Home » Eclipse Projects » Eclipse Platform » Commands and Toolbar and Toggle style buttons?
Commands and Toolbar and Toggle style buttons? [message #336423] Wed, 10 June 2009 16:37 Go to next message
Originally posted by: eclipse-newsgroups.scharf.gr
I am trying to do a very simple thing: I want to add
a simple button to the windows menu and the tool bar
and it should be a toggle button. I used the "Hello world
Command" template.
I have the following problems:
1. if I add it to the toolbar as in the with
locationURI as:
toolbar:org.eclipse.ui.main.toolbar?after=additions
the button appears but in the "Customize perspective"
the tool bar has no group and I am too stupid to figure
out how to create a group :-(
2. How do I update the toggle state of the tool bar command
and the menu command? (they should somehow listen to the
state of my Handler). I am sure there is somewhere some
magic, but I was unable to figure it out...
So, I thought I'd better ask the experts:
http://michaelscharf.blogspot.com/2009/05/why-is-rcp-emf-p2- databinding-so-hard.html
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Commands and Toolbar and Toggle style buttons? [message #336427 is a reply to message #336423] Thu, 11 June 2009 02:16 Go to previous messageGo to next message
> Command" template.
The "Hello World" Command template, is what its meant to be - the
starting point to understand the commands. It adds a command, a handler,
a binding and two UI contributions (menu and toolbar).
If you really wanted to learn beyond a "Hello World" example, I would
suggest you to get into the following links:
http://blog.eclipse-tips.com/search/label/Commands
Is there something more can be done to simplfy the learning?
- Prakash
Re: Commands and Toolbar and Toggle style buttons? [message #336435 is a reply to message #336427] Thu, 11 June 2009 10:42 Go to previous messageGo to next message
Prakash,
Great links! But I still cannot figure out how
the heck I create a group so it appears in the
customize perspective as something that I can select
(with a name).
Michael
>> Command" template.
> - Prakash
Michael Scharf
Re: Commands and Toolbar and Toggle style buttons? [message #336439 is a reply to message #336423] Thu, 11 June 2009 14:08 Go to previous messageGo to next message
Those groups each represent one toolbar in the coolbar, but the labels
in the CustomizePerspectiveDialog are kinda hacked in. Basically, they
currently come from
org.eclipse.ui.internal.WorkbenchWindow.getToolbarLabel(Stri ng). File
and Navigate are hard code :-) and everything else is looked up from the
actionSet registry. sigh, I can't believe this stuff.
So for example, if you create a new toolbar using something like:
<menuContribution locationURI="toolbar:org.eclipse.ui.main.toolbar">
<toolbar id="com.example.myToolbar">
<command commandId="org.eclipse.ui.help.aboutAction"/>
</toolbar>
</menuContribution>
Then com.example.myToolbar will be sent to that method.
But it implies a workaround would be to create an empty actionSet with
an ID matching your toolbar and the appropriate label.
PW
Paul Webster
Re: Commands and Toolbar and Toggle style buttons? [message #336440 is a reply to message #336435] Thu, 11 June 2009 14:12 Go to previous message
> Prakash,
> (with a name).
Were you able to find the toggle update part? There should have been an
example off of the http://wiki.eclipse.org/Menu_Contributions page, it
basically involves using IElementUpdater on the handler.
PW
Paul Webster
Previous Topic:Schedule UIJob in Activator.start()
Next Topic:How to use java syntax coloring for non java files
Current Time: Sat Nov 08 12:23:36 EST 2025
Powered by FUDForum. Page generated in 0.03473 seconds
