Can't find 64-bit build of Galileo RC4 for OS X [message #336477] |
Tue, 16 June 2009 10:14  |
I'm trying to run Galileo for OS X using Java 1.6. My understanding is
that this only works for 64-bit builds (because the 1.6 JVM is only built
for 64 bit). I downloaded the "Cocoa" version of Galileo RC4, but it
doesn't seem to be 64 bit, based on this:
mwallace-70004% file eclipse
eclipse: Mach-O universal binary with 2 architectures
eclipse (for architecture i386): Mach-O executable i386
eclipse (for architecture ppc): Mach-O executable ppc
When I try to run eclipse using 1.6, I get the following:
mwallace-70004% ./eclipse
_NSJVMLoadLibrary: NSAddLibrary failed for
/System/Library/Frameworks/JavaVM.framework/Versions/1.6/Lib raries/libjvm.dylib
JavaVM FATAL: Failed to load the jvm library.
Any help would be greatly appreciated.
Re: Can't find 64-bit build of Galileo RC4 for OS X [message #336479 is a reply to message #336478] |
Tue, 16 June 2009 14:35  |
The packages that you find here [1] are only built for 32-bit cocoa, not
for 64 bit.
To get the 64bit cocoa build, you need the "Eclipse Classic" -> Other
downloads, which is the link that Tom gave.
Starting from that base Eclipse, you can install other things you may
want by doing Help -> Install New Software... and work with the Galileo
repository.
[1] http://www.eclipse.org/downloads/?tab=developer
-Andrew
Tom Schindl wrote:
> Not sure where you are looking but this page [1] explicitly shows the
> 64-bit version.
> [1] http://download.eclipse.org/eclipse/downloads/drops/S-3.5RC4 -200906051444/index.php
> Tom
>> built for 64 bit). I downloaded the "Cocoa" version of Galileo RC4, but
>> it doesn't seem to be 64 bit, based on this:
>> mwallace-70004% ./eclipse _NSJVMLoadLibrary: NSAddLibrary failed for
FUDForum. Page generated in 0.05061 seconds
