Home » Eclipse Projects » Eclipse Platform » qualifier replacement in site.xml
qualifier replacement in site.xml [message #336827] Mon, 06 July 2009 05:01 Go to next message
I am currently building an update site with the PDE headless build, I
saw that there is no automatic way to replace the .qualifier in the
site.xml file.
I would like to replace it using an ant "replace" task but I can't find
wich property/variable is holding the qualifier value ?
<!-- replace the qualifier in site.xml -->
<replace file="${UpdateSiteStagingLocation}/site.xml" token="qualifier"
value="${version.qualifier}"/>
Thanks.
Laurent Marchal.
Re: qualifier replacement in site.xml [message #336828 is a reply to message #336827] Mon, 06 July 2009 05:42 Go to previous messageGo to next message
> site.xml file.
I'm using the properties from finalFeaturesVersions.properties generated
by the headless build to replace the version tokens in a site.xml
template file.
Something like that:
<copy file="${buildDirectory}/site.template"
tofile="${buildDirectory}/updates/site.xml" overwrite="true">
<filterset
filtersfile="${buildDirectory}/finalFeaturesVersions.properties "/>
</copy>
The entries in the site.template file are like this:
<feature url="features/org.apache.log4j_@org.apache.log4j>@.jar"
id="org.apache.log4j" version="@org.apache.log4j@">
Hope this helps.
Marco.
Re: qualifier replacement in site.xml [message #336831 is a reply to message #336828] Mon, 06 July 2009 09:20 Go to previous message
Yes thanks Marco it's a perfect solution !
Cheers.
Laurent.
>> build, I saw that there is no automatic way to replace the .qualifier
>> in the site.xml file.
>> find wich property/variable is holding the qualifier value ?
> template file.
> <filterset
> </copy>
> Hope this helps.
> Marco.
Previous Topic:Eclipse freezes after stopping at breakpoint in a static block
Next Topic:Tracking cursor / current line in StyledText
Current Time: Fri Nov 21 11:07:02 EST 2025
Powered by FUDForum. Page generated in 0.03391 seconds
