| Problem with Galileo [message #336615] |
Thu, 25 June 2009 05:34  |
I installed the new Galileo release and have a problem. Everytime I
start eclipse it starts with the workspace @user_home/workspace.
In Preferences the checkbox "Prompt for workspace on startup" is marked.
What can I do that the select workspace dialog appears on startup?
regards,
patrick
| Re: Problem with Galileo [message #336656 is a reply to message #336632] |
Fri, 26 June 2009 03:22  |
No, there is no osgi.instance.area in my config.ini
#This configuration file was written by:
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser
#Thu Jun 25 15:00:44 CEST 2009
org.eclipse.update.reconcile=false
eclipse.p2.profile=epp.package.rcp
osgi.framework=file\:plugins/org.eclipse.osgi_3.5.0.v2009052 0.jar
eclipse.buildId=I20090611-1540
osgi.bundles=reference\:file\: org.eclipse.equinox.simpleconfigurator_1.0.100.v20090520-190 5.jar @1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.e clipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.sdk.ide
osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
osgi.framework.extensions=reference\:file\:javax.transaction _1.1.1.v200906161300.jar,reference\:file\:org.eclipse.persis tence.jpa.equinox.weaving_1.1.2.v20090612-r4475.jar
osgi.bundles.defaultStartLevel=4
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.p2.data.area=@config.dir/../p2/
patrick
Andrew Niefer schrieb:
> Does your eclipse/configuration/config.ini specify a value for
> "osgi.instance.area"?
> That is another way of specifying the workspace location.
> -Andrew
> Patrick Gell wrote:
>> Hello,
>> my command line options are following:
>> -startup
>> plugins/org.eclipse.equinox.launcher_1.0.200.v20090520.jar
>> --launcher.library
>> plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.0.200 .v20090519
>> -product
>> org.eclipse.epp.package.rcp.product
>> --launcher.XXMaxPermSize
>> 256M
>> -showsplash
>> 256m
>> -showsplash
>> 256m
>> -showsplash
>> 256m
>> -vmargs
>> -Dosgi.requiredJavaVersion=1.5
>> -Xms40m
>> -Xmx512m
>> So there ist no -data option.
>> regards,
>> patrick
>> Daniel Megert schrieb:
>>> Patrick Gell wrote:
>>>> Hello,
>>>> marked. What can I do that the select workspace dialog appears on
>>>> startup?
>>> Make sure you don't start with the -data command line option.
>>> Dani
>>>> regards,
>>>> patrick
FUDForum. Page generated in 0.05076 seconds
