Home » Eclipse Projects » Eclipse Platform » Full text searching
Full text searching [message #336525] Fri, 19 June 2009 02:49 Go to next message
Is there a feature or plugin that provides full text searching of a
project? I want to be able to find all files that contain a pattern but
not some other pattern. As a work-a-round, I've installed Google Desktop
and restricted it to indexing my project directory. It's works, but it's
not pretty as it doesn't have the working set functionality to set the
search scope and, obviously, no pattern result highlighting.
Re: Full text searching [message #336545 is a reply to message #336525] Mon, 22 June 2009 05:12 Go to previous messageGo to next message
Why doesn't the default search in Eclipse fit here?
- Prakash
http://blog.eclipse-tips.com
Re: Full text searching [message #336556 is a reply to message #336545] Mon, 22 June 2009 21:10 Go to previous message
Unless I'm misunderstanding it, the default search is a line based
search, not a file based search.
For example, if I wanted to find all files that contain a pattern and
not some other pattern. A line based search will give a false result
because it's looking for "lines" that match. If line 3 contains the
pattern and line 76 contains the other pattern, then a file based search
file will exclude the file from the result set.
Previous Topic:What's the difference between "Run Configurations" and "Debug Configurations"?
Next Topic:Open Diagram with Errors
Current Time: Fri Nov 14 00:26:30 EST 2025
Powered by FUDForum. Page generated in 0.03599 seconds
