Home » Eclipse Projects » Eclipse Platform » defining menu in one plugin, but using it in another plugin.xml and adding a visibleWhen clause and
defining menu in one plugin, but using it in another plugin.xml and adding a visibleWhen clause and [message #336932] Tue, 14 July 2009 10:07 Go to next message
I want to define a menu (that has a specific ordering of command items)
in one plugin but use it and modify it another plugin. Here's the scenario:
a) PluginA: Define a menu that attaches to the main menu. Defines an
order of commands that I want to make standard.
b) PluginB: I want to turn off the placement of the menu in PluginA, use
the definition of it, but then add a visibleWhen clause to customize it.
How can I accomplish this? In other words, if no changes are made, the
definition in PluginA is used, otherwise, PluginB with the changes
indicated. Or should I use some type of plugin.xml "include" mechanism
if one exists.
Re: defining menu in one plugin, but using it in another plugin.xml and adding a visibleWhen clause [message #336952 is a reply to message #336932] Wed, 15 July 2009 14:47 Go to previous message
It doesn't work that way ... i.e. there's no way to include an XML
fragment from another place.
The closes you can do is define a menuContribution for a submenu that's
not included by default: menu:my.extra.command.menu
Then in your RCP app, if you place a menu with an ID of
my.extra.command.menu where you want it, it will be datafilled correctly.
PW
Paul Webster
Previous Topic:save all files before execute ant script eclipse galileo
Next Topic:Perspectives
Current Time: Wed Nov 05 19:47:56 EST 2025
Powered by FUDForum. Page generated in 0.25646 seconds
