Home » Eclipse Projects » Eclipse Platform » I found a bug, not sure what todo
I found a bug, not sure what todo [message #336740] Tue, 30 June 2009 04:10 Go to next message
Hi, I've found a very little bug, but I don't know what to do.
Since I'm new to plugin development, I'm not 100% sure that it is a bug or
I've done an error, and I don't want to mae an Eclipse developer waste his
time because I reported a fake error.
Everithing that is foolowing in this post is in my VERY HUMBLE opinion
The error is in the class
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor and affect the
method gotoMarker(IMarker);
(next to last row of method ):
if (end - 1 < length && start < length)
The error IMHO is that '-1'. I've found that the goto works if start==end
(this means that it is a simple move of the caret, while start!=end means
a goto+text selection
However, the -1 prevents the goto to go to the end of the file (I needed
in my plugin to open an editor at the end of a file so the user can start
appending text without any other keystroke)
Should I post a bug to bugzilla, or even put a patch? Is there any
official reference about eclipse contributing, may you provide link?
thanks
Alex
Re: I found a bug, not sure what todo [message #336741 is a reply to message #336740] Tue, 30 June 2009 04:41 Go to previous messageGo to next message
--------------020807090407030600010107
Alex,
It sounds like a bug to be able to move anywhere except past the last
character. Your description is simple enough that a bugzilla with this
information should be sufficient. Because the fix is also trivial, a
patch shouldn't make a significant difference. The getting involved
link on this page doesn't provide much help
http://www.eclipse.org/users/
Perhaps there's a better one, but it's not easy to find...
> bug or I've done an error, and I don't want to mae an Eclipse
> developer waste his time because I reported a fake error.
> start==end (this means that it is a simple move of the caret, while
> start!=end means a goto+text selection
> needed in my plugin to open an editor at the end of a file so the user
> can start appending text without any other keystroke)
> thanks
> Alex
<html>
<head>
http-equiv="Content-Type">
</head>
Alex,<br>
<br>
character.
Re: I found a bug, not sure what todo [message #336746 is a reply to message #336741] Tue, 30 June 2009 09:30 Go to previous message
Ok became a bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281978
Previous Topic:Eclipse startup peformance
Next Topic:Generation build.xml programatically
Current Time: Tue Nov 11 07:01:45 EST 2025
Powered by FUDForum. Page generated in 0.03967 seconds
