Home » Eclipse Projects » Eclipse Platform » Replacing the debug perspective with my own
Replacing the debug perspective with my own [message #336351] Tue, 09 June 2009 09:02 Go to next message
Originally posted by: subs._nospam_consertum.com
I wish to replace the standard Debug perspective
(org.eclipse.debug.ui.DebugPerspective) wiht my own.
I have created the perspective and it works as I want, but I can't work
out how to make it the 'default'. I can change it through the UI, but I
want to set it programmatically.
Can somebody point me in the right direction?
Derek
Re: Replacing the debug perspective with my own [message #336387 is a reply to message #336351] Tue, 09 June 2009 23:06 Go to previous messageGo to next message
Derek wrote:
I'm not 100% sure what you mean by making it the "default." Do you mean
that whenever you launch a program in debug mode, it should switch to
your custom perspective? If so, you can control that in the Preferences;
just type "perspectives" in the search field of the Preferences dialog
and you'll find the appropriate page.
By the way, another option would be to just customize the Debug
perspective the way you want it and then save it under the same name.
Hope this helps,
Eric
Re: Replacing the debug perspective with my own [message #336398 is a reply to message #336387] Wed, 10 June 2009 04:01 Go to previous messageGo to next message
Hi Eric,
Thanks for the tip, but that doesn't help. See comments below:
Eric Rizzo wrote:
> Derek wrote:
>> work out how to make it the 'default'. I can change it through the UI,
>> but I want to set it programmatically.
Yes, this is what I want.
No, I want to do this programmatically. I want this behavior for the
users of my Eclipse-based product.
> Hope this helps,
> Eric
Derek
Re: Replacing the debug perspective with my own [message #336452 is a reply to message #336398] Fri, 12 June 2009 13:40 Go to previous message
Derek wrote:
> Hi Eric,
> Eric Rizzo wrote:
>> Derek wrote:
>>> Hi,
>>> UI, but I want to set it programmatically.
>> mean that whenever you launch a program in debug mode, it should
>> switch to your custom perspective?
I would take a look at the code of that preferences page to see what it
does behind the scenes. Use Plug-in Spy to find the class that
implements the preferences page.
http://www.eclipse.org/pde/incubator/spy/
Hope this helps,
Eric
Previous Topic:Resource tree locked?
Next Topic:[Update Site] Creating required dependencies
Current Time: Thu Nov 06 11:44:35 EST 2025
Powered by FUDForum. Page generated in 0.02957 seconds
