Home » Eclipse Projects » Eclipse Platform » Control the way a feature's version is considered an update or a new feature
Control the way a feature's version is considered an update or a new feature [message #336957] Wed, 15 July 2009 21:51 Go to next message
Sorry if this question was asked (and answered ) before, but I juste
can't come up with a reasonable search query. I've even had a hard time
looking for a title :)
I'm managing an eclipse RCP application (based on ganymede) and an
update site using the old (non p2) site.xml format.
Everything is working nicely, except for one minor problem : the update
dialog doesn't show features where the minor version number changes.
For example, if the version 1.0.0 of feature A is installed, a newer
version 1.0.x shows up in the update dialog, whereas 1.x.y doesn't. The
latter only shows up when you select the "install new features" option.
Is there any way to tune this behavior ?
Here is my plugin_customization.ini :
org.eclipse.update.ui/discoverySitesEnabled=true
org.eclipse.update.scheduler/enabled = true
org.eclipse.update.scheduler/schedule = on-startup
org.eclipse.update.scheduler/download = false
org.eclipse.update.core/org.eclipse.update.core.checkSignatu re = false
I guess there must be a property to configure.
Jawher
Re: Control the way a feature's version is considered an update or a new feature [message #336958 is a reply to message #336957] Thu, 16 July 2009 04:04 Go to previous messageGo to next message
This is a multipart message in MIME format.
--=_alternative 002C6308802575F5_=
Content-Type: text/plain; charset="US-ASCII"
org.eclipse.update.core.updateVersions
Select the features that the scan for updates will select prior to
display. Available values are compatible, equivalent, or major.
I think compatible is the one you want.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="Arial">org.eclipse.update.core.updateVersions </font>
<br><font size=2 face="Arial">Select the features that the scan for updates
will select prior to display. Available values are compatible, equivalent,
or major. </font>
<br>
<br><font size=2 face="sans-serif">I think compatible is the one you want.</font>
--=_alternative 002C6308802575F5_=--
Re: Control the way a feature's version is considered an update or a new feature [message #336962 is a reply to message #336957] Thu, 16 July 2009 09:46 Go to previous messageGo to next message
Jawher Moussa wrote:
There was a Preferences setting to control what kinds of updates were
permitted: Preferences > Install/Update > Valid Updates. It allows the
user to choose between service-level increments only or service and
minor increments. The default, IIRC, was service-level only ("equivalent").
Hope this helps,
Eric
> Cheers,
> Jawher
Re: Control the way a feature's version is considered an update or a new feature [message #336988 is a reply to message #336957] Mon, 20 July 2009 04:46 Go to previous message
Many thanks.
Cheers
Previous Topic:Migration to eclipse galileo ,Unable to see Installation details,error log
Next Topic:Drag and drop for Common Navigator Framework
Current Time: Sat Nov 08 10:14:07 EST 2025
Powered by FUDForum. Page generated in 0.03341 seconds
