Home » Eclipse Projects » Eclipse Platform » [Update Site] Creating required dependencies
[Update Site] Creating required dependencies [message #336413] Wed, 10 June 2009 08:31 Go to next message
First of all, I'm not sure this is the correct group to post. If this is
the wrong, please feel free to correct me.
I'm currently creating an Eclipse Update site for a custom made plugin.
This custom made plugin has dependencies to:
- M2Eclipse
- Mylyn
- Subclipse
I'm looking for a way to declare my site.xml to also install the
dependencies, before installing the plugin.
I tried the "Add feature..." action. That seems to work. But when a user
points to my update site, he's still able to only install the custom
plugin, and no other dependencies are installed.
I really need to make the dependencies required.
Is there a possibility to do that?
Thanks in advance,
Jochen
Re: [Update Site] Creating required dependencies [message #336453 is a reply to message #336413] Fri, 12 June 2009 13:44 Go to previous message
Jochen Hebbrecht wrote:
> - M2Eclipse
> - Mylyn
> - Subclipse
You need to specify the other Features as dependencies on your Feature,
so that they are required to install yours. Then, in your site.xml you
can specify an "associate sites" URL that lists other sites to use for
installing dependencies. The DTD and some explanation can be found here:
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/update_sitemap.html
For an example, see this update site:
http://downloads.skywayperspectives.org/builder/updates/site .xml and
also the URL that its associateSitesURL points to.
Hope this helps,
Eric
Previous Topic:Replacing the debug perspective with my own
Next Topic:add filesystem resources to project without copying?
Current Time: Mon Oct 27 14:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.26271 seconds
