Home » Eclipse Projects » Eclipse Platform » Galileo - "dropins" folder not working?
Galileo - "dropins" folder not working? [message #336574] Wed, 24 June 2009 06:36 Go to next message
Originally posted by: phillipus.nowhere.net
Just got Eclipse 3.5. Put all my plug-ins in the "dropins" folder and
they don't show up. No way no how.
Am I missing something?
Re: Galileo - "dropins" folder not working? [message #336575 is a reply to message #336574] Wed, 24 June 2009 06:44 Go to previous messageGo to next message
Phillipus,
I'd try running with -clean -debug and looking carefully at what's in
the Error log. The -debug flag will produce more detailed messages
about why something might fail to activate, i.e., unsatisfied range
constraints on bundle dependencies...
Re: Galileo - "dropins" folder not working? [message #336580 is a reply to message #336575] Wed, 24 June 2009 10:46 Go to previous messageGo to next message
Ed Merks wrote:
> Phillipus,
Ed, I found out what it is. It's an issue with installing the Delta pack.
On Windows:
1. Install a clean Eclipse 3.5
2. Unzip the Delta pack over it.
3. Put some plug-ins in the dropins folder
Result - they don't show up in Eclipse.
Don't install the Delta pack and it's fine.
I'm sure we had this bug in an earlier version of Eclipse.
Phillipus
Re: Galileo - "dropins" folder not working? [message #336581 is a reply to message #336580] Wed, 24 June 2009 10:51 Go to previous messageGo to next message
Phillipus wrote:
> Ed Merks wrote:
>> Phillipus,
> On Windows:
> Phillipus
Bugbased - https://bugs.eclipse.org/bugs/show_bug.cgi?id=281353
Re: Galileo - "dropins" folder not working? [message #336583 is a reply to message #336581] Wed, 24 June 2009 11:06 Go to previous messageGo to next message
Phillipus wrote:
> Phillipus wrote:
>> Ed Merks wrote:
>>> Phillipus,
>>>> and they don't show up. No way no how.
>> On Windows:
>> Phillipus
In fact, things are worse than that - installing the Delta pack means
that no new plug-ins show up at all, even if they are in the normal
"plugins" folder!
Re: Galileo - "dropins" folder not working? [message #336584 is a reply to message #336583] Wed, 24 June 2009 11:15 Go to previous messageGo to next message
Phillipus wrote:
> Phillipus wrote:
>> Phillipus wrote:
>>> Ed Merks wrote:
>>>> Phillipus,
>>>> in the Error log. The -debug flag will produce more detailed
>>>> messages about why something might fail to activate, i.e.,
>>>> unsatisfied range constraints on bundle dependencies...
>>> pack.
>>> On Windows:
>>> Phillipus
> "plugins" folder!
Er, even worser....The Delta pack doesn't show up at all, I think it's
screwed. That kind of means no RCP development in 3.5. Ho hum.
Re: Galileo - "dropins" folder not working? [message #336585 is a reply to message #336584] Wed, 24 June 2009 11:19 Go to previous messageGo to next message
Why are you installing the delta pack into your eclipse installation?
You should create your own target and point PDE to it instead of using
the running Eclipse-Instance as the target.
Tom
Phillipus schrieb:
> Phillipus wrote:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Ed Merks wrote:
>>>>> Phillipus,
>>>> pack.
>>>> On Windows:
>>>> Phillipus
>> "plugins" folder!
Re: Galileo - "dropins" folder not working? [message #336586 is a reply to message #336585] Wed, 24 June 2009 11:30 Go to previous messageGo to next message
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Why? Because that's what I've always done. Target is the same as host.
That's what it's intended for. That's why it's a Delta pack.
Re: Galileo - "dropins" folder not working? [message #336588 is a reply to message #336585] Wed, 24 June 2009 11:39 Go to previous messageGo to next message
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Mind you, doing that fixes the problem. Perhaps in 3.5 the Delta pack is
not meant to be installed over the running installation.
Re: Galileo - "dropins" folder not working? [message #336593 is a reply to message #336588] Wed, 24 June 2009 13:17 Go to previous messageGo to next message
>>>> "plugins" folder!
This will likely have to do with problems generating metadata on the
org.eclipse.equinox.executable feature. See bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248578
The best way to install the delta pack is to extract it to its own
directory and then add it to your target platform by editing the Active
Target and adding the deltapack/eclipse directory.
Re: Galileo - "dropins" folder not working? [message #336595 is a reply to message #336593] Wed, 24 June 2009 13:27 Go to previous message
>>>>> "plugins" folder!
>> is not meant to be installed over the running installation.
Thanks for the info!
Previous Topic:Galileo for 64 bit Vista?
Next Topic:Delta pack not working in 3.5
Current Time: Tue Nov 18 16:05:31 EST 2025
Powered by FUDForum. Page generated in 0.27167 seconds
