Home » Eclipse Projects » Eclipse Platform » Reloading OS environment
Reloading OS environment [message #336533] Sat, 20 June 2009 04:46 Go to next message
trying to run an Ant build script within Eclipse and to call signjar the
build failed, because the directory of jarsigner.exe (on Windows XP prof.)
was not set in the PATH environment. After setting the environment the build
was only successful after restarting Eclipse.
Is there a way to reload the OS environment for Eclipse (and its plugins
like Ant) instead of restarting Eclipse?
I use Eclipse 3.4.2.
Thomas Wiedmann
Re: Reloading OS environment [message #336550 is a reply to message #336533] Mon, 22 June 2009 08:42 Go to previous message
AFAIK this is not possible (it's not eclipse, it is the OS process that
has its environment variables). Changing a variable in the parent
process is not made visible to the running child processes automatically
PW
Paul Webster
Previous Topic:build an Enterprise Application Project
Next Topic:UTF-8 Encoding
Current Time: Sat Nov 08 06:21:54 EST 2025
Powered by FUDForum. Page generated in 0.04010 seconds
