Home » Eclipse Projects » Eclipse Platform » ProgressView not updating
ProgressView not updating [message #336505] Wed, 17 June 2009 22:22 Go to next message
Originally posted by: jcarroll.us.ibm.com
I am having a problem with the progress view within my RCP app when I
run a particular long-running job.
The progressview displays a progressbar the first time the job is run.
On subsequent job runs, the progressview only displays the name of the
job along with the red cancel button, but will not show a progress bar
unless I resize the frame which contains the progressview.
It does not matter if I make this frame bigger or smaller, it seems the
frame resize is forcing the progressview to display the progress bar.
Is this a known issue or is there a workaround ?
thanks,
John.
Re: ProgressView not updating [message #336506 is a reply to message #336505] Thu, 18 June 2009 00:35 Go to previous message
Sounds like a bug. Can you file one with a sample code to reproduce?
- Prakash
http://blog.eclipse-tips.com
Previous Topic:ignoring circular symlinks in the filesystem
Next Topic:Can we apply exclusion filters on a project to avoid refreshing certain folders?
Current Time: Fri Jul 18 03:28:32 EDT 2025
Powered by FUDForum. Page generated in 0.08892 seconds
