| Automatic updates fail: No repository found containing ... [message #336389] |
Wed, 10 June 2009 03:12 |
I am using eclipse Version: 3.4.2 Build id: M20090211-1700. ( I downloaded
the version JEE+BIRT a couple of months ago)
Unfortunately, Automatic updates just isn't working. The proxy settings
are OK, and I can manually install updates if I try to.
I haven't changed my workspace directory for more than a year, so maybe if
there are some settings kept there by older versions of eclipse, could
they interfere?
Is there any possibility to fix this?
The error i get is:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.birt.chart.device.svg/osgi.bundle/2.3.2.r232_v20 090521
org.eclipse.birt.chart.engine/osgi.bundle/2.3.2.r232_v200905 21
org.eclipse.birt.chart.runtime/org.eclipse.update.feature/2. 3.2.r232_v20081010-7X8n7EELtcA6IWMJTLCJ6B
org.eclipse.birt.core/osgi.bundle/2.3.2.r232_v20090521
org.eclipse.jem.proxy/osgi.bundle/2.0.110.v200903042030
org.eclipse.jem.util/osgi.bundle/2.0.101.v200905140130
org.eclipse.jst.common.frameworks/osgi.bundle/1.1.202.v20090 4160830
org.eclipse.jst.enterprise_core.feature/org.eclipse.update.f eature/3.0.5.v200905070430-42E_5_kE77d9ICR7Z_H
org.eclipse.jst.enterprise_ui.feature/org.eclipse.update.fea ture/3.0.5.v200904070030-7Y7BFTBEPOwQQhP9-_UXFxRBQvWw
org.eclipse.jst/org.eclipse.update.feature/3.0.5.v2009040705 00-7U19A9LJLHQaz-gMbljgxLAYoUT8
org.eclipse.jst.j2ee/osgi.bundle/1.1.210.v200905140130
org.eclipse.jst.j2ee.core/osgi.bundle/1.1.204.v200905060100
org.eclipse.jst.j2ee.ejb/osgi.bundle/1.1.204.v200904280719
org.eclipse.jst.j2ee.ui/osgi.bundle/1.1.210.v200905132037
org.eclipse.jst.j2ee.web/osgi.bundle/1.1.204.v200904070030
org.eclipse.jst.jsf.core/osgi.bundle/1.1.104.v20090508
org.eclipse.jst.jsp.core/osgi.bundle/1.2.122.v200905060217
org.eclipse.jst.jsp.ui/osgi.bundle/1.1.313.v200905201407
org.eclipse.jst.pagedesigner/osgi.bundle/1.1.2.v20090506
org.eclipse.jst.pagedesigner.jsp.core/osgi.bundle/1.1.1.v200 90508
org.eclipse.jst.web_core.feature/org.eclipse.update.feature/ 3.0.5.v200904242131-7Q7AEfJEHhHehPlW6SaE4u
org.eclipse.jst.web_ui.feature/org.eclipse.update.feature/3. 0.5.v200903300031-7E4EAzDgz-Y1itBi74t4CUmX7TbF
org.eclipse.jst.webpageeditor.feature/org.eclipse.update.fea ture/2.1.1.v20090508-3239oA55V5F7R
org.eclipse.jst.ws.consumption/osgi.bundle/1.0.308.v20090519 1111
org.eclipse.jst.ws.consumption.ui/osgi.bundle/1.1.5.v2009040 81850
org.eclipse.jst.ws.creation.ui/osgi.bundle/1.0.309.v20090416 0037
org.eclipse.jst.ws.ui/osgi.bundle/1.0.305.v200904081850
org.eclipse.wst.common.emf/osgi.bundle/1.1.204.v200905060100
org.eclipse.wst.common.modulecore/osgi.bundle/1.1.206.v20090 4081630
org.eclipse.wst.common.project.facet.core/osgi.bundle/1.3.5. v200904070030
org.eclipse.wst.common.project.facet.ui/osgi.bundle/1.3.10.v 200904070030
org.eclipse.wst.common_core.feature/org.eclipse.update.featu re/3.0.5.v200903300951-7C7_EVVE_EkMNwQ7VAQ9ik
org.eclipse.wst.common_ui.feature/org.eclipse.update.feature /3.0.5.v200903300951-7C78ELqE8VrRVrtKp9gT6KxR8WBR
org.eclipse.wst.css.core/osgi.bundle/1.1.210.v200905060217
org.eclipse.wst.css.ui/osgi.bundle/1.0.302.v200905060217
org.eclipse.wst.dtd.core/osgi.bundle/1.1.201.v200905071842
org.eclipse.wst.dtd.ui/osgi.bundle/1.0.302.v200905071842
org.eclipse.wst/org.eclipse.update.feature/3.0.5.v2009040705 00-7A-8o8Qqdz0MMVgjXW3-rkYw_tFz
org.eclipse.wst.html.core/osgi.bundle/1.1.205.v200905071842
org.eclipse.wst.html.ui/osgi.bundle/1.0.303.v200905062029
org.eclipse.wst.internet.monitor.core/osgi.bundle/1.0.304.v2 00903080115
org.eclipse.wst.jsdt.core/osgi.bundle/1.0.105.v200905201849
org.eclipse.wst.jsdt.feature/org.eclipse.update.feature/1.0. 5.v200904281522-6-E79BcMAAz0BbEfEkMZ
org.eclipse.wst.jsdt.support.firefox/osgi.bundle/1.0.104.v20 0905071842
org.eclipse.wst.jsdt.support.ie/osgi.bundle/1.0.104.v2009050 60217
org.eclipse.wst.jsdt.ui/osgi.bundle/1.0.105.v200905060217
org.eclipse.wst.jsdt.web.core/osgi.bundle/1.0.105.v200905071 842
org.eclipse.wst.jsdt.web.support.jsp/osgi.bundle/1.0.105.v20 0905060217
org.eclipse.wst.jsdt.web.ui/osgi.bundle/1.0.110.v20090506021 7
org.eclipse.wst.server.core/osgi.bundle/1.1.4.v20090430
org.eclipse.wst.server.ui/osgi.bundle/1.1.5.v20090505
org.eclipse.wst.server_core.feature/org.eclipse.update.featu re/3.0.5.v20090430-20Ao8s733K3_6A1226
org.eclipse.wst.server_ui.feature/org.eclipse.update.feature /3.0.5.v20090318-791DE9vETFnvXEPbCQPH769D
org.eclipse.wst.sse.core/osgi.bundle/1.1.304.v200905151456
org.eclipse.wst.sse.ui/osgi.bundle/1.1.5.v200905201407
org.eclipse.wst.standard.schemas/osgi.bundle/1.0.103.v200903 242040
org.eclipse.wst.validation/osgi.bundle/1.2.10.v200905140912
org.eclipse.wst.web_core.feature/org.eclipse.update.feature/ 3.0.5.v200904070030-7G2EBCAM217nJZPEYxjAcnk40uRS
org.eclipse.wst.web_ui.feature/org.eclipse.update.feature/3. 0.5.v200904070030-7R0EPLE8Ks_vFN8ntF_nOY1stwIC
org.eclipse.wst.ws/osgi.bundle/1.1.4.v200904081850
org.eclipse.wst.ws.explorer/osgi.bundle/1.0.310.v20090408185 0
org.eclipse.wst.ws.ui/osgi.bundle/1.1.1.v200904081850
org.eclipse.wst.ws_core.feature/org.eclipse.update.feature/3 .0.5.v200904081850-7H7QECkED69XqMgup-fu537C5J
org.eclipse.wst.ws_ui.feature/org.eclipse.update.feature/3.0 .5.v200904081850-7E2EH_C-2gA4bQftGXjj2I-V2Jne
org.eclipse.wst.wsdl.validation/osgi.bundle/1.1.303.v2009032 50424
org.eclipse.wst.xml.core/osgi.bundle/1.1.308.v200905060217
org.eclipse.wst.xml.ui/osgi.bundle/1.0.440.v200905201407
org.eclipse.wst.xml_core.feature/org.eclipse.update.feature/ 3.0.5.v200903310029-7A7NEH6E7QYGHRHvLuKlbZ
org.eclipse.wst.xml_ui.feature/org.eclipse.update.feature/3. 0.5.v200903310029-7F3ENzCwum8Y6U_uQnFsWiUaNXFk
org.eclipse.wst.xml_userdoc.feature/org.eclipse.update.featu re/3.1.0.v200903310029-40EJs_kE77c8P_TALGS
org.eclipse.wst.xsd.ui/osgi.bundle/1.2.106.v200905201703
org.eclipse.jst.ws/osgi.bundle/1.0.308.v200905191111
FUDForum. Page generated in 0.03918 seconds
