Home » Eclipse Projects » Eclipse Platform » Undo / Redo limit operation on each Editor/View
Undo / Redo limit operation on each Editor/View [message #336990] Mon, 20 July 2009 05:21 Go to next message
Hello everyone,
I'm developing an application using the Eclipse plug-ins system. One of
the client's desiderata is to have an undo/redo stack limited to the five
latest operations for each Editors and Views of the application.
To this end, I created an UndoContext in the createPartControl method of
my Editors and Views. Then I attach this context to the
UndoRedoActionGroup :
(with the required getViewSite(), getEditorSite() method according to the
Part concerned)
UndoRedoActionGroup undoRedoActions = new UndoRedoActionGroup(getSite(),
undoContext, true);
undoRedoActions.fillActionBars(getEditorSite().getActionBars ());
Once this is done, I set the limit of operation in the OperationHistory :
IOperationHistory operationHistory =
OperationHistoryFactory.getOperationHistory();
operationHistory.setLimit(undoContext, 5);
And then I create an OperationHistoryListener for each part and had it to
the operationHistory.
When an edition operation is done in an Editor, I associate its
undoContext to the operation. But, when I have 3 Editors opened and I
perform an edition operation, the first operation doesn't update the undo
label in the Edit menu... And when a second operation is performed on a
second Editor, the undo label is updated for all the Editors. In other
word I can "cancel" the edition operation on the second Editor from all
the opened Editors.
Any idea of something I'm doing wrong?
Marc
Re: Undo / Redo limit operation on each Editor/View [message #468177 is a reply to message #336990] Tue, 04 August 2009 09:08 Go to previous message
Marc wrote:
> Hello everyone,
> of the client's desiderata is to have an undo/redo stack limited to
> the five latest operations for each Editors and Views of the application.
> of my Editors and Views. Then I attach this context to the
> the Part concerned)
> UndoRedoActionGroup(getSite(), undoContext, true);
> to the operationHistory. When an edition operation is done in an
> Editor, I associate its undoContext to the operation. But, when I have
> 3 Editors opened and I perform an edition operation, the first
> operation doesn't update the undo label in the Edit menu... And when a
> second operation is performed on a second Editor, the undo label is
> updated for all the Editors. In other word I can "cancel" the edition
> operation on the second Editor from all the opened Editors.
Make sure that you really use different undo contexts.
Dani
> Marc
Previous Topic:Intercepting: "Close Editor + Don't Save"
Next Topic:Viewpart vs. Editorpart, proxy Editorpart, common Eclipse design question
Current Time: Thu Jul 17 19:39:00 EDT 2025
Powered by FUDForum. Page generated in 0.30189 seconds
