Home » Eclipse Projects » Eclipse Platform » How To Programmatically Add Nature And Builders Into A Project
How To Programmatically Add Nature And Builders Into A Project [message #336931] Tue, 14 July 2009 09:56 Go to next message
Originally posted by: runzhou.li.gmail.com
I created a new project type with a corresponding wizard. What is left now
is to add the necessary builders and nature to the project when
performFinish() is called. Note that the project itself is pretty much a
Static Web Project clone, just with a simpler project directory format and
unique project type name and icon.
Need some help with this, thank you :)
Runzhou Li
Re: How To Programmatically Add Nature And Builders Into A Project [message #336940 is a reply to message #336931] Wed, 15 July 2009 02:57 Go to previous messageGo to next message
Originally posted by: aurelien.pupier.esial.net
Runzhou Li a écrit :
> Runzhou Li
Hi Runzhou,
for the nature, see extension point : org.eclipse.core.resources.natures
In the class that for teh nature, it will extend IProject Nature. You need to fill configure method to add specific information to your project.
Hope this will help.
Re: How To Programmatically Add Nature And Builders Into A Project [message #336948 is a reply to message #336931] Wed, 15 July 2009 09:12 Go to previous messageGo to next message
Runzhou Li wrote:
> What is left now
IProject.setDescription(). The description of the project has the
natures and builders of it.
- Prakash
http://blog.eclipse-tips.com
Re: How To Programmatically Add Nature And Builders Into A Project [message #336956 is a reply to message #336948] Wed, 15 July 2009 16:20 Go to previous message
Thanks guys, I ended up implementing this by adding a Static Web Project
facet to the project when performFinish(), and it works great :)
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:h3kkjj$i0a$3@build.eclipse.org...
> Runzhou Li wrote:
>> What is left now is to add the necessary builders and nature to the
>> project when performFinish() is called.
> IProject.setDescription(). The description of the project has the natures
> and builders of it.
> - Prakash
Previous Topic:How To Programmatically Refresh The Workspace After Creating A New Project
Next Topic:How to track modified files since last ant task run
Current Time: Thu Nov 20 13:32:24 EST 2025
Powered by FUDForum. Page generated in 0.04585 seconds
