Home » Eclipse Projects » Eclipse Platform » Eclipse freezes after stopping at breakpoint in a static block
Eclipse freezes after stopping at breakpoint in a static block [message #336796] Fri, 03 July 2009 02:51 Go to next message
trying to debug code written in Java 5 I set a breakpoint within a static
block like
static {
x Java statements
The x indicates the breakpoint. Debugging the application it really stopped
at the breakpoint and for a short moment I could even see the stacktrace of
the thread. Afterwards - without any further interaction - the screen became
white and Eclipse hang. There was no chance to access Eclipse in order to
continue the debug run.
What may be the reason for this behaviour, which I only observed with the
breakpoint the static block, or how can the cause be determined?
How can it be avoided, that Eclipse suddenly hangs after stopping at the
breakpoint?
I work with Eclipse 3.4.2.
Thomas Wiedmann
Re: Eclipse freezes after stopping at breakpoint in a static block [message #336812 is a reply to message #336796] Fri, 03 July 2009 14:27 Go to previous messageGo to next message
Thomas Wiedmann wrote:
> Hello,
> static block like
> static {
> x Java statements
> stopped at the breakpoint and for a short moment I could even see the
> stacktrace of the thread. Afterwards - without any further interaction -
> the screen became white and Eclipse hang. There was no chance to access
> Eclipse in order to continue the debug run.
> the breakpoint the static block, or how can the cause be determined?
> breakpoint?
I tried to reproduce this in both 3.4.2 and 3.5 but it works just fine.
Can you provide more detailed steps to reproduce it?
Some information that would be useful:
What OS are you using? What JVM? Have you specified in eclipse.ini what
JVM it should use?
Eric
Re: Eclipse freezes after stopping at breakpoint in a static block [message #336825 is a reply to message #336812] Mon, 06 July 2009 02:40 Go to previous message
> JVM it should use?
When trying it again, I couldn't reproduce that problem case, too. Sorry.
I suppose, the problem, observed recently, must have another reason - I'll
observe, whether it would happen again.
Thomas Wiedmann
Previous Topic:How to programmatically remove all files during / after uninstall?
Next Topic:qualifier replacement in site.xml
Current Time: Fri Nov 07 06:57:27 EST 2025
Powered by FUDForum. Page generated in 0.03985 seconds
