Home » Eclipse Projects » Eclipse Platform » ViewPart and undo/redo
ViewPart and undo/redo [message #336521] Thu, 18 June 2009 15:49 Go to next message
I have a simple ViewPart that impls the following extends ViewPart
implements ISetSelectionTarget, ISaveablePart. I would like the part to
participate in the global undo/redo and I am having difficlutry trying to
figure how to accomplsih this. I am well versed in undo/redo when it comes
to using IEditorPart's but the ViewPart seems to be missing something. I am
also using the commandStack, editDomain from GEF. any examples or hints
would be greatly appreciated.
Re: ViewPart and undo/redo [message #336524 is a reply to message #336521] Fri, 19 June 2009 02:25 Go to previous message
You can take a look at my example EMF/Databinding-Project [1]. There I'm
plugin myself into the workbench undo/redo from a ViewPart [2,3,4]
(search for makeActions).
[1] http://tomsondev.bestsolution.at/2009/06/06/galileo-improved -emf-databinding-support/
[2] http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf/examples/org.eclipse.emf.examples.databinding.p roject.ui.rcp/src/org/eclipse/emf/example/databinding/projec t/ui/rcp/views/ProjectAdminViewPart.java?root=Modeling_Proje ct&view=markup
[3] http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf/examples/org.eclipse.emf.examples.databinding.p roject.ui.rcp/src/org/eclipse/emf/example/databinding/projec t/ui/rcp/views/UndoAction.java?root=Modeling_Project&vie w=markup
[4] http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf/examples/org.eclipse.emf.examples.databinding.p roject.ui.rcp/src/org/eclipse/emf/example/databinding/projec t/ui/rcp/views/RedoAction.java?root=Modeling_Project&vie w=markup
Previous Topic:Deleting a file with unsaved changes
Next Topic:Obtaining SWT Browser from
Current Time: Fri Jul 18 04:09:03 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
