Home » Eclipse Projects » Eclipse Platform » Team API Commit event
Team API Commit event [message #336482] Wed, 17 June 2009 03:35 Go to next message
Hi everyone,
Hope this is the right place for such questions. if not, can you point me
the the right location?
I'm looking for a way to capture the commit event when checking in files
to any CM system. is it possible? will it be possible in the future? has
anyone done it before?
The scenario is:
The user commits the files
after a successful commit action, I get the list of checked-in files with
revision number and write it to another system.
I would like to use a high level API in order to make it CM vendor
independent.
So far all I found are answers like "it's not possible"...
how about AspectJ? can it help?
Thanks for your help!
Yaron.
Re: Team API Commit event [message #336494 is a reply to message #336482] Wed, 17 June 2009 09:42 Go to previous messageGo to next message
Yaron,
Whether or not there is a Team API available is really just a
convenience. The real questions is whether SCM system X has a callback
hook during a commit that would allow you to do what you want. The
answer for most system is yes but the hooks are server-side and not on
the client since this is the only way to guarantee that the hook gets
run for every commit. You may want to have a look at SCMBUG
(http://freshmeat.net/projects/scmbug/) as it provides a common
interface between SCM systems and bug reporting systems for doing
something similar to what you are asking for.
Michael
Yaron Burg wrote:
> Hi everyone,
> me the the right location?
> The scenario is:
> with revision number and write it to another system.
> independent.
> Yaron.
Re: Team API Commit event [message #336495 is a reply to message #336494] Wed, 17 June 2009 10:17 Go to previous messageGo to next message
Hi Michael,
Thanks for your answer.
SCMBUG sounds interesting and I'll take a close look into it.
However, I'm not sure it can do everything I want.
The plugin I'm working on is a task repository connector for Mylyn and I'm
trying to create the link between change set and defect, as part of this
project.
Yaron.
Michael Valenta wrote:
> Yaron,
> Michael
> Yaron Burg wrote:
>> Hi everyone,
>> The scenario is:
>> independent.
>> Yaron.
Re: Team API Commit event [message #336514 is a reply to message #336495] Thu, 18 June 2009 09:49 Go to previous message
In that case, I would suggest you search through bugzilla in the Eclipse
Team component. This question has been asked before so I'm sure there
are several bugs related to the topic. You can add yourself to the CC of
the bugs and state your requirements there.
Michael
Yaron Burg wrote:
> Hi Michael,
> I'm trying to create the link between change set and defect, as part of
> this project.
> Yaron.
>> Yaron,
>> Michael
>> Yaron Burg wrote:
>>> Hi everyone,
>>> point me the the right location?
>>> files to any CM system. is it possible? will it be possible in the
>>> future? has anyone done it before?
>>> The scenario is:
>>> independent.
>>> Yaron.
Previous Topic:Stop eclipse reopening custom editors
Next Topic:Debug UI: Entering debugger commands by hand?
Current Time: Fri Nov 07 15:29:48 EST 2025
Powered by FUDForum. Page generated in 0.03519 seconds
