| Open Diagram with Errors [message #336557] | Tue, 23 June 2009 03:40  |  |
| Eclipse User  |  |  |  |  | Hello I have a presentation tomorrow where in
 I show my validation ability that run on a diagram I created using EMF and
 OCL audit rules in the gmfmap file.
 When I run the validate button, its shows the errors/ warning as needed.
 But, when I close the diagram (which has errors/ warning)
 and try to re-open it - it get stack and so the whole application...
 If I solve the errors before closing the diagram,
 Its re-open with no problem.
 I thought is might be something with the syncronization, but I refresh the
 project each time there is some modification and it still doesn't help.
 When there is a diagram file with an Error/ Warning icon - it does not
 open.
 Can you please advice??
 Gilod
| Re: Open Diagram with Errors [message #336558 is a reply to message #336557] | Tue, 23 June 2009 04:17  |  |
| Eclipse User  |  |  |  |  | Gilod,
 It's best to ask on the GMF newsgroup, so I've added it to the "to" list
 of my reply.
 I don't think anyone will be able to help unless you provide at least a
 stack trace related to the problem.  You should be able to find that in
 the Error log view.
 Gilod wrote:
 > Hello
 > I have a presentation tomorrow where in I show my validation ability
 > that run on a diagram I created using EMF and OCL audit rules in the
 > gmfmap file.
 > But, when I close the diagram (which has errors/ warning) and try to
 > the project each time there is some modification and it still doesn't
 > help.
 > open.
 > Thanks
 > Gilod
FUDForum. Page generated in 0.03036 seconds
