Home » Eclipse Projects » Eclipse Platform » Which setting files should/must/shouldn't be under version control?
Which setting files should/must/shouldn't be under version control? [message #336989] Mon, 20 July 2009 05:19 Go to next message
I've posted this question on e.t.m2e some weeks ago but there was no
response. So let me ask this here, maybe someone could tell me more
about this.
So here is the posting again:
---------------->8 schnipp 8<-----------------
Some weeks ago I migrate a lot of projects from Ant build to Maven build
using m2e. Since then we got a lot of problems with the hidden files, i.
e. all the setting files on the projects especially with version control
of them. Which ones should/must/shouldn't be under version control? As I
wrote on another posting some days ago, some of the files are modified
some of them not but nobody here know's exactly, how to handle this
correct. Before m2e usage every of these .* files was under version
control. But now?
If using a SCM system which uses write protect files, this turnes out
into a problem, either with a lot of errors on Eclipse if not checked
out for usage or with highjacked files on the SCM if modifying them the
hard way.
---------------->8 schnapp 8<-----------------
We use ClearCase as SCM which works with write protected files and some
of the setting files are modified just during opening a project. How
should this be handled?
Yves
Linux is like a wigwam: No Gates, no Windows and an Apache inside.
Re: Which setting files should/must/shouldn't be under version control? [message #337011 is a reply to message #336989] Mon, 20 July 2009 22:26 Go to previous message
This recent discussion should help clarify things a little bit.
http://dev.eclipse.org/newslists/news.eclipse.newcomer/msg29 354.html
(make sure to read all of the follow-up responses).
But the use of ClearCase (or any pessimistic locking scheme that
requires explicit locking or checking-out of files) complicates matters
a little bit. Generally, the .project, .classpath, and .settings files
will only be touched if someone changes things in the Project
properties. I have seen an occasional situation where the .classpath was
updated as a result of just looking at the properties (not changing
anything) but I'm pretty sure that was in the context of a project that
was migrated from one Eclipse version to another. In other words, that
should not be happening in general and not very often.
Perhaps if you can describe an exact scenario that you are having
trouble with the .project, .classpath, and .settings being under SCM
control, then we could help find a resolution to that specific scenario...
Hope this helps,
Eric
Yves Schumann wrote:
> Hi
> about this.
> control. But now?
> hard way.
> Yves
Previous Topic:lightweight label decorator lazy instantiation problem
Next Topic:How to register form section toolbar?
Current Time: Fri Nov 21 10:25:48 EST 2025
Powered by FUDForum. Page generated in 0.07734 seconds
