Home » Eclipse Projects » Eclipse Platform » Galileo problems?
Galileo problems? [message #336817] Sat, 04 July 2009 17:29 Go to next message
I have encountered some problems with Galileo:
1) Galileo does not save selected perspectives
in the toolbar when exiting and thus starting
eclipse only displays JavaEE. Note, I usually
have my perspectives toolbar docked on the left
side.
2) Somehow, I have lost on startup, the option
to select my workspace. Where can I reactivate
this default setting?
I could not locate a newsgroup that is specific to
the Galileo release, so I am not sure this is the
correct newsgroup to which to post this message.
Thanks!
Dan
Re: Galileo problems? [message #336820 is a reply to message #336817] Sun, 05 July 2009 13:08 Go to previous message
> in the toolbar when exiting and thus starting eclipse only displays
> JavaEE. Note, I usually have my perspectives toolbar docked on the
> left side.
Due to this step failing to prompt users for
workspace on startup, it continues on with the
last saved workspace regardless if the workspace
path is preference saved or completely removed of
which I erroneously reported (1) above as an error.
I had assumed I was working with the last saved
workspace on shutdown and this mechanism failed.
So - there is a problem specifically with the
Startup/Shutdown handler in regards to the
workspace switcher, or so it seems.
> Where can I reactivate this default setting?
Never mind this request, I found it in:
Windows->Preferences->General->Startup and Shutdown->Workspaces
New Additions:
Subversion under Galileo does not work cleanly
as it works fine under Ganamede.
1) Galileo Svn does not correctly show trunk trees
(it shows only subsets of projects).
2) Galileo Svn has severe problems in saving projects
as it results in a corrupted repository, directory,
or files and incorrectly displays results and errors.
3) Galileo Svn has problems with authentication whereas
this is not a problem under Ganamede.
> I could not locate a newsgroup that is specific to the Galileo release,
> so I am not sure this is the correct newsgroup to which to post this
> message.
> Thanks!
> Dan
Previous Topic:How do i get all files from a project
Next Topic:Contextual/dynamic help behavior change?
Current Time: Sat Aug 30 22:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.05633 seconds
