Home » Eclipse Projects » Eclipse Platform » EditorPart.init() question
EditorPart.init() question [message #336569] Tue, 23 June 2009 18:37 Go to next message
My editor extends EditorPart and implements init(IEditorSite site,
IEditorInput input). In some cases init() detects that input is invalid,
and I have to show a message box and close the editor. What is the right
way to close the editor?
I guess I can call
getSite().getPage().closeEditor(this, false)
but I'm not sure init() should call that
Thanks.
Re: EditorPart.init() question [message #336570 is a reply to message #336569] Tue, 23 June 2009 20:01 Go to previous messageGo to next message
There isn't a way in the framework to gracefully close the editor
immediately after detecting an invalid input. The best you can do is
throw a PartInitException which will display a special error part.
Unfortunately it's not very user friendly and will show them the
stacktrace if they expand the details button.
Alternatively, you could implement your own error part that displays in
the editor when it detects an invalid input. You could provide a close
button for them to click which would use the close API you mentioned.
Certainly you could automatically open a dialog box to prompt them to
close it but I'm unsure of the usability implications of this.
HTH
Ben
> I guess I can call
> Thanks.
Re: EditorPart.init() question [message #336571 is a reply to message #336569] Wed, 24 June 2009 00:21 Go to previous message
> I guess I can call
I've done this on a past project, in editors that extend
org.eclipse.ui.forms.editor.FormEditor
In the init() method when I detected invalid input, I opened a JFace
MessageDialog offering the user the option of opening the file in a
plain text editor. If the user declined, I would just call
this.close(false) (inherited from
org.eclipse.ui.forms.editor.FormEditor). It worked fine for 3.3 and 3.4,
but has not been tested in Eclipse 3.5 yet.
Let me know if you can't find the code for FormEditor.close(boolean) and
I can post it. It is pretty simple, just calling the code you describe
above via Display.asyncExec().
Hope this helps,
Eric
Previous Topic:Getting wrong selection, sometimes
Next Topic:Exception when trying to update
Current Time: Mon Nov 17 09:24:09 EST 2025
Powered by FUDForum. Page generated in 0.03971 seconds
