Home » Eclipse Projects » Eclipse Platform » How to programmatically remove all files during / after uninstall?
How to programmatically remove all files during / after uninstall? [message #336802] Fri, 03 July 2009 07:33 Go to next message
As ours is a proprietary s/w, we would like to remove all files associated
with our plug-in once user decides to uninstall our eclipse plug-in.
How can I clear all references made to our plug-in once customer decides
to uninstall it?
Like deleting the plug-in jar, removing plug-in's entry from bundles.list,
artifacts.xml, indexed_contributions and all other similar files?
In all we want to achieve a 'clean' uninstall which would leave no traces
of the plug-in behind after the uninstall is over.
How can I do that? Do I have to write an installer-uninstaller?
What api is available and is there an online tutorial/example?
Any help is really appreciated.
Thanks.
Re: How to programmatically remove all files during / after uninstall? [message #336813 is a reply to message #336802] Fri, 03 July 2009 14:30 Go to previous messageGo to next message
> associated with our plug-in once user decides to uninstall our eclipse
> plug-in.
> to uninstall it?
> bundles.list, artifacts.xml, indexed_contributions and all other similar
> files?
> traces of the plug-in behind after the uninstall is over.
I'm pretty sure there is no API to do that kind of thing. Plug-in
management is pretty much a black box; p2 owns that work and needs to in
order to correctly manage things based on prerequisites and dependencies.
I've read that p2 does have a "garbage collection" component that will
remove unused things when they are no longer referenced; perhaps you can
find some documentation on that.
Also, you might want to ask your questions about this on the
eclipse.technology.equinox newsgroup where p2 experts hang out.
Hope this helps,
Eric
Re: How to programmatically remove all files during / after uninstall? [message #336824 is a reply to message #336813] Mon, 06 July 2009 02:31 Go to previous message
Eric,
As advised I have posted my question in equinox newsgroup and here is its
link :
http://www.eclipse.org/newsportal/article.php?id=6476&gr oup=eclipse.technology.equinox#6476
Thanks.
Previous Topic:Contextual/dynamic help behavior change?
Next Topic:Eclipse freezes after stopping at breakpoint in a static block
Current Time: Mon Jul 21 21:30:52 EDT 2025
Powered by FUDForum. Page generated in 0.67290 seconds
