...
> always get:
> Path:
> Version: 3.5 (3.5)
> Report Version: 6
> Crashed Thread: 0
> Java information:
> macosx-amd64)
> j
> j
Data;+377
> j
intOptions;)V+51
> j
> j
)V+1
> j
ect;+64
> j
ore/commands/ExecutionEvent;)Ljava/lang/Object;+79
> j
> j
Object;Ljava/lang/Object;)Ljava/lang/Object;+21
> j
core/commands/ParameterizedCommand;Lorg/eclipse/swt/widgets/ Event;)Ljava/lan
g/Object;+6
> j
ipse/core/commands/ParameterizedCommand;Lorg/eclipse/swt/wid gets/Event;)Ljav
a/lang/Object;+6
> j
> j
/CommandContributionItem;Lorg/eclipse/swt/widgets/Event;)V+2
> j
widgets/Event;)V+51
> J
)V
> j
> j
> j
+73
> j
4
> j
nt;)V+19
> j
> j
dow$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
> j
> j
h;)I+1
> j
> j
re/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
> j
gets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I +18
> j
play;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
> j
uinox/app/IApplicationContext;)Ljava/lang/Object;+84
> j
va/lang/Object;+135
> j
> j
> j
/lang/Object;+149
> j
> v
> j
/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
> j
> j
> j
lang/Object;+161
> j
net/URL;)V+211
> j
> Other Threads:
> Heap
> 0x0000000117740000)
> 0x0000000117c70000)
> 0x00000001181a0000)
> Thread 0 Crashed:
81
34
> procAPFUI] + 135
> apfInitProc] + 73
> + 836
> + 836
> awakeFromNib] + 132
> + 836
> awakeFromNib] + 583
> + 836
31007
29743
> Thread 1:
> Thread 2:
418534
> Thread 3:
418534
> Thread 4:
418549
222694
222577
> Thread 5:
418549
> Thread 6:
3241
> Thread 7:
3241
> Thread 8:
418534
319495
654
1107
> Thread 9:
10
437413
654
1107
> Thread 10:
418534
620735
654
1107
> Thread 11:
418534
620735
654
1107
> Thread 12:
418534
654
1107
> Thread 13:
> Thread 14:
1167
918
654
1107
> Thread 15:
3241
1167
918
654
1107
> Thread 16:
3241
1167
918
654
1107
> Thread 17:
3259
1167
918
654
1107
> Thread 18:
3259
1167
918
654
1107
> Thread 19:
3259
1167
918
654
1107
> Thread 20:
3259
1167
918
654
1107
> Thread 21:
3241
1167
918
654
1107
> Thread 22:
3241
1167
918
654
1107
> Thread 23:
3241
1167
918
654
1107
> Thread 24:
3259
1167
918
654
1107
> Thread 25:
1167
918
654
1107
> Thread 26:
1167
918
654
1107
> Thread 27:
3259
1167
918
654
1107
Current Time: Sun Nov 30 11:58:05 EST 2025
Powered by FUDForum. Page generated in 0.03682 seconds
