| Open Diagram with Errors [message #336557] |
Tue, 23 June 2009 03:40  |
Hello
I have a presentation tomorrow where in
I show my validation ability that run on a diagram I created using EMF and
OCL audit rules in the gmfmap file.
When I run the validate button, its shows the errors/ warning as needed.
But, when I close the diagram (which has errors/ warning)
and try to re-open it - it get stack and so the whole application...
If I solve the errors before closing the diagram,
Its re-open with no problem.
I thought is might be something with the syncronization, but I refresh the
project each time there is some modification and it still doesn't help.
When there is a diagram file with an Error/ Warning icon - it does not
open.
Can you please advice??
Gilod
| Re: Open Diagram with Errors [message #336558 is a reply to message #336557] |
Tue, 23 June 2009 04:17  |
Gilod,
It's best to ask on the GMF newsgroup, so I've added it to the "to" list
of my reply.
I don't think anyone will be able to help unless you provide at least a
stack trace related to the problem. You should be able to find that in
the Error log view.
Gilod wrote:
> Hello
> I have a presentation tomorrow where in I show my validation ability
> that run on a diagram I created using EMF and OCL audit rules in the
> gmfmap file.
> But, when I close the diagram (which has errors/ warning) and try to
> the project each time there is some modification and it still doesn't
> help.
> open.
> Thanks
> Gilod
FUDForum. Page generated in 0.02935 seconds
