| Re: Heeelp! How to define a command group for "Customize Perspective..."->"Comman [message #336443 is a reply to message #336441] |
Thu, 11 June 2009 16:08   |
Originally posted by: eclipse-newsgroups.scharf.gr
--------------040606090602010707040501
Hi Paul,
this solution works only partly. Without an empty
actionSet, the gropp in the "Toolbar Visibility" has
no name (see the NoName.gif screenshot). With an
empty action set with the same ID as the toolbar,
this is fixed (ToolbarWithName.gif). However,
on the "Command Groups Availability" page, the
Commands in the toolbar are not shown (NoToolbarDetail.gif)....
Michael
> Paul Webster wrote:
> Those groups each represent one toolbar in the coolbar, but the labels
> in the CustomizePerspectiveDialog are kinda hacked in. Basically, they
> currently come from
> org.eclipse.ui.internal.WorkbenchWindow.getToolbarLabel(Stri ng). File
> and Navigate are hard code :-) and everything else is looked up from the
> actionSet registry. sigh, I can't believe this stuff.
> So for example, if you create a new toolbar using something like:
> <menuContribution locationURI="toolbar:org.eclipse.ui.main.toolbar">
> <toolbar id="com.example.myToolbar">
> <command commandId="org.eclipse.ui.help.aboutAction"/>
> </toolbar>
> </menuContribution>
> Then com.example.myToolbar will be sent to that method.
> But it implies a workaround would be to create an empty actionSet with
> an ID matching your toolbar and the appropriate label.
> PW
> Michael Scharf wrote:
>> I feel really stupid! I cannot figure out how to use
>> commands and create a new group so that it appears nicely
>> in the
>> "Customize Perspective..."->"Command Groups Availability"
>> page.
>> I came to the conclusion that I cannot use
>> commands if I want them to appear in the
>> "Command Groups Availability" page :-(
>> Google is also not very helpful (5 hits only!?!)
>> http://www.google.com/search?&q=%22Command+Groups+Availa bility%22
>> Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Content-Type: image/gif;
name="NoName.gif"
Content-Disposition: inline;
filename="NoName.gif"
R0lGODlh/wBRAfcAAAQCBCSiJHyCpMTCxDQ2fHSC5GxyvDRglOTi3Fym3Gxi jKSm3KyqnNTy
/BxShJTC5ExCVKyS1ExSnFCe1FxepHyy3NTC3LSOvN7i9HRyjKS23IyizPTy 7FxMfPwCBOSK
LBwKTJym/Pz69ISm5IyX/EdupEQ+RNTSxOzq3FRKjHSS1NTS5HSGzDRCjHR6 pKSyvB8mdHya
3LTS7KSetMSy/Py7PISq5HSC7HB83HRopGxiPMqz1LSmzPHz/FxNjEQ2ZKSm 9LzC3GRapNza
zFxijOXk7Niu1FBorGButLSuzHC9bMS5pI2y7Ozr9O/7/Ozu7MTa7HyevFhG hJx6tHyc5ISq
7KzK7LTGzHR+1FxWnGRetMzO9Ly+3PT29Ex2pH53tKSezOLFjHyK9IRyNFxS jLzK5HTDdJSa
nDQ+fEFpnOTm5Gis3HRujKyu1GRerMzO3KSOzPTm/G91nFxWhNyiVNTW1HyW 5CwudJSa1Jiq
3HiG9HRutM+mzE89dLHD5Pz9/NDMvNye/BQWZOyWLJSmtJSCvExCZHyatNCc xJyYzEQ6XHSK
1PzIPC9alNze3Jx+LJyy3FRinOTa7JyWxJx+zISm7OSWPGRarHyi5OTG3Myq 5HxqnGx6xMS6
3KyixHR+7FRarNSqzFQ+bLyi1FlSnMSOvIS65BcebFRKZOT6/Jym3HR+pHxq PHxanMS+rEw+
fOTO5OyeNIF6vNy21Jyi7CxWjMTG5MzSzEtOlNTW9LSq3Ky6vGRqjOzS5ExG jKy+5ER2rGxu
lIGGrDxinEROpLSSxNzm/Gx2lOzq5HyT3HR+5GxmrNzd1HS+dJSu5NTOxFRG bHeN3JR6NNze
9GRgpLS23FxMhERFjHR2rCwqdMSkzPz2/FxOlMSqzMS6rJyy7PTu7LTC1Pz2 9JR2NLzG5KSi
tNzUzKyevGBSlDs+hLSezLyu1JSa3IRutFROlFxGjFR2rHxulOnm3JzG5FRi pKySvOTm9Ki6
3ExypPTu3GyKzCQqdHye3LzW7Iyu5HeG7CH5BAAAAAAALAAAAAD/AFEBBwj/ AJMlGGGjij9/
NpgcZGLqW8NvDCFCdMZEAxMmFBs2jEjxIsWM3yharHhx5MWQGFOC/Kiy5UqS LmOynAlzpM2L
MnOybCjSo86fLHPerOlz6MieHJPyVIpy6UanE0limjq1oD+cWJlUYJJQq8Iq NvwZHBs2LFiE
YtOOFWu2LVqzauOunSvXLd25cO/adZu3rly/Z+/+Fby2L1m2iAPvTWyXsWPF jBfDTZaMCj9+
VKYStMG5c1VMNqiKHk26tOnTqFOrXs26tevXsGPLnk2asorKMRKATk2lt2/f mH8L7x08+PDj
lokrB748xnLkyaMbZx69Nybowosf146du/ffzqtT/+d3Hbt56N+lL0+PeTrm aJST8QtPHlP9
9lRw23Eeo39/Kv/5ByCAATqXjH8HCmggZvw1mJ+CDhbon4QPEkjghBZOmCCG DUJ4IYcdghjh
iB9m2KGFG4YooYosVuZifna4uF+M+cH4YjI0unhgjrfFZxl5mNl3HT92DMgf jpTlhyRlMcaH
YwxL1qijkkk6qWSMMeS45H5PImljk0peyeSNW2Ypo5dOasmllldCGeObXTa5 5phx6rgmlHZW
CSeSbG6J5plUHkgZlIQOKuiheCZapaFeqmKEEd0UIssXsrBw4IAzZmmglDXO 2KmZnL5II6cz
3phjqKfeKGWqobaKZqajqv8qI6g5siqrq6uCauqtvMKoK6q6plrrq68G++uZ lOmSCSzrJCLL
HnssQ80Ri0T45ZOZxunmrm9CKea3aNoorqy1alpqqTZiy+ufffbJK7rhxgtj mIDWOy6wtvpq
a7fl9nvmsHCyyc4svUjSCRhf7JEDBVlIQEFlv1WGgTETY3Cqp5Xt1xvE/AFY JMc1DjhxeLht
3NumLlKsMgakknyyxiZzGvKAIEMM88Qhv1jjpuZ++nF+FFf4acwQv4iylAYm zWWFl+7oHMxF
Ey01pkZWrTGO2hhhgS3VTBItNVm400I6SAyHMxV2GGNMb0Vm6THNVExsas50 m+r2rWj3NjLQ
LLf/jSuumrbaqtwy22yup0UWmffiiQeteMlGt41x3olTbnnlmF8euH48X+3x 0Tj+rCqAfCDC
QxuJfCFtFrj4kg4BuGT2W9DnDUe7b+HVrrtvZ1Nx+3CKQxf8yeb9jl3uuxtf O/K7757585cv
/pviw/sWihXkZO/HL9xrAMn3G8heXu+8rx23+RicPbH5aqutt9oVs792+2fD b/7sLL//fv3u
x61++/cDYPn6tz7fre1/vRHg7npnvwTmj3/9a54EJ9g8TISiFAlbHS5a0AIC 7AMGMBBNZtx3
nakYcIQscx/FMLFC32HgOipM4QtX2EIYzvCFLiyPDQXIwrWx8IZTieEP/1GY wxy2UIhGxCEN
X/jD61RCfFB0Is7K48AeorCEV5TdE7dIBS56sYtg/KIYw0jGMT7RiWS0Tma0 QQ7s+WF73fOe
PzZQBUxUgioTI00ef3jHPVZij2qbSh7zSLE/GgMTe0TkIRUZv6ncsYd6XNkh E+nHPRIyfhgw
5GgsuciV9VGSo1EZaQxIFfotspF2xOQjacPK19xxBJXgASKmwDAJXON1HzyF II5QELAUJI91
rKMmqwBMPhoTmBOzQSEHechC/hAsw8REMKdCzEMKU5p5vGMdnQkWZ+ZRmRio pjTHSbFpihOc
26wYNo2hzXHa4I7vBI02J7YGbxpjDZUo5w/t+f/OYsbzn/AMqDwHGs9pApSg Aj3oQc3pzhGM
IA98uEAO3HFLAtwBBrpsQQyqABaO8vGXxkBnxaopUmOMoArlFCfFwJnPcCYz pdIsJzp7OVOO
gvSmKb0kSsO5U5KSNKchTWlK0dnNcIKTpjZNakkLIlOZ9pSpRnVqR6eKVKom taMFqapWr7pV
rCqVo1WAZRUWoA2JdvCighBEC/RRBa5Q1ZS9xCRHR9rNkFYzmSg1xk/DWU5J QjWlU8XrW9cH
0o4S9q5DXZlNFVtUnzoWnEPl6lXpClLKRlauVs1sV6uqWcl29rNYhWVBVMED HtTjGh9swRFi
UAGvdtShsIxtJWIb27D/2pa2s73tbGE7297agLa3FeY738lb2Rq3tw5FrnEd Ws3kHve5yI0u
dKcr3epS97rWzS52t6vd7h5XMyedKhOmalVYVqIK5z1pJd5p2/RWore5TS96 a3te+a73vfUN
K35lK8383re97FUvetk74POiF732YCeA7RvgAi/4wept8H8jzOAKP/i/E3Yw hSGs4Q5z98PW
DQ9VYImJEdixxMl1pOwoiBxasJgKLobxi2dM4xrb+MY4Ng98BoUl3ARIUKuK j5zohCR27MlJ
SG6Sn9iRpmQwGclEHrKfhNzkJFN5ylLOMp20jOUte7nLUf4yl8cs5jKDOcta VoGa14yH+eBB
/wUxeLN/2qwCPMRAzexQ851VkGc+r/nPb15zMv7s50L3+c+HJvSa+8xoPDsa 0YtWNJz1TOlJ
W3rPmK50pi+t6U5z+tOb9vSmRy3qUoPa1KS2dKAJjQJ5oAAF+Xj1EGL96lrT etYowLWuY73r
V9+a1rSutax5Texg5xrYwq51r5cd618P29bPZvaxpy3tahOb2te2Nradre1u Z/vb2A63t6cN
62TDegjCRnY+0G3udpt73cmGd7nn/W52G1veyHZ3vdOdbnnr+98AD7jAA+7v gRv84AjXN7xd
3Wp+h9vXEJ93vvMtcWHveuIWb3ayLx5xjEP72M6uuMg9TvKOm3zkJ//3eMpX jvKWl9zlLKd4
vM/d7majG944v7nOaU5zfMd75z73NbvpLfSeA93e/i640Zeec6Yf3elQb7rU dw7rqUf96VbP
Ota3DnV6uxrXJ591PsZua7L72uxVN3bGie5uXI892GKP+MDBfm+5J/zueP83 2PPO9763e+/Q
brrQ8T1rexd+8Pb+OM+DzXhbH77cgm+83O9986XD/PIvz3zMT755zHde854X OcMZTm6Hkx3Y
Gq+6xDUed7dDvPVkj7vqr9142Bd72qgHvLLBPe7e8/734ja774NP/OEbX+30 VjfXtX5umwNb
585vvtOfnw95rDv615e+5T+OfL97X+BK/77/+O8+enL32u+uTn/Dra/+9q+/ 1dV/dfvjL2z3
2x/+pFd/r0HP/8/7n+0zF3r9J4D/130AOH4ImIDuxnwMuHwOeHU8l3wQ2IAT +IAUuHDyt3vv
Jw8c2IEe+IEg+IGtln4kyIEjeIImmIIeiIIhyIIu2IIp2HAKOIPCxgz5wAyv hoM0uIP/dm9h
MAgfEIRCOIREWIRGeIRImIRKuIRKaAlhYIA8GIVSKIVfZ3ZhEAs1wAhauIVc 2IVe+IVgGIZi
OIZkOIY1EAthQHpTuIZsyIMLRwdZWIZyOId0WIdzWAN0sAuEsId82Id++IeA GIiCOIiE6Icv
cAv58AT5UAd6WIiO//iIkBiJeyiDwnYGf/AH23CJmriJnNiJnniJmYiJnRiK mhiKpMiJp/iJ
pgiKn8iJZ/AErRiLsjiLtFiLl9gFV1AHi3gFRWCLvviLwOiJipcPloiKrbiK opiMymiMo+iJ
qViKzniMrJiMoViMwXiN2CiLRbAL+bALsJiN4BiOm9hwYDcE1siJAJCO6ViL ALCJ6tiOm/iM
lwiPmtiO9FiPf3CP+biP+hiL57iJInCJAcmJAzmQ2GiQzdiJBQmQf9AFhJAP hFCLC/kHCImQ
yyiQChmLFtmKBhmA54iM94iMIMmK9AiPp0iKmWiS8ziNq6iSoliSLAmNl3gG TpCJTiAODf95
iTVJkX/gBCIQiju5kxTpBDnZkwEZkETZBUOJlDYpAj7Jk0b5lE7Zk0DZk07Q BU/wkITgBFzZ
kwKplE7JlNOYk0L5lJeIkz4plENJlTp5lEG5lDx5kwJZln9AibhGkxe5knnp ifcIk7Tol63Y
j/uol7J4Bl0gAojpBACAmIcpAgDQmOIgAo2JmIwpmSIQmZbZBY9pmY6pmZmJ mIu5mY0Zmp7J
mYfZmByADITAAYTQmKepmep4mpQpm7NpmZFJm5T5mbdZmZo5mbCZjl2wm5NZ mSKgeCjwj8qo
j+pYj+s4mIRZks2ZjqTol/AYnfm4nPzIj/a4kqvoBIbZBeDJAQD/wAHg2QXi WZ7lKQLkiZ7s
iZ6PeZjk+Z7pWZ7n+Zrm+Z71mZ7k+QRqoJWS6Z70uZjtyZ7/iZ4FOqD6+Zry eZ7rKZ8Hyp7k
aHbI6Y7JCJMWSpLYeYrbSaF6uaHbeaEf2qGe+J0NKp/puJ7myZ7kyQEPyqLg OZ4vup4uiqKa
uaIAGqPhWaAcgAJa6QQz6pguGp5COqNDKpkyqqLm+Z80uqLj+Z8LqqP0maTm mW7s9pHT2Jf4
eKH4+JzL6ZLZKaIrCaJfWp0y+QdngKLiCaNpGp6xKZ5r6qb3maL1yaCP+abj +Y736aZ3eqdx
ygFPwKMQyaIyWqcpep/AmaZ7aqh7yqSH/7qoikqocGqjdtqoXUCJtVaM8oil YZqlFbqlWkqh
7ZiSnuqcIeqhhLmJhskBTKqncDqequqod7qqKeqqNVqjMBqrMGqrrHqr8Ume yNCfEJkKNlqr
NqqmsVqrx8qr5vmqadqrxlqs8XmiyLqq4zmMyDmdnbqp2vqc3BqSp2qqG5qd ITqPLmmTJJqn
uPqq7xipfMqscnqsbhqvrMqs6eqq9qqqT4AAq7maK/qqy7qsdTqv93qv8bqu zxqwkKqmBeuu
rBqhsjahW8qc0EmmEquS7+icHNqhZHqx4gqmI6qqAMusC6uqIjuv8Rqyriqv A0uy9TqyrooM
gEoIwrqf8sqyNv9LsLG6sCmbsyabsjWLsze7ow5npdRYpiIZk7V4tEW7tLKo oUjrneb5BCIL
tPQatM0qtTaLtTmbrlXLtc2qqmoQsyRrs1YrsFWrs2XLs+OptSxLtQ1LendJ lOIYjUwLjig5
lszpj2Mbr1L7BDt7on5Ltieasn3rs/Zqr36rjlILAH7buAXbt6mpr4HqpySb uCfqp+o4tZjr
suqajoG7uYhKuIg6sqOLucaJqUh7kni7tPKYkEqrtLb4ujNJsshAuXtLuVi7 t1hbu7tru2Ob
u7h7u8JbuaCrqsggD4SQlfg6vL3bvMO7vKnpu9Jru7x7u5AbvcBLsg4baxCb kMwYi7D/i413
y7q0eKbSW7vGu7foi77PS7vp675jy77yC79fy7vIILn8Sr/s277r+77Cu7/9 e7sBPLwB/HPH
GY9I+70IXLd0K7sMHLtP+4p9+wQUXMHgUMEYTMF+msEcnMEb3MEgHMIejAz3 q5UifMIo3MEf
PMErnMIhbHcHPIvy2LreS8MQvLrIOIuvqAbI8AQ9/MP86cNCDMRqMMRGDMRE fMRKXMQ9zMRB
3MRCzMRqgADMQAiq6cNQnMVKjMRb3MVc/MVeHMYwW3DEmLp4m8MXicaqaMYL vMZ0S75nEMdy
PMd0XMd2fMd4nMd6vMd83Md+/MeALIO31r3AOMMyacNtbLQK/1zIq1umbZzD hpzI14jIzAjJ
DTyWlvzA4auJjneptCi3XhnKsii3oDy3TSvJapy0przKrLyXkuzKjfzGlsq9 cnu0mXjLCIzL
4WvLoqjLMYnLmFy3qtuMmQzM0Di+rHi3xrzMydzLzuzL4wvNzuy91CzKk3zG nRh46Ea0NozI
w+yLNCzNwbyK0jzMQKnMyijOjpzIqXzDlPzMx6zIzJzOzYzMqHyJDgtr3evL y4jLRLkNpay6
AD3NoBjQD/zIi0zMh7zOsJzG6/yM6ozO0TjPb9zPbzzQ9kzPzEyKRBlvN4i6 /LzAGx3PBJ2K
AB3RXlnOv5yMO+nPp/jPFg3P8DzSRf87z4Zsz+rczKzY0qRskyX905r4lmw5 1Aady3UJt7S8
xhQN0d8bzeDL0J1IypxYytYcyiYdi1TtvTD90tNMzg7dyLWclzi9tLUs1QXN tMCMzgPNlmuN
z3ZnjTZpzGENjS0909MolGrd1XTt00M9zvQs0zp5t2XZnS4tinMd1MbM0hwd z4PN1izdy3hN
0n+d1wuNzExtzkcNcvr8vYqJnQCQ1VgtyVkNyp9Nkrmskqlsz6FKmE59pdJo ijBN1/KMiaW8
naktmBiN0Gk90Ti80A49vlT60esMANOpmCGtjHWNzTGtk/2Yw6t9pZGtljZp sf4M1BW61RYt
0SmZ0c5M3LP/vd2ATb6uq9OTLdNefdX4rIav9o8YvdqhSI9lHdijGNZzvdYt SdvlTY8oqd/s
/NzeKtLx+NxWTdVVed2KPc1EWdrnrJMMXtoMDtTn7dt/HcsMzM+ZyH0xrNPe +tnrmJLSSa6f
7eHvnY6x7d0mrp3z6OHV2dklbuIffp0nztzqOOIubtj2WJ0fro6dPeLdjeP9 eLE4DuIxPuP7
aNxEXeATjozJ/cyxjd1t7LCzhpf9HOKhbJ1Ubttjmo9yq9+l3eUsruUc7pUc HqrwWJNeLqpX
ruW3nOZAaY9h7eZarq0rvuL1mOA7qeBqzo+KiYlujuYsbaqOTNHITdD4Lcq7 nczx/+1u5/jm
COzde16SirnlPRmqnb2cA12qpPql7/3e2Qrpnp6x7VjpYV7cLq7joX7qKV6K Rl6SbV7nFLvn
87jnor7qNE3bC+7Y8RjZcs3REp3ZyAbS+O3eerkNo56dosrn3ImKmL7aIWqK Co7nZP6S++jn
ay7tzD6Y1U6mzo7sxE7bAq7t057str3n3e7n1+7lvd3UAH7PCG2MRQdv3Rvq se7dX/rozF3k
G2rk033vsB7pYT7ppIqtcZ6P3Q7wDj7wxF3m9sjRcO7ggA7o4O3wpm3wgwnn HTvpIl7PNW3X
vKzS0szToWip6x3Pl27pz87n0mnmKU/sxK3y+kjsaw7e3f9e6gAP0CZp5zC+ 5euo77Mu5LL+
3maOkzoe5+hO4g/e5UZf5aae4Ehv9E3f5aDo4P889Wdd6BhN9YWO9YuNxrds rZsIysAM9g9+
zWp5ygrM9dTM1Az9zYH9k7f89pgI99sg93Qf93Y/93YvDqFa93jvmBqtyH4d zEC95F6d3uYH
12Kd3Ry/+Bqv0uZNvhGu17sd+ZNP4a3Ml7OY9Mud5Oqu3F/91x6JzYmd2Nfs i0F5yyBv66p/
0quf+qz/+q4P8hHu8YtP+7b/+JBf+7qP97fvy3aZ1Gdt1msd31eP38Vf/MZP 9cc/kcyPkVDZ
/M/v/NA//bm+llN5/USJ/daf/dz/v/3er/3gn/3JP/6hbNbm/+DnP+Dov/6n 69sO/P4JDP9/
3/u7X/+3z8byn//4j7Q4+Qf93/8AIWLbH3F/tgn8g7DgwYEKDSKE2FBiwoEL I/5BIQ/FkHz5
UOQ788egSBEkRRZMeNJkSpYlW65E6VLmypkDR960mVOkTpw7ffYEylNoyqFB fxZFelSp0aI/
e9p8KnLkQKpTpVaFWhXF1o8cmYW8ahWrWLJjzZZFe1ZtWrZr3baF+1ZuXKtL qy4NezOvVL58
ofrtm5Er15BUnexkkFjxYsaNHT+GHFnyZMqVLV/GnFnzZs6OuXr8iAKsz799 TZ9GnVr1atat
Xb+GHVv2/2zatV0L5rgR5GGbIg67PCzVJd/Dv0kad1LyYN+GJnkzH7kwqk7D 28YGdXJXutnn
KLsY5G0z+07ez6uWH+n7LHj228yjHx/cvN/gDcfrvct+e133+d3vHGyw0eYb r6L4BEpuogL/
WJA9BJUDryIGEaQuLHF0ui+/8RCS0L+oUKrwLqgSJI0sBqtCKKoT+RspQxb1 Euk+/GIMKzin
bDRtuL1sEgw0jwojSzmXcgrRRBFxei4qIZMDD0IGC4Lyj++EbG4gJ6Rj8iAm v3OvpPIEKslL
gh56CCvfSvJOJC7HbNGiwywi6E0pVXJTSDZRihJCl74jkyE0m+xTy+X2K4hP Lv/D3CqfIboS
rUYI45vIp/v4BLHF86Kb0MrzRCSxIBKxE8/KFDsNcqIUI0SoPJ0gXCvVirjD aq7rYvXJ0+tm
HJOnmxpEyUiMNArwDN9U+q9KnEr6zlb2rkzuyoSc3WZNFJ9ls0ueFvwvu+yq ZJW8qZJEr1je
hs0qzJ2GXIlNoqTqlaaX0l1OuPTYZVKc4NYks6AzBc1yXGe7GDQ9ZgG9k7fP Em2UvOY4fPZM
F/Uds1Kret3yWe1IfG5bnxySCtIVrXU0uxRR1DQ6bOccE2N7y0QZz0xXtIpE Cf21z+ISGV6w
QWOPFA9TnfbrbyTcPOIIyFybbHYsMN8b6TunU+7z2Dj/R9aTyZSLLRPdiElj tluTnVzOSoGR
9BVmcc006LvD1lybwYeSRNtTbyEu9NyTIU723BbBk07gP1MKkLCQRQCg8MK3 XvlrAPI2HIAV
1YPyXwYNf3LFNREcE81mY0R2RWfNRfFNq620N1UwKWr6W5MMc5XFJH2dFXWx SwZzOY+Prpfa
u5wdL+9H6w59oB4RPqM71QGotL4wn3N8QuQTAuDPnjd+Xpzo/3ieKukuFAsA P60zaDuNl+Ny
m4XcO9+gDtWXsyooret94jG5PLS/gaR1dnv1I5yT+7BtlFCUuoQ7vx0tSu3p 31TEZJ9ELUpR
CVuRvg7iOPMlqHYiq0j0GEJB/yd4L3UXEsiUtkHB6DjuaeOxlW+gdL377Glr SZtXegKYEvVk
TkuYkpEA59Q6m+gPQiJU4IZIFbqWSc5zrcsfxkTlueWcyVteWhpCBBMst70t J9FjXuF+Yzjf
AGBcWLTelAx3mMN1CYzaOlzhCDes640Re8jTYAe7cLgOqnGEnesSgT5ms5w4 cVC8U9PcApk4
tRHsP6Xz102Gpa8CqYVhHTqL/9T3SKqgj32xosrBQgOkvpWOhHPMICgnRzhG No48niTcREZ4
OOhJyYNenGAHGxI9x3Vwi9hz5Zma10IJOfF0+zrOnAzDPxmi7iLFvAjHqJLM nPXwWcqKT+ke
p7skTf9JPn+S0f0a9pfvDE03wrpKDQ2CxZJgEZfXs14HS6jCxYmkcR2socva Oc/vXG+EYZzK
8+K4OH027kKRq+S3AkoVgK1vXEQJV0L3Jrb26PEq9UnJmqSFKYCxyk/jQ5Og 1PdP+EkIYEBD
n/mEFriEgWyHJEwlQfgJHloikoQm5CAtm4MxxxGulemMZS116cpZYi85zWOo EDWXp2eyBGMC
WQgKIybSKEWuqdFiasQsaL5oUcRe++FSsxipkyn1BJjG45ONtkqjulnTbd3U iI8gyDfymPOO
ZMSeLtX5EHI2r662xBwYYbnXetYTjhscYT3tVThRtnOOIBwo04JmP+ngS4T/ GevYMKmDo49B
1m3DZKt0lGOmqgb0qmOpKLZCOBYQ8o+zI33gA8GCQWFar4ICMVyyDFcQ5G2Q i1Bt3BpfRbjD
rdCmP6UlcD04x8nRMq7ChavVEKK2ZM4UdYXyrJS+11SCVFCCSI3q+xBbN6Re jSJCdVaMGHkq
FY4uc596ptVElhJPQWROUxQQq5bEEm7p521u65ZxsFazPrrNXgxJELRqWD8E XXWSFwXwyiwC
MoAFuMAwI1cVs4XA4izLbeG6MAJn16ffxIq1i72S/diX1EqGeHwhvSTLFqvJ H7HrZf+9oKck
aLEYb/NBVS1dAJkl0g4tN1cqlKo2talZbQoYZDeW/26S/wvQQtXOyVH0k5Oj rCUn183A4tjX
VIvaOSdYk8vL47KX58QkJzKXzAN7mm+8WbTuCDmpT40TQxay4BD/+FXVjbND cAwtN9F5ztXd
l8OWXCYBY3CIS5IvWSaqvbJ0i9FmcfSdlymy9QL4wQnu042NLGBCX/pQIiMp BMnMJieG14mM
pGHuGnbeVP/Nl3huL0NgPb8dyvp7c+qCj3OtzV3j+sZLU9tVu4Y+Ztkr2MUO sLCN/SRkF5hZ
JxR23rSUpxlKG8gzjpK18/dcWjtkeJv0r3uQ/b0dOzvBhoYxsc+9bnPn2TAr A9j+kkroqRDq
tMu8d9Z6vG8793vB/mbZv/8FTuh0l1vd5kb4wRVucIYvuYGMMlrtAj5xWQ+8 4hTXc8b5DUSI
dJnGlr61xTUO8IuXfOQi5zfKSX5yjKe85St3+cXhS5ghbZu6N0dcznG+c50j jtJdsCClbccn
zP2J50fvOdKVnnSmL93pTYf606nL4oSxVgRRwHrWtb51rnfd618Hu9YJgfWx R6HsZ4/CIcye
9rWrPexvh3vc5T53utfd7ndf827e9t9D2MbvrhFB4AU/+MEnRPAs+XviFb94 xic+1KOpeBQa
z3gRBEitn3ngw1Ewec533vOT//aPILocyX++L7VoRC0OsPphpMH1JSgBPoDh BakgTDe6AU1u
QjP/GB2Z3ve/B35gGKVaeoGp9MAHxgSUv4Y1VMAUD5iHFWTQDyjAgySMsvyi BpN50ATf+9/3
/cy3Ak70nen4tXFA+tW/fvVLpRaob0QjDjCM1qcB9vjwgvVFMhhgBQhYoNmK 3Og98CPAAqwN
quOkjTo/vggHtTuEB1S7cDgNB0CACkQANVADZHiCJwAHDnAAqSCCLuiBHhDB EhzBJkBBYbi+
jGgcAJAHFwQAzQPAzTPAGrTB2Mi7kOCNp1lAqeg70/jBvqDAC8RADQSHJ+iC LvhAkQgGDLCH
WsCAY8AAKMwADCgCDMAAFdy/rXDB2+PC/gvAjtiKAbzBMjTDLQwcIHGa/4Po QZEIwubpgiDk
iyGUhwzUwCcIgFxbwj8ggmnIBSgIglwIAkAUxFwwRC2sPBbkP0UUjP/TvjOE xEicIgAEp4dI
ljb8g0NIwjnqAmRAADmUCgoswg3EwzwUhz0Mhi1QxVVkxVUUgNr7wsGIwS40 nJkjw0jExe/7
DO1rFIkwP9TQxBZkhr5jgD8oxmJ0gDoMgDsMgGZMiD3khWCIxmAIBjmwRhdY hVUQAGFAxK14
wVp8wRdEgS4Ux93LxXM0QNvbJN54n20ARR/kAHBABgDwRHN4xz9wgAxsRmRo xjwUiT2UhgYQ
yIEkyIGUBlgcR43IjVn8RsNRSI+4RXSUyM7DPv/iE6/kuDpgRIA6OAEAeIYB AIR7dABk4Md+
DIBeAcgGcIJU6IFUYEmXbMlUcIKDTAhvjEGuCMdZDDUanMieNL1JpDkMMj5g BARv8IYlOEpv
EEkO7IJ+5JN/lIoxaACZXEknqMqqTIUxQMguBA2GjEGNAACPAI2I9Mmy9Ltd FJyTKDZMDIe0
c8AInMAn4AAOaErT2ENWaAAGKY69dBtWWEFxfKCcZMHCcaBHNMvDZLyZ+5FF EoGKwkTYcAC6
TELEg0qR0IHLxMzM1EyE3MnO5EnEBE3bOBjiIyiCEIfHlIpiVI3I7AKIEcID 9EzPDM3ZPMCH
FJy18Y3vQE3XYL/eTD//2IzNnaTN4cRBy2uUBROB05TI4OxM4nTO1vi2ojkr LGND1lDN58TO
7NS88TOZq9rNxnu/1GO917O/2dO/7ETPxoMv0BCWNzG2jFyN6/y75JuABEiA 5nu+6Js+KACG
9PTPxcM87QOSLhtKv/PN3nQ/1FO91XM9+4u9/PvPCD1L2xw/IamobWBLt3TL Q5BAu7RAIrxD
utxDIhjBHtiGEhXBJuiBFDSN5lk8F5VQnwycFssOpwk8TLxHkbxAEDXCJIRG e3hCSTiGIqgF
IS2CabhCLeQLGE08Jo3R5UyrMAwJ5QA6gLnHTJQKdNJRBFACJWgGJTCDZjCD 1kRFQ5wGPyjE
/0AMREN8xb5wUr970yfNxe3sxeTItRsFxk1cHHBwBB1Vgy710mYQU3E4Rang BVUsg1ZsRSXN
0hZlJRd1nEiF1Ed9IzmFUk1qT4YAmC7A0TlqnGE0xlBFxjr80jA1g1OtzD+I xmmsRmvMxm0U
hjZd0tSI1EalVEitVFyy1DlNlMwDCzDJNeU8jUOYy3lEBke4BZHMwEA9VVTF R6kIyIKU1gag
yVl1U8rB1Wx100bdVVz0pgqt0U0VVtOIAkcwh1vwSEAIyQnUQDAV02ZN1YDE ypeMyZYchxbd
VnfS1XOy1Xzd1249Q+PsRSlJzivB0aJMSqRcSnAw1WY1g1SVSpmkSv+JtUqZ 1Ep/1Vd9tata
1dh+zViADdjdy432BLRcy9AH1NAOFUIOeAKHhddnFQm81MuZtcq+dFTKeaNH rVVczdmPjVOQ
LUDsE5z7aczk/E7WYM0kbJdU1cymzUyghdpfUcf2FIfWjBZOtc7ViEwsI8M9 jNqvZQ205M6G
uFP4tI0DZT+wVdvVUEzRUKGrtdK1ldugRRjSJNiDGNfUkM+55dsJ9UK3tdNN xNrgU9DVm78G
vb/Z69sYfbymKdq8RY29tQ36nADmcz7okz7qO8/F9c/QA9yqvVrInQ20Xb8E jT/5o7/Xe9DN
5Vz0fDi7bcyqFV2RaMANhUsPtcBR5EAPBEH/ESTB3/VdFGwCRrXW2mjBj+U8 U5qNn8VO8fvc
1lRaHB3WCaxADMxADkRCJZSKJnzCKJxCDKjCK8xC1GDe1nDS8oUNJoVR9C3e J0XApoHe2cXS
jI1D6kWAOiTJDcxDERhRPyTEQVRTQ8wF4uVW48VXxVNfA7bUHDwJ6G3NTk3C xfFEP71e/TVF
VFTUDJZVf8VZnsXZAubWDk6jSbWrXGUl5HWnjSXhFNbVDs7V4Wxcp5Fd+Q3G TyVGUcVHZWRG
Z+RfQ5VGamxVOcBGbeRG8sVXngVh5eXXjm3hfZVUJgbhjEViJubYcyphGP4/ mkuboh1cIIxH
Y0UAe5xAfVxGp4zX/2mV1mrlYBcm4fU9YlO6YknFVo+N4hZWXjiG4ipm3+Xc zpAolE002744
hI3syI9cV7skSZM8yVCEVpV8yUeOyZnM1ytuYkp2421N4Erm4H/l5CYuXo7V YycmTnWkUULl
4is9BIRFSoWNS3BoymZ8Spj9g4it2FrGyosNYZ8t4Ck+X1GOY1+mY+QFZToe Zm1FYdCsyEXx
4yuJ35N9yyhQ2TmUS7oMALuUCpmt2WyuML+81iX94PX94Jyl1J71ZBXWZU6+ 4yw94XQ2Z1HG
4qlt4Gb+u6TtqjmUCqfF59b9T7FtFBlOwkCOXK2lS9e0Z31W27alWqVNwiuF TNL9TYMG2//R
VOYJiV/5heiLho1vdduDENwu1luMBunTmNGEqVp5JtzCPVz7K08IDelRjtJv eqYuGGiGTs3F
o0/7xE/M3c/+bGkYFtpGYWaTPluH3sPwXNADQNzV7el3tr32jN3W5ABn3tBo DsUP1V2ZHtES
PdERTNEVHd7TCGfa2OOlpo0AHdvG3EQanl7cBVFS5IBCFQleANIiHVK6PtIk PeBOjo2xJmvZ
0OiEFgfJlF53QhMKrmAOyEPtZUIzRdMAXtNc2OBjVuC+Br3tG7/AFWpB1tMu 4FMdxd8d1kND
RdQMXkUCftNv1tkULuETpmzHE1nRC6G0RmVPNRxQPcZQTUY1WEb/uTRjaPxh arRGOXhVboxs
1d5lTNblcW7tv/vpXhSBgX5rHC1WekRWZdXtACjFRZblaEVjg1QNFdbZNELh KV7u2oTn2C7p
Ky3Xc03XQxZCDVTkp0zJeW3Jek2Fe6XV8fbYTNbr8i5OoZ1S2W1NGlblpFzY 7G6XPaTlib1K
i81rSwbmCO9v/34NhG7MLpPMqEaNtkRZlKXqf2TZJNRuRo7ZvNRmmv0Dbr5W cG5jJ1ZuvqZw
05Bo5841ugTo0ZXM1rRmy8Tnpo3xnvxripDM5/5OyV1Zrp3AH0/PkQ6JXKvx B55nolZy131p
6URr6NXwKW9pOl3mt7bxIqc8whNzstRy/xtcT+508k3McuCzDDIvcwI0a9EI 3OeG8vhUPBHw
jI7giCGQByN/czOnULcNIS+vXwOVcpFo8z+HRIHVQTofaLZ8Sw+fQGZwBEp3 BCLcQHBYQjwf
vj3nPyMfgFAfgD8Ydb4odVFX9MR8bbdNc5kudCBcayFkBksnwiN05T1kAI1g ABRggHzo9V0H
DQbovVIXiVDvi1EndmJP9bPMvKFtTMlUa/oVSVrHwEz3UZLY9dctzK2QXGUv dqk49WVXzyyu
ULQObCLP0wjuxE+c9OpVA2sn09QEQ5Lq82E3jWT/dnEH0D6Wkqr1chqm7cKx bRx2gEuvYFf+
5023jHtn+Hwndf9j13e/PZgmR2vJROUvpscwpmANzPFUzfXby42Q9/WGP3ZS Pw1vj/j/FsuJ
LmkbX3NBJmSPBEnrhncdl+Vs98xuP3mTJ/mU9+tAp3g1J3CjXGWlZFd4T3B5 b8Sl14g+73l8
B/eo9/nZYPJ+p0svl2pJt8uaT3pED05QR3WpB3eIn/qff+2gv3qPpo3IRPhY 9vjKKHs4/2k/
dnWsz9rVHPIB9Nq4P8cz7+eKl+mj1dpD53t0jHOKh26LLvxd/euKD+zAv/s7 H3PCW3zvY/Lk
aPk6/z08h/vK/73oBAkpScK0p2lEXzzHUJTU/wg/93z1nHuCdXm1H13CX/jW /8n+Y8//wKt7
DhCBK+XwSP9wfJz1Snd3psR1H9lzH1GUbhd1lLd9v+5VARX9uo92QZ7ASqf0 C7xDucR1jtj1
X/f1wPRz539+s9e9v0/7l+eLNyzsSXcEg8/ADrx2rwd5ogFAYd/58j9L42zy x7f7YQWILgIB
dAHn6NCfhAr/OGDmCIEaNU+egBMozkFCEQzkoejo8SMKeQwWLhxAcgBKhShN /lnZkiXJmDJn
0qxp8ybOnDp38owZEkW+jkPynREhkIM4Dl04RJl5qAuAqFGZIRxplSECiBLB PRHYhaFCBmLH
ki0rQibMlipPqm2btifcuHLn0qXbMd+Qj2f+eOWglKlTv8gA/yBzdAthTAda J3btsu0sxoQM
8ALNS5myyJlpV6Z8mZIl6LqiR5MuHffn3Y57+y4V11RmFEfmbgF4BggQYpIO 1CCbWNFiwsh/
GIAs3nEk2pJsE5oM3dY09OjSR3vMRxnFahF+kwKWeQiQN29LxHvLvXC3b6/n w3Js/9N95uRr
mT9vTv/59Pz699P8OdRjUUcttdRrMYUTxSGHIKhgODI5gAwHjT22nmTGFYdc TG+5xJxLzr3F
H4ghRldcUKsd9VeBcjnAwW9dnEXhcGXJOJaINdp4404/BYXCUCb+pV2KM2E4 04pdiCPCizDi
uCSTTep0V14A8qXdUn4FCZcDWWq5pf+WTnr5JZgJoQaUakZVOaB5Yaq5Jptw VXfdakm11l1N
Q9aFJJ555tkmn33e5N+O2JnpF4oiznhokn4q6idIO5o4oJU32SmXRjIChRde 8S26KZ+p8Vgi
kpASWBeXpWYZ1qEyJsopq19WBpKPSEUqUzgKJphgFA0m5pBDD0XkW2QavYpp lB1pel9yHy6n
k7LIyjcfs521ehpHZJZ54nZpKqTtH9w21KtWXFUk3EYoEDcZutYykGiz+NHU rmbv1gTvTTA1
S++01RUbJ6R0kpQbAAl14S24v1IkULDEQTlslJPaC61N+GYILb0SyxvxtDaN SWaAovq70FMD
dYEMAgRnZfD/bxexZ6FHIq368H32ScsZhx46C3N9nX0Ws1ozb+isSgPswmHG /aVGWaxVXpnQ
U1JNVdVwUTvga28HCyRCwqmWNTGyoelcH9g2Uzzfw16v9TXONY9tMaeASilg od6xOBjJ5nir
VW9KCRTcyv/5HdRQk/Y8OH1ln324zGwl3rVbm4UNsXKe7Vz0TCRi94eskC7d LQJ1nFDbALg5
iLJX4vBdIcseCZ644YUf7vriiIPtOuG12wc02ctSTpKOQhHFV5WEbv5deOON 523VKcNYLnzv
hST47LTbPnvaY6/N8/Rpw9z67ry/+vZfLn6s0IG44qqrbukBpxC5qase783U b/hz//WMl/T1
49v/rHbQ9e8+pqMGRajx9WRFLUoMqrRGo+7lhG0MrNxd4AS8KiVlcwuBHvv0 hiQEPnA0NOug
XNx2LUIpjVSm4hIIU+glyz1qgBZUIQwf2LtP7SV8catTafSkww3GsId2+Z5q gDdAAkqnUgoU
iw+T6KZqWatjNnyhZEgzI2IFJR8YVCIWfRLBKNUweLOaywlRKJkjIjGLZqyJ CC8Ht1HRakEL
OgT6zsMMXp1sK10g146ouEU7tQteGuLJ/jAWuXrhxI8ZYyHmvEhEbnnLEXOk GmM4QK7AmcuK
lszLsdw1yGfBxX/u+iNplOXANc2wR0LUnFMUAoCziINgjv/wFW/Aobf2faqW /znOy6x3sbjg
S0NDY84vPcjJfAHxcn9xoVO8QhCDuHIxVlPZHzTCRAtlMnr20tntzOYzaWnS M0QLGjj51xyv
ze9188sm2kYZIgAGcY2LhIrTqBK1qyhmMVxRD7nIuK5lbc+cYTMb0Oj3Otl9 aJywG+jt/Fk2
56jpTVxM5BCHJxjCGOZuBpMQZMJyGctw9HnJmh7tuJnQkcKPMwk96DUnNzju oXNyJPVkk9LY
xSfOJDazqc1tvMUb9RnpdMNx33E+StKQPk569wrocsSWvaKuVKEIZVOjgnhM 4TkFPOQ53uh4
urzmcRV62vOnW5jqOOzVDnsMfWn/UXfWOrTiboVM/M9MUdlG8zHIQRDC6PKA ai74fRJ/htMf
N73ZP4iBUnL5o9/iPthS+zXUU1JVJBRxYkCvrCqfZMSROkuT2e7JFKJyxWFN inSkVYGFTx9c
0mb/F9WZIpMuYdzSGWMrmlL+7kxUlS1uO1XMGmrHL2wE7Wh2qMPcEpedgvIY EaWjzysSt4cO
fWxEJRXcKQ6lutVsrhJl6oTeflZFrz3VGMlIWuz6MKrG7O1tDWSrW+XKQbx6 pTPBkbDKYKo6
xnLYaQdayPzuJ7UxHBNcqURT7xB4VwVTg7juGJbjWLGSDLjlPjfJtW5y0r+6 kzB5FWLft0E2
lQkJGF9c/wlL9c2XYUerpiHbWuFQ8jXDC+msDX/7L2WOrGTuraP6oDmcaX6k ulac8P3UChps
btKgLwmmz35pZGwOuXHklC0iOYDeL87YaQCQ51VGMjWIJI+yWbvsSQR6UKbW zK9OLRxAlZPm
JceWtnG94b/mRhgE2M1BeHuC3r5S2h3bEnCBijDk8se4wpJNsf1T6Ug7ZNTo ZXFhUpoqlUHW
uc89I3Q6lYjVerpnhaUOxRNOrH41ydDIFTabZwapGY37ZhmDzKrGK49dc7xV 5zVvrxcWNJlF
PehFr/XUQ031FqHbWgO58XwO4qnp2Ldg96H4tDTzEP4CndJwCrafhiVcOVXs XP+O3NKYHovs
TSa7N90k8IgubvRHHAXRYdOEuUVyEWmFoxMP0Lve9r43vvOt733zu9/+/re+ s/vWEnkWznH5
Lnh3AvCFM7zhDn94dh3r7eiu6eEWvzjGGy7wWkK3u0KyUb2bG/IkRrnDIapF LRpRiwOwfBhp
SEMJSgAPL3hh5Lm1+batZUoSGlwmzN0JMCYwgQSsYQ0VMMUD5mEFGfSjH/DA uWyhDkNHS3XK
ydUJwoWDcpU34gDDcDnM8YEPYNSc3iI3O8mZGEDkbq58621vYrJSx6otRThE 6AHet9GDLux9
7034uzCkfkbBp/C5xhxgBT38LzvPPZI65oU97FELSRz/owi1wEAGMCAJDBQh 8Gi/+edz3m3e
UjwmuTmLCFpp54jsFM8BQJhCgpGLXEzDD7kIwu1zP3sBED6Lve+geWvo254z zSsCYaad5cGb
qgXg9VhTCC+2sIUySL/61t8C70Mfde1PXeeg6lektwVPqWB5ngxRfgDy1vzX 75kXwXB/MIIh
h/mvov7CuP/vlZh/Bhbz8IRKvNxwADIMIDMcxuioQfM9wfolm3BIQwM8IARG IAQ+wv75UAX+
T7UEivB50ebY1C08AwiKTmL0xvo1n57tmQM6QSqoYCr0QAumwguOwwXG0AwW jb6Az4CZnquR
h7dQhAI2X7L51Bg0wAquoAoe/+ERjkENqtAS5ss0gQqkEZHbuVEcZVBjBEAQ +hQrNMAfOIET
dOEXemEX/gErNCEImSGr2BfS8MXwASAY5VkW+pQOzCEd1qEdouED4eGmwJjJ AReRIAUPkRtP
6GH3EKKiRNnwsRqWIFxPGCLlOGKfuNm6pVeYQGLGWGKbUJ0ateHVRRFP/JxN YGKriCIpqV2Z
RCG4gVzGrSIrtmLEXQoXOYFtKWJMgCJJ2CJNtKIu7qLDbdzoTWL48QfC8SIx FuO+vaJ9Cd9f
uGG79YS7yd2dUYQkLQQG7MAfxAE94AIpcEMKvMImFAFNSAVPgFg4/gE51sU5 miNJgJjTzEQ6
qlJUfP9YmEgiKt5IPbFeb9yTgikEBhhBD2BDJFCDEGyjL/TBObijKu3EO66j Oo5GOp4jOy5E
wDykTJBjRLrKbmFOInZi1HyiTdST8g3gRDifvLVBIBgAGiyDQJICKfiAFMQD QsLFQkpkQ4oG
RSZkTeKkTtIkQ7qKKU4cu4WIYkRE1fygkQgHCSSlHizlUv7DDfxDAURDNFRk RcZjQ0KkOVqk
VU7kh1klTl6kOGblVYalPOZkV4qlRe5kWa5QsPnfnEQWLoaF+WXZ+SEg8zVf NMlbBAABMVyC
FrjBJbgBBaCDNcxBOHolTV7kWapjWnJlWn6lPDZmZO6kYkJmTWqlV87kjfD/ YemJyG4gQ/OB
pgn6FAnQQgjcAA4og2riAA5gASckAh7YBGZyZU42Zjs6JmUypm5O5m7W5lpa 5kTepmWyZbq5
JfHdInQ8iGguoLIpBA9oQjuAQApwgzVYQwegggmUw00oJm1iJW8mJG36Jm5K Zm965zuCpU4+
pmbaCD32oWcezPqd4J79wRN0Ag1www9IgXUaAgRkADhSZVmq502Wp24+Znqu ZXdeJk9iJXoi
6HA6iSYq41tKl2k4AJ4pRQBwkEKsQCdQQiv0gSgYgiKwwRvUBFlm5VbGhIBG JDsipoN2ZYO2
Y3qSZYJWpYFC6E+yFiUKZZ5FkyAuRBF4Ahz4QB8o/8A5/OdcrKeXKKlMgonh SehxXlByKoXp
xNt+uGibMKlCziO3aSAwcmR0ZN25IWNqQCkzftyYpmldtGdnoqmavqmbZCTP 0eJ0bN3Ked3L
lQDMkR08wOl/5eiXwiVpBN3QEd3RJd3S9QMUAIOfdh8sShUnpmJoMWJC2CnL HcDLwVwJ4IMX
9GmjFl6XPpp7LsQU3koVBgc0EuVE1J1C3F3e4V3fNUEPAJ6K8uR2fipxJqNG 5uDimR7jRSOe
PV7kTV7lEWsRTEMRYIAwqOiNoiOu5gebBuW2qBIrWZSquh7sJYTs0Z7t4Z63 zl4uCACzqiVd
aOmznoacRmoyiQzyxV1I3v+liwhH9E3f9V3fsjIkd6Yob8poWG4llp4rtWyY jgZjt4zf08xl
Xaaf642mvL5f/Mkf/a2CANyfuOLrb34nbl5sjZolwMbpoxonnR7CRBWGASZG RCQgc6KgBK7s
A0pDrZZnv16lgqJod8pox4ZQqArbjiqEB+KUCOoGCZbgCTZgAxwhDLqgC8bg y4rlzCYoee6m
ud7sn6zWrk6od+wgViWGD6asEBIhEhahF67gGCytvs4sgZJns0ptjnDEjuzc qJJPsdVVYkSI
QGDhj24hGOatGH4hKyztZdLoV/ZrzKKo2oZQuvLqwcGhhtoh49ahdERt4S6R wAYqqQDieMmb
jdjxbOSOSFuaKZh+JKVubnnlLFDurOhKLSIi7umiLtv6zsB+7urCaYRWraxI auyqqapR7u2q
7ZPSLp3u7qdyprQCL64GH+2eKfEW78CVLsEmr+xKHJT+rvPibpeqWz1O77Om 20PxHPJi75vO
kM42r/ee2+zOKeyOb27l7vWi7/PConV4ru2yb5vl7BC8bvzKL7BNrvneL/5i kafAle7275j2
H/wKcJqihgYaxRCdrwG/4nVMnMc1cHNtDMEtMANLsHMdTV68WfdiMJSRrjIO rwe3GUhwxKpd
8AiDqvP4nwinMLoVxwnzrwvLkHGEsOnOMBYFBAA7
name="ToolbarWithName.gif"
filename="ToolbarWithName.gif"
R0lGODlh/QBDAfcAAAQCBCSiJHyCpMTCxDQ2fHSK1C9alOTi3Fym3Gx6xGxi jKyqnJTC5NTy
/BxShKSm3HRwjGRqjExCVEtOlLyC3NTC3LSOvFCe1N7i9IRyrKSm9Hyy3PTy 7PwCBOSKLGRa
pKS23BwKTPz69IyizFxKfEQ+RNTSxOzq3Jym/NTS5ISm5IyX/FxWhKSetHSG zFBSnHSS1Ixu
vEVGjB8mdDQ+fLTS7EZupPy7PHR8pGxiPHR2rPPy/FRipMS21Hya3EQ2ZHaF 7LzC3KSyvNza
zJSq3Ex0pFxijOXl7HRopM6x1G91nMTa7KyaxHC9bHB83MS5pMzO9Ozr9GRe tO/7/LSmzOzu
7HyevDRCjKzK7LTGzDRilGxGnNDM3PT29FRarLy+3FxOfGBSlFxOjOLFjIRy NIF6vHyc5HyK
9LzK5NCcxHTDdJSanOTm5Gis3HxonGx2lKSOzPTm/NyiVNTW1FhJjCwudGBu tE89dHiG9LHD
5ISq7ODY7Pz9/LSuzNDMvFw2lKyu1KyS1Nye/BQWZOyWLJx+zJSmtJSCvExC ZHyatIyy7JyY
zMSy/EQ6XPzIPNze3Jx+LERqnHhanJyy3Myq5JyWxJx6tGxyvISm7HSC5OSW PHyi5OTG3JSa
1Ew6hEROpKyixFRClHR+1HyW5HR+7LSW5FQ+bFRinFxOlMSOvGRipNy21OTO 5IS65Nze9Bce
bFRKZOT6/Jym3Ew+fHxqPMS+rOyeNMenzJyi7CxWjGxulMTG5HRutMzSzFRq rH53tIyu5ER2
rNTW9KiczKy6vOzS5Ky+5IGGrLSSxNzm/FlHhOzq5HyT3ExmrMe63Nzd1Gxm rHS+dHR+5Dxk
nFxVnNTOxFRGbJR6NEQyfLSq3LS23FxSjCwqdPz2/Nyu1MS6rPTu7LTC1Pz2 9GRdrJR2NLzG
5KSitNzUzLSezHyK3KyevDs+hFROlERCjFxOhLyu1HxulIRutFR2rDRelOnm 3JzG5KySvOTm
9GJepKi63PTu3GyKzCQqdLzW7Oz2/Hye3CH5BAAAAAAALAAAAAD9AEMBBwj/ AFWoaKMHmKKD
eg4qSqjIoKINilQAKzgRmMWKBSlmxMhxo8eOIAtK/EiSowqNFlF+DMkS5cmK KTnCLLkS5cyW
OGnKFEnxpk+bQGPCtPjPzL9NmwSmbANMoAqkT5FKnUq1qtWrWLNq3cq1q9ev YMOKHUt2KjMf
ZsxgRaB2U9q3cOMalVt07tu6eNPmtau3b9y9df3KHSz47aa9dwv/XUzYL+LG ie0CdkxZcuPJ
ljNjRszMjI9/R1UcPezWs2m0qH2kTu1ZtevWrVXDlk2btevOtW3jXs379GvX uW/PFu5jN2/U
u2PHBj5cOfDntWH/Sx69uu3gZjozG6U9+6ji37eD/x8vvnz27szOjip6WIXR w6ezez67nT73
9Pe91/eRv77/+9zxl9553oE3YHoCavfffgGmpx2AD6qHn4IEHqhggNzpd6GF 3HW4oH8Veqjf
eRBumGCJKFqoX3H0sehiiwjGSN+ML9JnhixJJHHLIWXwUoYLA8r3XYboDSkf ekcmieSSSo74
YJNMIgnlkUYW+WSUU2KpZZZcLklkl1kSKSZ/HXYo5HZnjuLdmttlwwkrPSzS ow7Q4GPHPqad
JmKEAh5Zn5MROilmfV/+eaCgEe5p6JCLSghlo/ph+GCfh25pKJULFiipkoxq 6uWnkTIooaik
SqrdKsXsoc0wv/ACDQ/UvP/gBW6mdZYMBrdioCZ/8gmpp2dqyscrWr3yiiux aHVWa1rd+XDr
sxjkiZaRyTL767TV9qpstsYmg+2u2lpr6a1NopZWtsoWyaaaaLbL7q7sCmut tOB+d64Z9pqW
L7bWelPBLtpU4io+1Ewgwzp2pFWaGRhEqya59sZbra268jfxlN8yaSS++B6b Fq5SdjakxZ12
J+zI4Y5ybJVpGckyYcGqqSauMk/JssiQQRZzyxwX2mSGQIssNL5DA+1DGlQA wmqdsR5MwARy
JZNMzoQ1DFewVOdMbFzkfjx11mDLpezH0Wa9ddhSh6322o1hzXbOaJQjdx55 GJMPCJPkPYIZ
mMD/1bXfZXf9bFpSf1244bg+i7gZheNKeOFRf82w4VIH7jjjlyteNuZpP945 5OQKHjjkaG9+
uNeEj/7326y3LlcqrTI9QTtXEMDPDPxgQpXjfSPFeDJu4bqJ41IPD7zxSAmv /NSOO+572sIj
r5ZauCY+tfHUAy885r9PHrz21xMPvPfOL/898ti7pX5bfK9f/PTf/578+KU5 D//96+eP//S6
891+Wr3bn/4GuL9yoAELdDOGAkGAtw2MACl6kEr0pnKrTWAiehVESgY3iIFN VPCDUyueBjvo
werdSndIueDxKGhCDKgwhRnExAlLWEJo0dCCI7QgBhM3QhuiUIUkpEoG/2vI wRkScYUoTCFV
kqjEJmYliT9sYhRxSMUppsESBGNHO9ZBgDq84hWDaIYe9HCSTejhVhFMowrQ WMI04iqCxdOD
8OQIPDSiEVdtqKAcMUDGM/LRjE9R460CeZI1/pGMhrQgQXCFiTx2kI5tNKMZ cVVGOP5Rj9Xj
YyLVCMhOprGNlKRjI9loQ1E6spCARCUiyZhKVrpSIGqMJSE9OctX0pKWt7AA EgxWu9uBkQY+
yMgYVRBKOhqSjny8Ix8bRkZSLjMZxITmHZNBxz5G8yRvLGQ1+9hMPlbzjcac ZjerecxQUhKN
5ExnNtF5Em62s5zQNKY8j0lGc1LzncPMpzv1if/PfVqTnwD1Zz/x+YBbIAMJ 7ejiFwdxhX0s
JCPthFY8kYlGQ1JzjOhMnDftmMyOUnSj1ePmOPFpUU1WFJljbOEwobXSkI6z mMUsaUD76VJs
sjSl98SoCQc6057uk6cC9SlQ9UAEKlDBHjLgBz+u4It/TGQDY5yINguJCYFU 9aoqqKpTrDrV
rDqlqmTEKlbDylWyrrKQVPXqWcfq1atSEqxptSZczRrXutL1rmqtK1u56lW9 TnWuecUrYMXa
1sIS9rCGLaw2ITrGxg4TE328qkgjCwxMQBayeoBsViWL2cdqExOVDWtkRRtW y17VtCfRrGnB
qtqsRvYe91StaF1LW9n/1na2ts0tbnebWtJi9rK81e1th5tbxBo3scfF6lQU m5Sp9M0wroMM
LqLbuulS97rYza52Xdess0xnXs3iTjpK5KAJlXdCHjpvecdrXvLexz/the97 5VveFH3IvviN
7331a1/4qje/+w0wgAfM3wLD4MCdgIFqYPCPTjS4wQxO8IEVnGBmHNgHB7bw hH3QiQJMGAYS
prCHM7zhCl/YxBSGgYZT/GEJY/jEH37xizd84Ror2MYyxrGOb8zjHPd4xz72 8Yd/TOQgA/nI
RUaykZPMjBM42cn6gPIQTqCPKVcZylS2spafTOUsc9nLYP6yPq5M5i2XWcpY 9vKVwRzlM3f5
/8xwNrOc1TznONP5znYWc533jGc+2/nPft7yk6N8giEQ+stcNjSiB+1kRaf5 0JBOs6MXTelD
F9rSjH7ypBONaUp7+tOgDrWou0zqUZv61KgONT3CTGpCu1rMj54yo928Zjc/ +tatrjWsqaxr
Lr8a178ONrCH3WpiC7vYtDa2sovN7GM7e9mHXjWpFU3tKCua0NWO9KURrW1f N9ra4N52tTXd
5m9v29zYDre4wz3udrP73euOt7vlre4vz/ve8MY3vfet73EPWtagXrOvZS1w ZBMc4G0GOKoh
rXBvo5nbqY64xEf964lb/OKeljaxS13qbqd725b+eJo7nulpj9nhJv8PuaTL 3Wxou7zlMD92
tl/+7JjT/OWzrjOZ1Uzmnls552/+edB5bWWfE/3kO/c50n9u6z47HdBPD3TU WY1mqFtd6lef
uq1XvemBJ1wfq67y1+khdrIb2uyudrTYz732tl/b0WqPu8jXvmuM213iFb+7 3iWucS6vWtp/
PwHgwS74wqua8IFPPOILn3jGO57sjY/84hvf65pb/uY2b3nTM395zmO+5oXv 9N5HT3pE9zvf
qOd36k8/ciyz/vWrj73qzx3mv9PD9oK//e1zn3vd+/73uuf97n0vfNwP3/jB P37xlZ/4wJf+
+Yt+BpSfoQ/pQ//6iNa4PsZACA94//vgD7//+MdP/vKb//zoP78mxiB67Lv/ /fBnNPdv4Ij6
2//++M+//vfP//77///+dwO2MAbxV4AGeH1cpw9yQH8A2IAO+IAQ6IA3IAdC YAgWeIEYmIEa
uIEc2IEe+IEZKAS9sAz6UAW9QAwgmIIquIIsiIF+twZ8EIMyyAfdMIMzWIM2 mIM6SIMxiIM3
2IM/yIMy6INBiINEOIRAyINrUAU72IRO+IRQGIU72AVZYGhDkAVMKIVauIVc +ISGdwIwmIRS
aIQ2eIRNaIZCWIY7iIZJyIYxGIZdGIdyKIVHQAxVQAxHMId6uIdNyGhwaIMA EIiB6INuCAAz
KIiGGIQ5mIgyaIiM/9iIfPCIkTiJkliEb2iDIhCDmYiJmsiHniiDU8AHXWAI +mAIWriJqNiJ
fJCKM8iKnCiFm6iKscgHhWdoYUiGPFiJbQiEiViDjGiIRIiLkyiEwLiLw5iG vyiEbLgGoRiK
IhCK3RCKXcAH4sAH0BiKoqiK3fCMq2iNmTiNztiNqfiMmZiJ27iKU0CONLiJ zpiOXVAFpGgI
3DgF7SgC5IiNhIiP1kiD0NiN++iD04iOPXiPA5mO6oiN0xiNBUmLT0YPf7iI SPiEj5iMT+iL
kOiEukiROeiDU7AGItAF9tgFAGCPJAkA7kiSIPmRKgmSLLmSI+mSIrmSHwkA IpmSMxmTI//Z
ki0pAlWwDPH4jDYpkoKIkjIZkipplDKZkjsJkuJwlDHpkkO5k0aplCLwhcwo hjgoiYLYiIEY
g8V4jL/YlZE4kReZiGLpiFtJiZToiF4ZhGvQBXAJlwDAAXHJAXP5kXGZl3jJ knwpl13AAXhJ
k3G5lzeplyJJlzVpmH95AobAAYYQC4AZl3fpl5GZl4MJl5XZl3upmJY5l5KJ mDW5mX0Jl+Lg
hxhJjJCYjBOZlkTIlodYlsPIlqqplmbZljn4liKAmIEomYJJl3SZm5hZl8EJ l7nZmzQJmshZ
k8kpmMoJkojJARzABj+JmMWZl8kJnM9pncP5l9wJnNxJnL4pmNX/6ZzBeZ2g WYv6cIsReYxg
2Z5kaZtj2ZW9mJqw2ZazKZu2OZ8y+JbPGYjh6ZlC6Zlz6Z+HKZe+WaAFKqAC apeCSJcDapcM
mqB0WQWMWYqxgJ0FipwNGqAM6qD+SaAcepgEyqAjmqHfuZsk6qB0+WUPCYi8 SJ/2iZr5CaOv
qZG1eZ9qGZs52JHl+aAD+pdzCZ0Depw/CqTcaZd/iaQQuqAPCqRLuqRGqqQU Go9HGqVH6plQ
qqQ/qqW+KaQRCqVWqqUoSqThqaShB4ZqmIuvGaNsCp+12aY+SJY36p60yZXK uJ9J6qQ+KqSI
CKF6Cp0QeqBNGqhB+qQquqdBmqh0uQzS/1mK3FkFKnqkfmqoiqqohNqgWPqg XsqdWEqoXnqo
K+pl6gmRhyiW8WmbviiIcbqVGSmjZxmfc/qmuviG0JmklmqpgFqomjqpXqqr udqrv4qonxqk
y8CYjgmotgqovwqsnnqrgWqo0Fqoz+qpz6qpVomN64mLhLiH25qGcoiGjIiL /Amp1Iqru6qp
/qmsgQqp6BqtT3quQdqT9BCPkKms0nqu5Zqvvrqvy/qpHUqthmqaYriF3WqJ 3hqF2hqRhTir
1rgGgMqu0Emuc8mu6eqrVfChHECuGQsAGpuoldqgFxuyHAuhF6usyzCvpfiw EdunfOqsT1qy
MNunFtunkEqx7f/ashILAOj5kN16hG44sGuosMaohQl7pzbosBoLqcsQsRyw tBn7tEyrsVCr
rFKrsk6rrlibtSTbtMtwAPHItFirtEzrtFWrtWE7tWabtWKLtsr6gkS7kesp tAf7tmkojHTb
kYB6tWkLnXrbtCbLt3/rt+rqtFdbuHnLoHp7soYAj1BruHsLuIIbuY57uJAr uZSbtYSbsVYJ
tHYbt2nqhD07tGNojJ37hlVQs6ebuqq7uqzLuhl7uuDQuq4ru6kbu7Bbu6e7 DF0bjzX7urQr
u76rurZbBcPLusN7vKsbvMl7uq/LAQILtHCrgz8LvQg7sKU7uh3Zk8vQk9y7 vd7bveD/+73f
ywbcS77iWwXmW77qu73p277rywYH8AyG4JPey77he7/ju77oq7/n6772e74A jL87i61ya4Z2
K4w+W8DUS71FW7T7uQYQHMESPMEUXMEWfMEYnMEavMEc3MEe/MEs+rlBO7qK GIdoOL3Va7R1
W8ILfIafaLAwfL1QiMLSG73dmmajyoX6yIU07MKgS7qea8Iz/MI9LMQs/MPR G7dsSIRg1qI1
+MRGC8XByINkuK1TXMVUvMI2PLdJDMRYqcJYDMVAmLBhnMVTPAU1iMZR/MU8 iI0E/IRqHMQH
+7McmYOb28JcnMcizMVuKMYK6cdIGI1PrMZY/MVSrMWIvMcn/zzDbzzE/KiG ZBzIiVywCZzF
P3jD0/eHVuytB9zGMajGBFzHdtuPlVzJesy5clzCnbvKMDzGrpymZbzICZzG rhzKoJiPhrzD
+njGMbi5Uwy3ZSzJr0zKEUnIK6yQuxi6h7zJkXzIr1zIxyzM0GzIYFzDYizM l5zNhbyt/Yit
m+zNZsyQXabJrnzNBjzH2ayIi7zH2OrGTtjI+xjPIwyKn3zLxfzJ3RrHbcyR pszP1kjLknzG
syzCAL3MlqzPr2zHCcizb3yN5VzPBn3FlhzOxCzRyRzOytiPF+3QEI3Ig5zQ kyy31TzR0zyE
+myE7syPBQ3O08vMAc2DIQy0U4CIbf+Z0qf8zzuI0BcJidcMADLsxV/5iBbd iKwszCftyVCs
0Vk50/WczfOZxqX80LB8sIRc1c7czgCNrWd6lQob1JNYsFQMztn8xttajBqN j0xtyd1gkp5M
0uFqkkONi2ltzpxs0hf5y4+81mvcmmS9xqgMyNI8ugONg2gGh2WdhGmdhjrd 1kn90Po41wbr
00Eo2UFskWoK0ggciTj42PacrTPtz+sJ2W19jWb9yxJ9zdRMzRH90j94x/jc iOBskoEIjVsZ
jaxpqmnJ04bI1LINjGbZlXo927zo28A902cZxzTtlWfJ1hYJ3GnJqsBo3MhI 3NHdgzTN1s79
3Mrt26HYixr/DckY/cgTrYO7DN4y+LxEyNRiPIiUmMZsaduTONNp/dn8aJbN 7dO8rd5r6ZWb
XZvwLdm8DYrF+JUBHqc6ao2yjeAKvtvzyeCX7YtqnOCS/d5q2d+xudjOPM9R Hd5DC8U7q82J
iI+zSYOuGYndnYvJbZ/5jaP1DNdf7ZUnzqZrrd96jeDdLYiJbdvqjYjv7dvw mZW2qd90Gt/D
KN/YzaokztovDdjjzcqmbYMxbYbF6N65qN8J7otArtlCGOEr/uISnsUUieVe buXsOeBeruVA
zuDrPaNi/skTftkK3txZaZHNPeYOPtqvndJ6vtl53tRx7MZZ/dpb7c39yNYx euKG/+7Tu02J
3T3fXzmMNR7ijijfMQrhZYmNk67iVc7fkm7iQ+iaiy7baAzXom7iT4zdmE7I iW7kiI7pObrj
+G2Eqz3rUm3QGG3rhY3NsMrfvJ7btz3gpqqmFknmE96Vjv7RpD7bqarmbp6W xj3b3h3fxS6r
+UnZZcnepSqfyo3gW8nUz/6mL67EbLzNz1zuag2Ern2D7czY607LAB3PyPzH 8szZ4i3uBN3F
5yzSc2zM3fDE/k6D/97vAD/wAl/wAe/vAFCNBk/wzyjZm0zS4U3J2TrxbIze D03udB3Oocva
dA3Iwezxd/rxe43ZL7yFDGunn2vKSSzxbOzRM/jhKqzKNf/MwBOv8lJs1Sqd 84Ks8zi/8z7f
80Bf8Bev8URP60Zf9Eh/9Eqf9ETvtvTczaAN9a/9jzhd9d3c2VYvi1rvj6zY 9Vvv9Vz/9Z04
BdWYjt549maf9pmo9mi/9m7f9nDP9mm/j81I93Zf93h/93qf93y/9/voy1Qc izWo8F7cwIV/
+Euf+Ey/9Fps+H7t+JBvjAovAoMfg5Nf+eeY+ea4+evY+Zrv+eao8KJPg9X4 vHsc9qgP9qpv
+apYjagf+Y9/+LE/+7Bf+7If+aid2YrP+F640NA4yJu/+4s//MJf/MR//Maf /Bx+7jftibQu
zk7WojS4ANRf/dZ//dif/dq//dz/3/3e//3gH/7iP/7kX/7mf/7av9VmPIsl 3/7u//7wH//y
H4e5Ts8FG47FzI3cGM9qn8bsv4kA0YUPHxEDxQ3k042gwoQNpyiEyOehxIYK JzKMmLFiQ44W
NU6U6DHkSJAMS45MOPEiSYwsXUZEyHCgCIUipmzsuLHbxYniJhbkiFAoRT4n 6J1AuqYgxps7
+RyE2HTK0pw6OzZNmZWpVqwwWzp9OlDhwapOuwEdKzMi1IZsuyakCrfj0qZU x26MexbvSqtB
xQ68mVWoTMB/hx4+DLZlWaQn9J1Yg3AKWbYWqdLkWHkhQYcM2WLGnDMi5qlw e85cm3kqQ4Fk
FQoMbLOm/8qwf0Fvbhi6JsSae2Xa5EgTpGaqZAXyEYj54OraoD1LpHlbuPKw Z+8+r23c4ECj
J4boW9NUI3CNHHmKlarR7NudMLUjT7mUrnaIsv+yNV3fLGe9Zx+STy8hnyrS rbaE+murPQHx
cqi63FbK6C2rLNLsL7B0Ukssu0ZSL6HGkhpKpbF+IjG0g3wq0KaC8CMtrINU FMmrBr+iqKTJ
SLLPsNkswmm3zYBCiKwghbqxMCBnIhKt7X4zTEgnw6IuudJYC+s0uPQCjqAb hbuLORWhLK27
xyKrD8rMHlwLq9wQ5PEggfoLbLTSliuTQBHluqvHiqZkT7D1rHoTOJ/8e+o/ PP9lk+9QueDj
T9DtkKOyJTUzigvPm4Q0C7Oo+NNzP4iQ0mcIyCTj8TX4Ln3wshsHnGpVLU2C L7pWNR0JuIdu
HI5TrEh0a0MHYaOOrQFfjanTvy6SVCQReYrRJQ5HepEvT1ey6ydYfeQxOQTj Eqi7pOKUbwoA
xh1XOAd30hSAushVt62FaG2KXJtedPdJc9F1EVXzXpztVEbhzAot8uSKc9Kc Cg5KRh2vEk3J
ggbWy6cTocvXtIfji5iiiTWbDKscGxuzyeAACC63zW4SAYCJAUhOZf4Coyg6 AB4GQKGan6KU
t7ZuhqgymsTR+T/9FryOX6GJfsi6zVB8bTflmqbOOsz/ujAVKufohE/BuwbW MKKJ3txTt7qa
BU43+zDr7rvI0Buxm25cpnqnQce2ieSxeFZXbpyjMyvviFmmeEB0bxJIoJkL Hai1mwjPWmB3
Lw3sTX0JZbQhyaOiCyOuB+dqQ3w3ZROo5Cjyj1B9MXXU3SoTZ70uVBMl/MNR Pd4675nkPYtc
5FRudeapXE553JvGfRf4W8sV/uYuag6e5ODFvVtc5nVPWSKoSrsy++y7Adu5 eU1e0WQUH5y4
N34NmjM+KCmELiq3aXVbaa0HTSmt+rfnDSr360f7qKSAWg5JDueTw72NDwUk Gcngwi6P/W55
95Le4ar3NsMBJYHAURfgfHfA/5QVxHcpmxLFOFcayM0kNrsaz/1KSCmrXC8r rnnhjHDTLIcE
sIZ+4pRTbvQnWwUMXG8B2ag8Ep2w1GwiRkzZ8tDFMsAZriYfZNcBZ0MXEBpw eU+x2/KUqByS
XZF7Nesiu1TmNkjZT35AExAZgWaq0Gjpfg4KzuJM0kN3KSsuXxPMmyY2Haeh 6y5ohIrEsnei
3UitkEATlqnSBp5iHUsch9vdUi6YkARaDoEPcRkFC4gnDh6wguLC4AEfdDjA cVCDdHwS40xj
wu0wLipAE9qKnCIx6witNfqR1R+7ob+CUK04OHPhpjQFrk21ryt8uiHpFkU6 EmZNdmQCDB8P
yJwuev+ymkxklLrqdhCS/U6Ug4OiN704PSYWDow7CSMYKWmdmbWHS5piS9xw djTLMERsqDEP
HOvZmSrBCmuWI8l2BLlG+CASoECjyV0KlyBtpdFo1imf/IriP8gU5GiAbOeN yPWmjXpSQOwK
FEiZdyVyWe2Cw1OZAuVFSW5eUJsHLBco1UcwA9nql0qjH9XmaSrrzNKM1cmc 1dx2qbYRjUs4
AZDG1IQyqWgIJOpbnPoU00z/iCOIa6sNsDzWPpMVqTfM+SoMLUqrsUbKJ7A5 a9ZaY72O4bSt
wnFTQtBaukHx7VT2sVKOQAOSvVIErdAyoT139Cj7/LWtg0xTTxHbFqENDY3/ bUvo9ibqHfCI
Z4fKWc1l3yq3zFptsx2Dq2nqqrfPEbE/A6qrXDy7SkK1ljyvdd37MhYovcHS apAqFEQH2bja
kraXkO0Poiy2yi8RqrhlmxJyw6Wl5R73Ic8USrAuCtQ/7laoLrJudg2J2VrC CKj/ieV2xcs3
8hpyYoorKmmE1RNrWY+x6WVfUelHGqWhN7SjXZXQ8lvLE+m3v/zNbWi7dZQx ATC5bpwOgvFV
tgWjrMELKQ2DI8y4ta51u//5mVxFG5aFdhg+HgZx1lYDHKqNmHB+JDGKT2xi SLG4xLJqcS6D
pd0Z45S62LXxdcsXJVCJCpqZfScZS6zYIUe2yEJ2/yeSG9tixQ6VjE0jkIKY o7/66ezJVsby
gbT82MhyWY36MWOXwYyzK4X5y0ibW5pvpWbOtrmtb2YznNc8Z4V4CzJxAvDG sKtnPu/Zz30G
9J6Tayi65id8gUb0nxWdaEYv2tGNhvSjJR1pq4JqVKmqLqUnvelA89EmXRix Cfu7Vk2XmtOn
NnWqUb1qPS9SKYmTmhVkPWta19rWt8Z1rnV9a0PIutdW+HWvE+HrWf9618dG drKVvWxmN9vZ
z7YCdI8lECsgxtrXxna2tT0TEXTb299+mLcJ0u1tl9vc50Z3utW9bnYPRUyz 25tCEtFuem/b
0o6RHVK+8xjK8vtI9QZ4wP8FPvB291iIXBVHtQmO7VwYIBfzgLgWphGJSNjA BkUogjxm4hhR
here/Pa4wU+wcJKX3OQkt/OrLTYFhZ9cKMG4wAUQgIA2tKIVDKgHFmpQgyVo nDv5pmzQg/ih
f7vc6EdHurstvbYRn6Xl7HZA1KU+dakjJBdXN0DEpzHxiwcj4xvvzlEo+qHH hJzfSUd72o/u
arGQdt6ICYcVEjHsuSciHIhxwAH0fgA2sGEZVahCFzjgAIQYoRs72EEXEo/4 LkTB8VE4BkIa
I0Z6AKDyR/nOhzJfdLV33vPshm4fRfB0obx9KKYXSt713ve/A54D4iD8QCJw j3vkAgNvcEUu
XPH/Bgy4AgMYiDxBkHL5fAMg3/xGyueVv3x1p1ypbiI9Qkw/QNQjJO9997vr A9CFLsSeD7oQ
RvjzsIcgLCEI5BfGEoQR/KIgxfhhN4rl4b9vpHCe+ffH/8/xDc2zRCf6A0kE 7tMicHiE6huI
vKMHv2u9ANg+EfC+CIACKECDCKTACoSC4BOB4ZO/yTuB9yMXkcu/EBTByVIb A0OR/+ODABSj
Z5i3BeADF3RBB0jAAPg7DmDA7eODB9SFCNCFHlSCH8QBHBCAYzgGAZA89/vA Drw8+SO+xrC/
EYTCpAu9kPgZFEwEDuCAZQCAZXiEXjDAHOw7BqyCGyQL77uGBkDDNFTD/zS8 BrCrPI6Lvw7s
QHYJoii0Q897t/B4je9BQSt4hHPoBQCoBj/wgy90gL+7QQY8jhxEiDOcgliY An+ARH+gREqM
BXI4Qjn8EMvjRP+hqO+4w1BEO4NjuugQh9GztkTwg2/4hidoxW8wxCoAhzFk QCFhxIEggwaA
REh8xF7sRTIAO30wPpAzvmLsjmFsDFFURqNLuaXgLxSMu7mTu2G7u8NwAA4I vC4IAFu8RT6g
hQaQiMURR4qghSMcAuPLvHNUwjmUv8w7gSdcxngsuKWLprPoAlSkt2sUQG7s xhzwx38EyIDM
RKAjSNmRx4McOLaTK775wqFwQWy7xlPkPO9Lt/+CtMgPQciMrLdn4pWpQMFz o7qQjDrQu8iL
1MiTXLdmhIt7dLo7LEmTRMmYNLerAoyz8AcR6IKPRIiHlMme9EmhYLsT8z+0 a7iHg7hp0IKK
q7gi8LqfdMqSm0KWFIGE0zaerDeYi7k2aIMNuLmcq4F+6LmnFMuEpCilICpf 0slyE8mQtLqr
g7h52Dqu67oiGMu63Eh6rJrJgEa6qzsrqMahUL1HOIAEbL0oGLzCOzzGWzzF ezz2QwgFEjjI
tMtlDEp7nEp8PIwvNMTVYz1Z5ADu8z5d+D3b4z3S9L3fc8yBkEyAW83JDMUp PKspyMlUfMzE
2cwDaIImiAbdjAY1uEf/7zMCVxAGVwgCYSjO8yvOPVi/w2hNemtO14zCZpwM qcTM0xNAllmG
A9hMNsjNJlCD3owGcYA9hNCFCJxAC6xAIxyK1tQdUVJNUSIe1YzPBHpO6Mw/ mqwPqqFKxFBB
dmHBFwTQGKSHZeDN3lQDNThAhOBBHvRBIBTCIUxN90SMSnrP+ZRQ+nxP+4xO zGOkeeEenLRC
DgAHLczOczBEv9vN7zxQBO3GM1zDF22ANlxP5tQdyKRQ+JzRDNXQEYxKnNwl KzyAOTABQRyA
QsS7v9PNFT3QBB0IR4yFWJBEKJVESpwCGRWK1bTRC9VSLK3NHeXRspQNceiC U9zPzFzFV3TF
/1gEBxVVUiblg1zkxTidgl6MBWDM0S7FUZja0trMUi8VQfwsKL20tmjkS7/E uyrgAANt0278
xnB01DklRxptzyjS0xtVKQvVUT/FP7abl3u8x7TcNn3kPs5IPYQIyFMFSE1V Vf0DkdcQU/EE
VavEu8+kF8Bc1Vs9N+k8RU+dzXxcy6nD1WDVNkClmtYAVWFFVpPj1OnEyV7F NllN1milt6jk
vqk8VoEryreUOIqzOIzzOWm1S+nESaAZ01gVOKycuZrrSp3juW8F17Ek1n28 Voj81aobiKtr
OK3jOqb8unetS079UE+FxmmcRrvDu73ju+wLvMMcCMNTTMVLvMeDPP9rq89y E6NMXThKTbeK
9UlqfVUr5M+D5czWQ9TxlD3aM03d473TjFCM3VjmjMw7ldBt41inbEZ7FNNP pU3VXJHt7ExE
3b7uI8/wE4bxKz/kTL/lnFDnhNmA49J1q9mfpEm5GtNyTcXr7AIC3EzCXMAG fEDzRM8KbNkL
xVT3bE887dJJJZ74hCmV0tO3ddn5ZFu1NVsLZVuUZDs3yVlxaMj+JJf/hEEA lUE2oEGgVcRu
XNAe1IUfVIIghFD1bNor1VLJfcyztVSzrVA+ddunpdw+5dPMrVC3jUmOJAhP tdZUxEIS7cIT
JdwAoMVtdFMXhVE1tNI7pVRLPduZDd0azVD/+uRd0EXb3r3d371czz3JPIQr 7hPTPvzDQBxE
I7VGREzERTTDBuhFSYzESpRETOxcHd1c76VcyX3a7w3fG41bjM1S8s1T3c1I UjQIMcXJ6iy9
M3XFND3UWSTDUsVFXfTFXZxTSLTTtAXfAZ5Z9txTzE3fzw3fPE1g0C3e4G1f MCWcquXbQSVY
afzL1MNG7oNd/fVGcITUEI6qclxPydRYE87di61b0WXhshXdynXhuZ3UFSbg 48XLcVXeeb02
UR1TazRVVEVVf/1XDo2MTv3Yqsy2iCQ3HxZiYQ09HNZZX61XimziVUVe5KDg LmjIKuZidHPf
qVBeq802aO3iMuaO/7JcDQHkvi0muWw9yqS0gaVsSjOWSZoEYxGgVXMNOKy8 AK3kSpzTObB0
VzrWSFfrNu4JYx22tikeyXt1y6PcuoqbS0Ie3Q+JjKl4VTE+jHDgSwwW2ZEF PHBgWD5w2Idd
vMac0LuFWkp2uTy0HgF8vb4NWWvkzOybRdAkz9G8PQwwzd8DvsiNWmwLZlZO STiMjCzW5NPr
Ui0WWa4FPK8tPOEkTuM0TvRTzggdZm3LZmL24rL8sNfjPivE2uz0WZJVRJP9 PrAN2wiEXAhu
WxiWT/nc3G3m5mGlx2aV16tdwRYM0Bycwa4NAILQQQZdXAcVAAhNZc/l0hfG UPatZ9Aj4v9D
HlNa7VsRJdEDMFG88zsGXIYbPI7qnV3aFWZ5ltu1RV93fujms+SVpGAgFVIi hV7AXIaOTkQh
qd5HhNIntUQqrd2m5VwK/emUBjjnm8697Vv6fUU11cbDtT6EgNP/hWo6DWA8 ZegDbmCHFmov
BpkixmPBg1ULlkZPtkZE/cyAttWBaFQRflRvTOgrlWGTlucazurm47chOGZE 5j4OUORZFUBS
beqBAOIgnmtRDLnZid/PlF/EIGMN7uGio+LB7kma9FQOwEm9rjdGfmzIjkkC 8zHkaNYj1mxC
hi6a+MzS1uOAA7fUXuLQjk58GxVezeGkE4EFoO3atu3bZu3Wzjz/pcBnymbm MRa426btUCFu
x1js3F6+sSOTrsbjMoU6Rt5J4Zbu40buz7u3Y67s17NsuLvguctg63uGZ3iE Z+BMWRTagVgA
kPsOd9SHUCHjAYDvAeAD+RYK+o7v6iY4OByVqazaZC69WQbM8RZvviPZUV6A 71iAE0jvBfc4
eoBW+h4I+B4K+YZwCMfvu2wMs6xswfvtzHzMnsU78RZM1hNlXEZvfXuMdES+ Bfg3C49whLDv
C184yZ7oMXXu0sNarQ3xEWeDUFbe2JvtsQM6Bz8MF59vGH9xGSdLysLuvBY8 cd7nfo7B8r7l
UfW+6ZbuFi9yJI9wCVdyDAeRnKXs1wvR/yzcwtU92L4DvGzUiyv3uDfvOFEh 8glHDAqv8y+f
VgJ77d7u8KHwQ0AUREI80dYDh3100wQvyQe/cyM/cjwnSY87ZnEobf+WPqS2 X2vscfMe1b9+
QbGDP0+f8/oW9SQndUZ39HJzvsnm8IYkVIL97gNchg32JQ9G9It87/vmchj3 8lNX6f1DDjHV
7htXt2ss9Go96xfEctzm9c5jO1X/TDZG7ySm1dXm9GV3yZWGZa/ea2uEbmt/ TTD9bIr2diem
x3ssbUk/bYBT7dQe97Rrdid/crRL9tuGx3ZPSGzvau1O93abbeF2DOIeglC3 91YGd8Hb8G0H
zG5H9nmn7Xof+P+hLndzH/O9LFhq3HERT9hQBvIEh/PCNooHj29Tf/huZnIs 5vDPBFkPt8bw
fgQen8VCv/KjSHAG53ikYPE7H3mIz/BxO/ftVnn37HPwbvmM1/SNB5k41+/F Fvmcz1UwdXLT
vlruw07tDPHy1nR0XgAhzzcH5zwXh29i0HX7lvBdz3kaP3lhB8Dl8U9+DlwH GHFCF0AHnAmG
r21rs/AKp/MYb/SyJ+Jfx0LB8/nTs+gtxOhyRtS+7sasDzoVpyylr++Q7/Kx T/Klt3boevp4
588gHdJqKFLW9XHlPfSXdPxcL/VG13u+z/BmLW3KtkJLh8Uj/XxbjPlP//TR L32813v/yl92
yc53dAfrQn31HPz8Hub0WrdI24/8sLdz02d6EmSkvJ50aA9VEUV8Wqd76m7+ edx5WNZ3JIbI
z7xHx87++2tG6Ad8hE89hR9/6y531ff99XfNZsfCvw98a8N+dFt3cIP//MZ2 YD9/2QaIBQIH
EizI5yDChAoXMmzo8CHEiBInUqxo8WLEE/ROcFwjoksXDhxCirMScQHGhgUF 6hvSUt8JfShT
0qxp8ybOnDQ5xjyxhg/IkCE5mLTp4CjSpEgRrmwqUCfUqFKnUl2o8YTLnyBF chBHtGE4K4kS
iR0bjqGDZ88ePTtwgA2bKuC6OGAKM6ZLlxz1tZyJcIBDwIAf/w6mWHjhYcQK E0cc4Lgq5J08
fQIVMZJr0YWJGG5e6IDt2rfLqpDmUPfgApcLTiyQ6XqIRr8HGf+VSJtwYNw0 C9++HTny1Y4f
h17OrLAzHwAi+IhDnjDto0dv2SwDN5IuU456t99lvTwh79q2L4afDdH3+PO/ 1yvkCVOr0OIN
EwUF0AXcI+cIoU8nPbeLOKeJsMBGkxkYm2LmKSgYH4/N5thgEC6oIIXlNejg YxGaJxhvEoq3
GIbosRfVVVkB5dVlX3HWBQAttvjMZijJyIcDbsElVxVB0ciUUyt992F5HG5Y W3gaNggekBUe
eWSRGlr4oIUMjsiegT9dJ1JIxiWUiP9IywCwzCO96HdQjTeSBlI3y53GR2uw tYQXnPTIRiST
dA55Z50MJqbnkn1K6SCeUva5GJQZTkllgZRtNZQIWiJkxSPn9AJANX74MSaN 1PkXlDhkZnfg
gXMOKSipfprK5555JumknXVSSOigsR5KlXuUpTiUowcl4sc33zzh6zeYOhCX XDrux9RGyV6l
rJwNPVlqkeI9meSqE7p67WFBtjprVSXqo5VXQ3WBKR9hjVWWFWd5tgwHOXaR 5nOfgjqZqEq2
GqGHHpqaYKz5KlnqhYBCCR6gInJrU5VAEedVrhY5wMF/XfzoKWo9GnTwoQZj PGJwPg2XoooP
1fvcSOKIMDH/xRurDKLAK2NcK3xcZXmTUjUf5TLOOefsrZXxidSwzkELPXRF CW8lEsMnQXUy
0003TTTUUUvUsUdHYzalxQWhLDXXUcOs8GUzQzTyRQOuFNNLQzTbNdtS88wH yD/TbLNSPGYt
0NZt6+2y0fElzVA4ZI11rroKQbeWdGaCI+Bqb6Y92dof8stQqhXp2xismGvu 7N4IUf0xVyEf
xxlaakU3HTjFrkkga6y51jhHC0zsG3oa5/YqkrlLfhNttkP99aLykX4QAAeN W/rpioPEuHtu
Oh87v9NOTt7mBxFT2PVQ9d55exuZGLfoW9bXxTIHCNtWf8UCuHqi88qJcpR/ hbgk/6sFX977
AMQ8SLD88jv5P4bslK8/BbBlOutb2MKHEPq46EUxYhMEPyOaTYFEBIy721My p607QYtVuNNX
tJDEJ0IV8FTbclUHcbez7lQtdHLjDMS8VL5zCGs6o7lOF1LGOu5gBSaqoZyq /rW/e+0rQRAy
lAixJaFohRCFSwxUEYP2po7ALT5i08wB5mACSg3gUmhRHkg6tSPUzMtA9UJV tbBlQhVaa3dG
MpIaoUWnEMqRjXzbi6Li1rBd9epXvxLWaNQnRh0ya1nLGtmzBDihJmZLWid8 oxBHJcARonCN
ssLZRt5kJctgSYEHMZfgyFK451AQQPEiYxl5gkg3BtCEQf+6XMAIlkjdHdGV IBxhLZ0IR98d
qkof6eQLa/KwiHnGbnc7GC+lkkzuMQSPtiLOFR1CNjJd52TFhFouMbZMZran h88EGdAoQre6
cbOcXWtfz2TmSXOys50UcWY6QxdO1CzNafbMmzvzCRU42coy8Znn0jCYQX0S dJ+TaaELATpN
izQlbTCRSUEjmpOvJTCaKRlnUoyZNYlytCY8mwIn5QkWdA1ulPsxXfLYkDrT 2GUvebkLX4Yg
qiMyRlC2yeZ6ttnRhHHgl8LTzPAMB5rEEcs6q1ON61rTJgRlDoh2nJxOnTq9 jlrkc9AM5uiI
t5zmIM9GcUnd8j7FQ73EDn66uaT/VNGKkd5QVTI90Yoe5zM+/JwvcYF0V4AO MqD2gSpyuysU
k/CFL90FdmBDjGVhL2RYJPrLgG19262wKr4GAgBGEJxRjWxoHR2tTqDwA+Ec I+m/VtLxVB5M
Yhzh2NaDJMyfndxjl74UphqayV2mXJ3jnvcmv6qQiaLtbaF2WUtGPjGOf6Wq VdW5TkhJilKW
EhYYc6jDVKpyqr61JHAvqdo1lpaRq00I8OLKGV4B649oCeR/4EVIQxaSt7K6 bhOz210i7pJ+
lowqMyErLskiBJToMimZ2IXXQY6RTdSFHsvsx9jFNrVC9vOfvQTrQX89VaI8 vSpAI+IAcBDT
cBq12HdD//yQnlAxgfxdyEIfhjSmnVLELq7JFL/52rlhdE0vvnFV8YhQ4uSq Az7+MZCDLOQh
E7nIRj4ykpOs5CUzuclOfrKPR5RJ2MTzpwmBMpazrOUtc7nLXgYyxw4KNh4z 5MtmPjOa06zm
Iof5LlYKnUUP8mN65iQYF7hzG9qwgVYwoB5YqEE/liAPHLtszlTy5ibBWeYo S6TGNztILiI9
j0lPo9KRsIENihCMIhB6ZYZeDzrhFrq/KeTH5yIcWtziVfSy9CBG6MYOYt2F Hcx61lG49TEW
UjyE7FrXyYlIrx8SbIm4yJyf/g084ebaEx9bV6mejqbAip2D6AIDGMgFBt5w 7f9su8LaGMi1
QoI9bF7/GiLjTsi5gU1uhqQ7aM2GDD/frM4eM/o7XPWMW+hBnUAGQGJrMoIr hOGKIAiD4EHY
A8H3IAxwo7vh7C63Q4rX7nYLW91ce3e3xAw+encgjOQzX6rhctcA9Duv1IYC FNCA8pWzHAoC
8PW6k9Mi4pW72OGGuMx3PXOdz/zXPY85unv+c6hhnFY6FvVlSH1lH1PWsjNC iQP0HQB+k5wP
FkRIBHSRdV3oQglexwEOBCCAYzCc15SlOc0lDnFxr7vXavc5uYUe7p+7HedE Z/R6ICveUvs4
dctgQ6SguwySD57k0l3TNRqg+MUzfvHXgDnaz672usf/XOc3h3vage5wyXet 6FMxGpw9+eNz
VKMXlRpArhywjMKTPACDRHwDphCLWPhj9v6o/e2n8PjLR/7mb8f52e1u+bpT HubDpnjOPC+V
q7zHtWReyI9r4Ss/CqtYrZduysjQgFhMQfbd5773Y0EGyNc87phfu+/Nf/7f s733mb843pEN
pzVMgThdEb2PTy1KtFQBSwG4Jh/QQgPwQfcR4BQYIAEGIPm5ndzxXPu1Hd3V nNyhndmJWwRK
jfKRSKKk0/PxXQdMxMPoCMqsSQ6UoAmeIAp2mspkoEG9VRXN26J9IAQ9RAh2 ytbYmArCnwzm
nfd8C9J14NLtIEQ4Gg7mYNSw/6BOXBhXKB1CIKER6pMT4kRy2R/H0VlFLNQT Dk0U3kR4JVAV
ZuF3bSHC9GCVMRujYSGKSQUGDEMMbMEfSEIlHAEY5oQYepTGdRITyln8RQUR KsQeVAAFlEIG
hIInYIMbcMEc3kQd7sQGvqBIQd8ZXkSKqZoNnUmrHQQGJAEfxAE+TAA1sAMd zIIbyGFD2BxF
IN/v3cTxXV4DlWIpTqBDLGJKUFQnxRkfyGKjqZrIkUb/TdtBHIE37IAOnAI+ fMAn0sEdqIMr
UiCxmZvd1cQqtl3DRSPvWV4s7iG8kaEjXg0kyiAaKsQkwoWm9F+/+SIfvIMg XAINQIMqGCMq
iIEywP/DMl4EKj4jTVBj+fEeM2qePTYhNmYcT8gbSeCfEPLhAejb6pEGyZnM mqyAQ+IBRJ4B
HgABRWZCJqTDw+naBLId3TUg8QxdPjrgR0rg0Flj0Mkc+u1jP+phQWZjQG6j GXqjJF4WTUKd
1N3Q9RUYHwQCCnyCF0jBOIyDF3xAGLAAC0QcSL6fBb4f3LHf5jHl2zmlNLIi BTLgBTYELl4E
LXphDFbFsLAByVVB64lRQ+ICCpCCE5CCNEiDEziBKCTAInSCM37kzjEj8bXi 5AFdXjrl8Oml
SlqjxOHlVGLlP9KKNm5cV84gVKieWLZevx0LQvQBJcRDCNCBGIiBO4ABLJT/ QAtYHPHZpfqZ
X/E15fqV32ia5FQWH+VRXFbm2EuqUx7eYmHihAPw4li2GB8cgTMwQhj8gDIo AwmYggRAQBXM
o0nyXDWiX17u42qqn1S6n1JWZeWpZBByTCMiZjdaoU6E4Eg8Jm7yQQo4QyFI wh2YAiIMJyIi
pQXC4nTmnFImpWpuJF0+YCtGJ7tdZWLm3dGpky22Jg1iiXp9Z26CAhwgowKo AylCo9QgH0aw
5mwu32HaH0FqZ048jMlYk4dFRlIODYNWBPL55zvdYdJNKFX0YSKuB4hOBNXA JIl+44l2TopO
zX7WIkGumY3eKI7mKJshSg+VYY3qKJAGqZB2WZi9/yYe/uiQJqmSLumO5h0L sWiGDaGjIUSk
5cKkzUOlTcOlZdqmvWhExZhAWllCBE5ZoBq+6eI4GhVCvFqs0Zqb2hquLeBE dKiXHpoLYidQ
5anheFW0ucuaVNu2aRu2vUG3WVvZjSR13mOd/saU2cqR7tG6Hc+ZIiS/+dua BtzAFVzBIZww
KNyhomSipgSdLqpblZiE7tH4lA9tjWNjrg9C6ALKqVzLsdzLpd/awWJU2pyu iiSpJiGJhakt
8gEDNZDT0WTUgSXV/d/VHUTWbV3XfV3Yjd2nRqWvfeZoYt619qpk6IWPwhY4 yNAB0NAXFR7r
HR5CJF7jpWsD7N5TWmVflv9mzuWqKWprTYQabK5TImTRFlVDFwES6y0kZPJB 4ske7dke7vmD
7kEerkbnZ9onvU7Ur0LpfJCXHwUL/81FTgas9oEfx36f7I1fNR7ndDYstvLj w1bVS/ggf66T
f5mp4fRfdwKgACJgAdasAuqju7Znfe4sXZ4swvDEEHQrzeCQ1WUoH6Ag0p4g VYyqz0qGm/3g
/UXpf5rSDW5MfTYtvCGaxBrFlGJtW9krjUqt19YpPPnUI47t2MbbCw6k2KLt ifKUC62T22or
RVmR3M4tqepdQuEt1ioh2/Jt0zKfo+4t4J6sS33TPxWu4V5n3Lat4qpg3Y6o 4z4uoent2VLu
ovocrZhi7osakrxdLud2rsbZ7eSGrojBLeGa7osGBAA7
name="NoToolbarDetail.gif"
filename="NoToolbarDetail.gif"
R0lGODlheALIAPcAAAQCBCSiJJSCvNTOvKyqnDQ2fERixHSGzOTi1IyizLSm zJyYzHSS1K/C
5Dxu3J621ExihMTW5FyC5FRipHyi5Eh65PTy7OTO5KzC9GaC5ISq5ExyzLGC nNzi9MS21Jdm
fKh2hHuS5I2y7LB+nEd67GmK5LSWrFR03MzSzGyKzISe5OzS5GButLPK9OSK LERuzJyq5BxS
hOzq3M+mzLzK5EB27LrS/Jyi5GJ63KRuhGaK7Py7PPwCBPz69Hyc5Mza/BQW ZKCm3KSezL/G
5Ki61Iei7IF6vOTq7LS67Ky+5LDK/Hye1Ep25GRfpLSOvKx6lKySvGSK3MTT 9B8mdLDC1DRC
jEBm1Nzi5ISW3FyK7FxyzMyy1HCS7J6y5N3e1Jeq7GmC3LSq3D5y5FGC7Iyk 5PPy9LSKpKx2
jFx67HSM5GN+5KxyjNzCjHeK3ERizIym3MSqzLTG7Jmy3FR95GSG7ISq7Ly+ 3KlqfJWe5Hx3
tNyiVFRuzNiu1KxwhHSO7OTs/LzO/JSanJSmtHyevEtOlIR2tOyWLKSyvNTe /NTC3NSaxLTG
zPzIPJyWxHRopOSWPMTS3FxWnFR61Kyu1LzK3Ds+hFRqrOTa7BcebLSavCwu dIye3OyeNERC
jJx6tH+j1Lyi1Le53FR25Ky6vHRutOXi3HyU3ExmrLSGpNzm/NTW1D9t1Ozr 5Pz8/LzF7Hya
3MXU/GJ11J217GxmrMSkzExv3LzG9LSZtGR23ISc7LzM9Hya7PTu7CwqdOzm 5JSa3Ny21HSG
3FyD7Pz29LSOrExmzKS23OTG3Ely1HSK1Ki63LSSxNze3LR2hLzK7Ex27LSe zKy+7MSOvExy
5LHG5ISm5Ex+5LLG9GiG5Iyu5LSGnJRqfHyW5Ex+7GmO5Jqu5PTu3NSqzLzW /JSm5GN+3KFy
hGuO7Jyq3ISm7Ozu7Ly+7LPO/LR+lGyO3CQqdOTm5Ima3HSW7Jiu7GaG3FSG 7PT29LF6jFl+
7OTGjHWO3EBmzJSq3ISu7MyexMzW3EVGjCH5BAAAAAAALAAAAAB4AsgABwj/ AE29okCQggZ+
GjSI4JdNRDZ+Cxs+fOjwoYaJFjEi1HiR4caMHieGHClSZMdsIFFuZJgy5MWX JUnKVHmypUmO
MWnmlAmTJ06fNke+7EhUYcJsCUUc3Xj0IFKjRDM2ZZh0qdWiFrEi1Ho1q9eV UcGCtIqUqtmn
SsNWVTvW69q0bbc+LUv3ZR2kdRLm1bD3Ll+8gP8e1Ks3cF/DhBPyLSx442HB fqn6nYx4seW+
iTFfxqtY82PKkA2XTeg4c+KLfkcjXa3Y8eiO1WLHJlONjAYyFNBRMMVb4KuB GihUO5gXoUGC
wQsqX868ufPn0KNLn069uvXr2LNr3869u/fv4MOL/x9Pvrz58+gLvvLBnpsp HwLd927DwFQ7
3j5+F/xEkP9y9gAGKOCABK5HIHsGGojggvkxeOCDAip4YIIMUghhhBc6OKCF GgYoIYQcFjih
DxRIaCAFDq6HIokKtkhigyuWCKCLKKrYIIvsyYjjjjr2eKKNFgZZYY4u3vjj jAvqSKGCOua3
4oJCvnhikuuZOKSRDVaZ5ZZCaunllUhuiSWXW773pZbvjXmmmFF+iOWXZpK5 Zpxaqhlmhx6y
6QM3r8jXmyn5BCpoPvS10dtvJDaHZpa/NYqoo/kJlN+jVVZqKXyWVjrpppA6 6umlnWoKqqia
Svopn55O2qiqrKa6KqWmgv+q6iuS+rZeraRWGeuqpvDpnnu09tmbe/DhN2yv AvVK63u9FYss
sMoaKy2zvEFrbbLX0urntcb6yqy38BGLrLbYChvusdr2Keyv31JLLrnGnhuu us0eK6+98dGK
KZ/t3uutuPT6q658+wabL7PFAsvvvQwjC9+9Aefr68DMRkwvtMEujPDG/vbL scMHF0xttX+W
/DDJyAIKaKBtJNPGyy4Hk4zM+TBwH376DaQzlA+Ty6587I4MNMopp5xwtEOn HPSzTCctrdMo
J520sz+/0s7RTRM9dNBSU7vtn+wWey61WBeNtXzLGjxutMvyW3G51ba9LKZw R2u323Rnu7a1
c9f/XWzavAGeLOB8l9x3uoYPHvjihY+8eLJ/5q32smyXbPnlmGeuOeSb/0l5 56CHfijon4tu
+um8qfBNF6zL8803MMAwzudkxOGMLrc7o7srrmzychv5UJB77sA7HMQWfCgg gBF5GHGApA/n
J+7E4G7MzcnU9yku9tZ/PK+v3J/8vfgcV/+9uuTv6X2v2Jtrvfvff7z9e8TO H3/708P/rbk/
g9z/9Fn7XwAHKMACEvCABkwgArsnwHP9T4G/6pMDGXjACSqwYx3rXwYXCEH/ eRCAIOSgCDsI
QAwybYMFfIUGuBECb5QgCtgAgxrIQY5fIIsM0YiHObyBjXuogQSimMYJ/76B hzS04QahMIM2
OPCEM5yhDWnoTRiOcQEPLIB5pJhFE1iQDAqtD4DPIpcFuwWyhpUwjGVUVgS3 dkKSoTBr7fqX
GD/osTOakWxkBFkc9RfCb4mNjht04LrquMeweVCQhjwjCNfFyDXuL3/zU2Qb 5ZjIjRGyY3SU
ZPzs98hLHlKNnoTk+zhpvjRGsnv4W58Z+ThKVprwlKuM5CtgEAJu2DIfaQhG DHGAi1j8ok/O
4EYRipALLpjDHNhAgyhqsYdQEMoVJrhFJkxgBg5wIB/V2gQwVnCJUAghD6Rw xAQiQYgJXG1R
iOhAKjqAiFvtaT3Xo9/D+NQges4TnvRbDzuld//Pnt2TG+oMaCoMlCZ75pOe 4Dtog/L5zj35
0xTr/GfPEArPgYnvYeqk2DwVGqd4OjRNCNse+OZ5Mgl2tKL+pKg/o+fOlq40 TS6NU5xY+tCF
2tSmMb0pSNmz037WtJ4olSlPh3pRoeYUpSqlp1CjJ1RNgvJ+T/Wf+6pHVUIq cqpYFeUrP/nK
qcaxk1ClalY/OT0Y5MOWpjBiGsAgw1ho4RfucQUXitCKutq1FXOohRvUEShX oCITdSWGNbHJ
J1CEIxFD8EAjstgEcv6jEiwYUEbzE1Gm4pSyHSjqjehU05Zez6JViqg+UzFR 0OL0szU1qj/V
iTAJwqmmqK1TmvYpJwT/oZZji3LtkFwqQYcO7LfZC67FhJu9ihH3t8YFrnI1 lj5VOtem8luu
dBP6zuNS75/TzS6qOtszM3k3UuDVV0u/K97vIuyh6joqedcbXvKid7veUy8/ W+rO1rK3vO0N
73QfNo40uCcEUJQhDWPhy+s5Qwe5uKtdl2kAvubDFSO4hV050Ar2vWIGigDF JK6oRcdWogCE
eNGKKpshAakzTyUG0YFI3IHMpvjFDzoxjGFM4hnb+MY4zrGOd8zjHvv4x0AO spCHTOQgw6AE
aUhyGjIABnKoAQc4iMUm2OMKOnChFVzo4RxE0YpnnKAY6oiiK55gBjPcVVk+ 4AMNhkANajQg
/wkNUEYXjCEHOSRgFwTZBYlOrOccyfjPlV0naX2QilQgYtACDSh7IipoGRf6 0C8CkIx9AGkK
HPrEFFA0oSurTkEDqNCTbvSiT1xoHzjaxYVep56fpOdcAOhJob60ngG9aE/7 oM+uftKAXM0e
XgdI10UOtrCHTexiG/vYyCY2DLCh5BhmYIYzjAUeqDwHHbRCB3QYAxpI0Iog 6kMdpgiBK84w
Ag6gwq5p8kE4pGGEcDaWEI8tgDum4I7l7GKdMcJzOlFU6n6TFtP4pgC+961q fKuaAng2eAcI
cnA8EzrRCMf3wy298Htntt+ZpbjAK07qivubRIzmOGkljm+HF4REeP9O+cYR jiKGXzzjJW95
RGN065Y7vAgixnnLc2FzlrP8RXjm+S50rnKT3zzoLBf6z39eBKQ7felHp4DS lW50FDVd6kln
edVRnueuE13r+W55jmpO9Z4vnetYx/PXVS5iPEM97WDPUdG1LqA+p7zmdgeQ 3VHUZ/bo+e5/
R7jfge13vBde74YP/N8Tb/hbB0jxjnc4gXB9+LpHXteQv7vjCw94vg/+8wJa NpKRjA1sZODZ
Ub4Be3SBBjpcmw7CuEc3WkGCaRTDFSEIgS768AQK2/V6JJoBNdgchzcnoQtJ qPM+EqAb3RBE
nQRx/sZ1A/1Mp6Ig66T+9a0/fehDv9AFqX7/QNO5/ehXX/qJvn72n19+6KPj +4l+f/nZT/+N
rz/9BaH+oZtTfftXH9Tl12jb53wEGH35txzSJ33KUYDTwYDS4YDRAYHQIYHP kYDZwYAUaIDM
oYDVwYEHWIHU4YEgOIId+IEkCB4iuIEmqIIa2BwpyILdIQvYYA54gAdFgAe5 UAIScHqS8AUE
4Qwk4Ho6oANZkAX0QHtioA+2sCfO0Af2YFfs0Ao+oAKxAQr94AnvFm/zhglA cAqLUQe5AX1g
OIZiCH0aIH8UUAdmuH7Z532poAFuyBdiOH2LoRtnyH1gqBtqeH1jOH1pqAHr BIaBuHF7eIZ3
OIh5gYZ7qH1mmE5g/3iHYJiGBqGHaQh/gtgBYKhOZ9hi9/eGikgQkRiKoDiK lCiJkpiIpiiK
fGEQj2iHzqeKj9iKkziKkriKtuiKtBiLrDiLd5iKu3iLs+iLlEiJfXiHvSiK vgiMfbiMkJgb
kkiMzYiKfViLsgiJhqiH1liL6NCMxoiL1/iH4JgX1MiLzeeL2viLr8iLugiM 3YiOo9iO7eiL
Yxgc4liP7miM62iH67iPp9iPzKgbspAF3qACeECQZKADJUAPEoADMIAO1aAL JHAPClZXJCAG
VuAKKuADUnAHfVBX7GAP9kAi1YAO+zADTuAIhNAJH6YJmMCFVfAKCFEHeVEH gSiHbxiIAf9F
k5ioiYFYiIUYiECJiTiZCjPpk+zEFzNZk0WpiTrZlIC4kzeJiU+phohgk1M5 lUy5TkjJlD6p
lIk4k1sZlTKZlVLplE7plUiZljKJlEWplms5htv4lkWZhnB5hm0pl3SZhtuI Dnc5lzKpl3bp
lkiZl3Wwl305mH9ZmIEpl0VZlIbJF48pl4KZmHsZmHy5ior5lm5Zl3V5mXip mJ5JmIk5hqTJ
mZFpmKQpmoBJmWw5mTMZl6SplrCpmqD5moh5l6e5mI15m7TJmX4Zm6PZm3T5 hb4Jl7JQAjvE
BVzgDeZQhDpIDl/AF7pQA9ZwD2MgDGNAD91AAjUgBm6gC1OoCxz/CQJnAJLN IJLbGAS0sAyO
8A/yNgUumQLEoZaJtpYCaJOYmBc92Wn5yZNQiZWNNpagJpk9SZ+CZpUC2p8B qp85yaAFmk78
oE4zKaFhyZWuiZ9vWZ8MmqELeqGa+aFgKZOHKZkkOqIm6qEnWqIouqIf+oUu qqIwmqKTOaMh
epcsaqM1qpbE6aE7GqM6mqJAeqNC6qM5SqRBaqS7KaIvyhey4A1O6qQl4EIS MKXJIA950QJz
wAQVYA3WsKVMwARi4ADIoAsqQAEtAAJ3cAfl0Ad9cAfoyRf7oABCAAX/MG9V cApLgBB6+oX+
2KcOuYx9So99moeDWouFCqh9+Ke5UQ2E/9qHiFioipqHq6iokZobk8qoz4iZ z4iplYqom+qQ
oMqoIzmqoUqqsVGqqDqqdWCqoVqZrsqqpHqN1wiroCqre0mrI2mrZ4irrjqr rcqrmCqpngqo
vVqZYxisnJqskvqqt5qHI5mplCqrx7qq1Mqphjitllqs0pqGwcqtidqt34qt lGqt2hqXiyqs
myqu17qo0Tqtyiqq1MquuXqrvxqtxtqPzXqu8CoC7RAF/hoF88BWYDAP41AE IykC0SAJL4AM
G7AByLAKEIsMxlAHOCcPoVAOH7ANH7CxOSIcjFoc/BCyBxGydcAPSsqXjPqY KPuWsJmydpmy
a2mYI0mttimzhf8Zs5CZs5kZl65arSx7hoHIszm7si7Ll8O5solol3QJrzT7 h5eJtC9bm0VL
rTb7pyork7Apkx/7tCKasrTaqqBar187kmJbr2ELrGeLDmXLqmmLtrwqr2tb r84Iqtyqh24b
t3ebt3i7t7Rat3r7t3sLt4A7uGXLt4aLq3UgC4q7uIsrD80XGyIgBbogubqA O5UbB18whVMo
D5Pbuc4QPYlSEMnxHJK3Y4T3axlyujmmuhDCugPiujAGu8k2u7RbYhkJILdb u6mLumMXaa82
Y6wruwcivK8rIMBGvL+bvMW7vCUGu4Sna2LnuwRyvBcSvBByPbaUvbW0vbkX AoLCG97/kC72
ZCRh0w7sknvmGwLhpr7egCzpu76m0L7qG7/wi77/ZR8sBL/yC771q765F27I EgLmG7/u4Q3c
MMDcsL//5b/+u77vK78MTL8CHG4QrL8F3L+9MsD0e8D/tcAA3MDqK0AhTDLy 0cBM88FRozQp
Y8JsdMIsTMIwjMIq3MIvfMJBU8Nc0ysGFMEjzL4ALMEffB/nC8INzME+bMTp a77ty8EEvMED
bMBOzEJJnMAULMFTLMAXzMHm+8BafMET/CtPXMBgfMHt28RL/MThNsVbzMRQ rMBmfMFrTL/0
e8b5a8BxTMdofMBYvMVzXMVLLL/7G8gZnMVK3MdRvMd7LMUH//zB6psGgeLI wBPJL1MzDFDJ
S8AAS/AKS5DJnPwKn6DJmszJljzKl1zKmHzKr3DKpmzKqbzKqswArfzKrCzL tEzLrkzKuGzK
trzLS2AKrvzLuTzKsXzKu0zMl1zJsIzMxFwfymwKxOzMyOzMxwzNqRzNzfzM lVzNlQzN24zN
yWzN1jzN2XzN4dzN32zO3SzO58zMyrzOwXzMqxzL8bzMwAzPr8zLo3zP9qzL 9YzP/PzOtVzK
w7zPxkzK8pzPBA3M+ozMv+zLxnzQ+EzPCz3PCt3PBV3QFA3QCt3OHK3MgSID CAAOIA0O4BDS
JX3SIZ3SKE3SJq3SLr3SLx3TMD3TMv9d0yt90y/N0ictAzSt0yo90jYd1CQ9 00Td0kUt0iHN
0z+90yd91Ee91Eat0jOt1D7d1C9N1U/N1FFt1SuN1Tl91Vzt0jxN1V9d1Vst 1T9d1mjd02Gt
01kt02291jj91lx91GQ911o911sd13TN10nd1FQ90n5d1VMt10at13yd2EI9 0jKQDIiNAHd9
2HBd0l7d1JTd1ixd2SZ92XvN2WZ911Pt1JCN2Z5906Vd1p4t2Xmd2o+N16ht 2K5d168t27Gt
2rBt27SN26ot2mwN12dt1oSt24Md2sL91zbt2pEt2sl91smd1bLd3LNd3K2t 16Ad3a1t1Ms9
19Ut0igtA/n/MNZQ3dW87dxqDdzTvdboHdytnd17Xd7k3dO/vdiYHd/wXd9C fd/2nd/4vd/6
3dsyANQ7fdtubd25zdsAPt9I3d+wreADDtxrLdjY/eDSXd7b3d+0fd4IHuGI zdjD3d50ndQ8
zQCQ7dvmndJKfdcoLt7hbdx5zeIuzt0mjthtTdYn3uIwbuMpvuI3rtkNPtoj zuAXvttC3uBB
TuRDXuRIfuRKbuTq7eNaXeM+DuVSztnQPdgxXt6wXdlWzuQF3tlYbtlCveX0 PdtiPuOnXeI5
zuPuveYITtkh/d3/3eZXzd90zuD8zdh3DtMAXud8HuA9jeJxPuTpPegd/uEO fui9/23oif7l
9H3T/53Wds7gB77gHv7gfk7o6R3pv03XEF7b453UHg7kW93pm27dLw7Wp97k JX7pWi3ihn7i
UU7lsh7rtD7ltT7rth7ZPB7Y3c3rt/7ruY7rqa3rbh7pi37diE7ijJ7siq7s yH7sYs3aIB3s
wD7r3f3sjV7q6m3mlP7ZGI7dGT7gNP7cfR3qzr7hr87bQb3d0Y7bVj3tbfDf ez7jkN7n9q7p
NP3orF7T837v/i7vPy3vSc7lSz7wBl/wCE/wCn/wCs/YeI7v963vAi7oXV7f /Z7f9G7ef17W
k17mfl7oE9/jg93pn87VWl7vO37cOf3fDHDymV3sTi7vMv8/8zRf8zZ/8zif 8zV/7VAN5SKt
80Af9EC/03uu5iWd0kh/9EqPAEnP9Evf9FD/9FLv9FQf9VU/9Vaf9Vi/9Vff 9U2v5zz/80I/
9sTe7oY+27te4O9e8dmu6gTu5JuN3/Nd5equ09m95azN5qh+3fA+7es+86AO 8YLv76wu8ZSt
7xdP+PfO4SAO1Cb+13Ee+WM9+T9f+ZJv+ZR/+Zqf+ZyP+Z6/+Z/f+aA/+qJf +v0e2IGv+H8O
8Psu8u6+7PXd7AmO7CzO5OkN4PMe7pV+6G3v6SH/++pd4VkODi3P0zh94tVt /AnP8MyP8JH/
+ALf0sq/8Mtf/W5P8yPu99qf/dz/v/3e3/3g//3iH/7kP/7mX/7of/7ej/vH T/3uH9eGD/Ku
D9xpf+VyPv/t3/tvL+Pafu6YHtYAIQMcgoEFCRIsaDAhQoQKGYJbGPFgRIMC H8pAIKPNxIcF
ZXzkeBCBSIwkRw7MeHJkSZQsV6pMaVJmS5guD2L8mBMkRpQoZ778GZNmUJtF a6rUmVHnUqZN
nT6FGlXqVKpVrV7FeRMm0aNcRQ502nGiQocQH4oty9EsRbVtIZIdq9ZiWolw 19qNq3Du3Loe
0dK9CHhtXsJ++07kWRixDAYfJe5UilXyZMpMlUaunFmzY3yGXHwGHVr0aNKl TZ9GnVr1atat
Tz9iA27z/+bLdMsKzmtX4OHbbtUK7n337GDiHOe6xZ38d+7hf5fjrZvRbnC0 ONtkLftUtkDH
3bl/3x7eu3jw482XR09+e1X159undx8fPvqPbDjtYJRf/37+/f3/BzBAAQck sEADDwxwB07Y
aOo9B+V7L6rh6uLrIuR8I04v5oSbbkLFouMQLeci2is4tjQMsTjomlsrsRRN ZBExcBrb7SKB
VBlFEB135LFHH38EMkghhyTSx0NQgCgdHItkskknizxSD/wQpLJKK6/EMkv/ dtAjxye/hBLJ
t2K0DcO4KszwwxOpgzG7DldME67jKgKxzedGJGhOMqUT8U0+ObQOu4tQWOSI Vv8ORTRRRRdl
tFFHH4U00kXLWARJQg2VNFNNN42U0kA4BTVUUUcltdRHA8HU1FLrWUQViHLa sE48y5TNw1qT
mxPOE81EUc0L46T1OTgREzbWX3lS7tY8Z9SpooxGSVVVaadV9IhRLICWWm03 PeLTbb8FN9xS
vRVXU2vHBLFYP1P807h0dZWR1zd3fZFFFfXkcN1fh0PzJhjxtRXNinjaSDcZ BOlB0oRbWZjU
hiNd+GFII160HkHAEURViTXdeOJDNy6D3EUBIBmAchU1OdGSUwaXZUlNdhnR mGFuJeZTEe24
1JwZVrQHi191bEQ7152zRHV5y/NXWoNVEUOAgeNV6ML/mJaV3n0T8otGsBY6 uAev6/mY4YTB
bpRsng8F22eeyTY7UbPJTnjjtM9uZe6dfU7nYoTDRrtvnhtmW9HA/8aZcLcN rxvxRXsoIx2R
VYb85ENdpjxcmyO9PHOZJX08boofbptuihkN3e280Y26XzYLe7pNonnLVV1f 83XXVtejhm7d
ZG+Pk1iNcLoNYZ+/XhmAr4evx2vlkwcgea9Xdl555IfvwXjn62ne+OmNb556 7rE/fvp6LGBF
EAsQTt557ZXvvodhqF8e/vjb9zn79If/3vvqwaf+/vFZedzmJDeyyJWLZpvS HAEnx7nr1a1k
6rtf/K4nPvhFj4LJI5/5ZLNB/2I1jXd3stqreOUifpEpO7LzyLvYhDS6GI12 hmERCUm0JhBe
TSBaE8vB6rHD8fnMAt2zgP94OETs8fCHPGweEYnYgx8GkYlFHN8OfbbDI6aP ikms4hDx9g69
8dCHAAjiFZX4RCkqcYhJjCIayyhGK44Pi2ocIvkCuMCRkWxydrRjzfDIspIt MI96/GPNGJXH
PgrSj4XUIwH5KMBCHrCRjRQkzBzJqEB4MYvNyyIZ27hDNU7RiWHMJAbTwUXU Aas68DKl7k4J
whV+CF8qtF28crch3C1rdssa1upouLWMXCdpekFYGL0Ixjj20Ig9BOMUMYk9 YQbRAj6cIhSZ
Gc0oIv/RmWe0JhV9OL6DYWyJJEMiMalIRGdS05jM5OQzjSlMdLITjeJUpzNL MUdDFnCSkaTj
zBKJTzrmk5D9PCA/+Vm5fApwcwH140HxmTKGUnKcRVQnJ6s5zmZWr5lrPCMo e2iBbm5Hlh08
4a14MtJfklSkJUUpDDmoLJGGtKQq/eXU5JJSt7gIlS4EUdFyiSx7ybSFy2oM dARRTDdStGTO
fOARkYrUK4Lzh8QMIlQxOdWpPtWpYMTqU5WKyXR0c6hGleobr/pUNzKVqUXd alWh18Sskmyr
47PAO+hps0U2dKD+xKNC+1lPQ9pVoAH1q0HrKrM+OrKwCqWZXS8XiGZC9Yr/ WnXjVbFK1aqW
VbLjG+XFwlM7PVnkabVMlm+O41nAjDYtpr1TZ0vLS9TOMrQp9FftWAu1NKmO swXJx0jhYj6K
ljWNS5VqE9N41GtagK3FDS4zidnWMDI3q+gkJitI+dVrOjeqxmXrcoW7XWZe V7nXfe53mQvd
ILICgI2iq14bqth6Ara9BewrQN+7yL0C8o/3XOh8EXtXviKqksYdbljBC1zv BtfABbZAVzWL
HRkaJ6avBa1olUPCojlYL6fVCks7iDsXCeqkF+6gDCtcWgubtMEd1u2Gk9Eb gVAXrr41LgDK
EOMfzpitUWzijDFpVazi2LJLbSKNwSjk4w7ZyMZV//D5nGkBHRc5xivbLlZt LOMlZ7XJQT4u
kZkb5CGnY57ohdxg48teMf/VnuxNaCLFTF/Btjmxes0vYC/Xikr6mMlcBu6U 8Vxj4+pYz1TG
cmaBtto8jXY2V9HLTsCSk/WgtllLGRikCx1p1koapjpty15iy0tn0ekmQduL pTPN6c+Cmie5
XSlHeItduA75ylmGNZaPTGQApwPWQ8Yzrq076yGzohRdBDCN94xrYd+a1cYW dla1nOVZm5ee
9iUsmu/J0MPidWZ5be99E4vIQOpzrysbaGEhOW1HMXbJ2N2zsXmNblljOci+ XjBUFo3iCEO4
tCDxiElTEml9U7jB817Mp//1Pe+RMtrCtQlxhkPsWXoD/LSw+nBiOlzoCzFg 34EZKruL3W5d
u7vjHLc1u4mt7C07WdlaTTArvHruYRf75CTvMnZHnmuOO/nJ2PX1swcorjnv HFI9r2TI211z
Ws+a2SSnscoXPNNF5zvUh7aK02GrHluudDyF1g7WpV51F3b20UFbT9P91SzM FNzgYcc6Uybc
aBHPGyyonvhAzJdgJCcYjLa29VHz7tZ0xBzKeIdyl/HeRMDb/e6TJVnef9j3 ZA8e3hire94H
33fAJ37xMd4747GreMBnfvErUzzSL5/yL/vc5z03fR1PFfLKAyDkrse8VSUf +5K9Hquz5zu8
LTD/6MXYu96/933wgV9v0vIp7gsHS4aPL3y2hyXRhtG3xU98sM3T3foarz66 WY997ded+94X
+vexr3ic/zpv4kd/+tW//pCzgu6aN27OUz9/+o+KseFff/7Vb+vHM3/4/gfA /xNA2tqaXSK1
DaoRDxpADIEtfDO+ULsOsMs382m/+LNA8rlA98PADdTADszAD+RAEPRA/qM7 9yPBvgMADeS/
X8OYCgzBF/TAEDxBDJxBE5RBGtxAkes10tO5+vPBHzyUQHA8C6zBEjTCIkRC HMS7/nPAiEsp
E3vCKHTCKYRCKpTCKsTCK9TCD4MJnxiKLwSKkhDDk8hCK+RC6PsKMkya/53w MAbQjYwQBLzb
PuubwzoEvzukQzwcvDx8vz6cPD+0PuliQQqUQwvghUI8REO0tURMxD9Mh0J0 RD+MxEekxEo8
xEQUxB4Ewk1MvfsDxEn8xFAERcfrv8tgQ1PEiVRExVU8xVZURVdkxVeUxVik RVi0xVm8xViE
uqeoRVz0xaRgQ8u4xVTMrSYsNEFghSMwL2VkxmR0xmaExmeUxmikxmm0xmrE xmtMxncoBS9A
RkFQRm3MxnEUx3IkR2rkRi/QRE5kR8lBlWU0x3g8R3h0xnRERo7axXzUx33M jFL4CH/kx10E
SIDUiYHECgSwOIf4iEBgyIZ0yIeEyIiUyImkyP+KtMiLxMiM1MiN3Mh29Mj6 48iQFMmRJMmS
NMmTRMmUVMmV3Egv6KWzK4h1/MiZpMmatMmbxMmc1MmdDJVAGAAvYAybUgqZ 5MmiNMoBKh3S
6ZthSBxHARumfMrEgcrDaYWpnMqjxEqbZMqqlMqujMqoVBSmFEuutMquHMuz JEuc9MmXNEZw
eJyoLMuvTEu4nEuupEuw3MpEGUuuVMpFyUu+FJe/7MukRBTBBJW9zMrE5EvE 9JtHYUxSQcvI
TEu0pEvJtMzJxMzHVMzNdMefDEoSkQGi1Mm/NEzOVBXB3ErS1EtGUc3CDMvV dE2sREtHUU25
NMzLHMvKBEyjTE2v9M3/qQQb2/RN4aRMu9xNnOxNRAlOqmTOpvRL2mzOIByA l7y4mGxHwjTO
sjxOwUmc5YzL7OzO8FzO5YTNQ7nN53TM8oxN9DTP1yyd1vSbtpHP6JxP5eRM sinN0uTOacFO
muxPTpzNTOlNzZQWwyyd+Qwd/aTPskkUnwRKrRkY0Rygq3ROSAkc8tw5+GRN 6EzLDd3O9lxP
ED0cDU1KEn3NEBVMwsRPSNHQTPnPD60Y49SUF92U8RTPG7VR4MTRHbXRHg3P rBxQzExP3MzM
IrXPA43OxuTR/ewbDPWv6dSI53jL8PxOHdVR7xxO43RSEeXJ+dTOJlVS7txS EA2d+rTPvlRS
/wpV0rZJ0eYs0x9lUgYFFRo90h9VUSq90Tr1U
| Re: Heeelp! How to define a command group for "Customize Perspective..."->"Comman [message #336445 is a reply to message #336443] |
Fri, 12 June 2009 02:36  |
The tab shows only the actions defined under the action set. It
takes the menu & toolbar path of the actions to populate there. It
doesn't seem to honor the command contributions in the toolbar/menu, yet
its named as "Command Group Availability". ouch.
It shouldn't be this way and there has to be a simple way to add a
command there. I've raised a bug for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280033
- Prakash
http://blog.eclipse-tips.com
FUDForum. Page generated in 0.04345 seconds
