Home » Eclipse Projects » Eclipse Platform » UTF-8 Encoding
UTF-8 Encoding [message #336539] Mon, 22 June 2009 00:54 Go to next message
My eclipse based IDE involves reading XML's as metadata. These XML's could
contain special characters. However i ve noticed that eclipse's default
encoding is set to "Cp1252".
If i change my eclipse workspaces' encoding to UTF-8, and then export my
product, it seems to work fine. However I would rather code it in my
product so that i dont have to change the workspace settings. Is there a
way to set the default encoding to UTF-8 in the code?
Thanks in Advance,
Sheela
Re: UTF-8 Encoding [message #336540 is a reply to message #336539] Mon, 22 June 2009 02:16 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
Sheela wrote:
> could contain special characters. However i ve noticed that eclipse's
> default encoding is set to "Cp1252".
> Thanks in Advance,
> Sheela
You can put the following entry into your plugin_customization.ini:
org.eclipse.core.resources/encoding=UTF-8
Derek
Re: UTF-8 Encoding [message #336544 is a reply to message #336539] Mon, 22 June 2009 03:56 Go to previous messageGo to next message
Sheela wrote:
This is not the full truth. For XML files in the workspace Eclipse uses
the encoding inside the file and UTF-8 for newly created files. Of
course if you implement the reading code yourself then you need to make
sure the correct encoding is used no matter what the user or Platform
has set as default encoding.
Dani
> my product, it seems to work fine. However I would rather code it in
> my product so that i dont have to change the workspace settings. Is
> there a way to set the default encoding to UTF-8 in the code?
> Thanks in Advance,
> Sheela
Re: UTF-8 Encoding [message #336552 is a reply to message #336540] Mon, 22 June 2009 09:13 Go to previous message
Derek,
Thanks for the prompt reply.
Sheela
Previous Topic:Reloading OS environment
Next Topic:What's the difference between "Run Configurations" and "Debug Configurations"?
Current Time: Tue Dec 02 19:41:44 EST 2025
Powered by FUDForum. Page generated in 0.03950 seconds
