Home » Eclipse Projects » Eclipse Platform » java template, insert superclass name
java template, insert superclass name [message #336289] Fri, 05 June 2009 06:53 Go to next message
Hi there
first of all I don't know if this is the correct place to talk about
eclipse-java help
Anyways, I'd like to know the simplest way (if it's possible) to insert
the superclass name as a variable (depending on the class extended) when
creating a template for java. Which context should it be within java o
java statement?
I'm using Version: 3.4.2
thanks
Re: java template, insert superclass name [message #336303 is a reply to message #336289] Fri, 05 June 2009 10:50 Go to previous message
miguel wrote:
> Hi there
> eclipse-java help
eclipse.tools.jdt is better suited for that.
> insert the superclass name as a variable (depending on the class
> extended) when creating a template for java. Which context should it
> be within java o java statement?
Java statement.
Dani
> thanks
Previous Topic:[CommonNavigator] hideLinkWithEditorAction
Next Topic:CollapseAll Action(Ctrl+Shift+Numpad_Divide) is specific to java editor
Current Time: Fri Jul 18 05:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.05500 seconds
