| HowTo avoid minimal size of text in ControlContribution in Local Toolbar? [message #336941] |
Wed, 15 July 2009 04:16  |
I would like to have a resizable textfield in a toolbar.
public class SearchAndExecuteField extends ControlContribution {
protected SearchAndExecuteField(String id) {
super(id);
protected Control createControl(Composite parent) {
nsURIField = new Text(parent, SWT.SINGLE | SWT.BORDER);
nsURIField.setText("<search, execute>");
GridData gridData = new GridData(GridData.FILL_HORIZONTAL,
GridData.FILL_VERTICAL, true, true);
nsURIField.setLayoutData(gridData);
return nsURIField;
Positioned with:
private void fillLocalToolBar(IToolBarManager manager) {
manager.add(new SearchAndExecuteField("<search, execute>"));
Unfortunately the textfield has the minimal possible size ... ?
Any hints how to stretch the textfield?
Greetings,
Ralf
| Re: HowTo avoid minimal size of text in ControlContribution in Local Toolbar? [message #336961 is a reply to message #336941] |
Thu, 16 July 2009 09:34   |
the "problem" is that I don't create a new ToolBar / ToolBarManager but
try to use the existing one ->
IActionBars bars = getViewSite().getActionBars(); IToolBarManager
toolBarManager = bars.getToolBarManager();
Is is possible (re-)configure the ToolBar of toolBarManager?
Greetings,
Ralf
Ralf Buschermoehle wrote:
> Hello,
> super(id);
> @Override
> return nsURIField;
> Positioned with:
> Greetings,
> Ralf
| Re: HowTo avoid minimal size of text in ControlContribution in Local Toolbar? [message #646070 is a reply to message #336941] |
Tue, 21 December 2010 14:59  |
did you solved this?
Because I have the same issue...
Danny.
EDIT: I just found this way - but it's not dynamically filled:
super(id);
return nsURIField;
protected int computeWidth(Control control) {
return 200;
[Updated on: Wed, 22 December 2010 20:06] by Moderator
FUDForum. Page generated in 0.08217 seconds
