Post Eclipse 3.4.2 migration, project folders now labeled 'JS' [message #336284] |
Thu, 04 June 2009 21:48  |
I have a question on an odd behavior that is occurring when importing my
project post Eclipse 3.4.2 upgrade.
In the project, that I previously created, contains some subfolders and
files. After I had upgraded my Eclipse, I imported this project into my
brand new workspace and discovered the following symptoms in the project:
1) Some sub-folders now display the letters 'JS' in the Project Explorer
view.
2) Moving files from folder to folder does not refresh even though the
workspace preference 'Refresh automatically' is enabled. A manual F5 key
refresh is needed.
3) In some subfolders, the files are not displayed in the Project Explorer
view even after refresh.
4) Restarting Eclipse then resolves this issue.
In the Project Explorer view, the 'JS' folders are now normal unlabeled
folders, moving files from folder to folder refreshes fine, and all files
are displayed. The entire project reacts as it should.
Note: Manually refreshing the project or right clicking 'Close Project'
and reopening did not seem to resolve the issue.
This symptom just started happening during this version migration.
Does anybody know what may be causing this to happen?
Any help is appreciated!
Brian Yu
Re: Post Eclipse 3.4.2 migration, project folders now labeled 'JS' [message #336296 is a reply to message #336284] |
Fri, 05 June 2009 10:38   |
Brian Yu wrote:
> view.
> refresh is needed.
> Explorer view even after refresh. 4) Restarting Eclipse then resolves
> this issue. In the Project Explorer view, the 'JS' folders are now
> normal unlabeled folders, moving files from folder to folder refreshes
> fine, and all files are displayed. The entire project reacts as it should.
> and reopening did not seem to resolve the issue. This symptom just
My guess is that those folders are marked as JavaScript Source
folders (or are under one), and that's why you're seeing the JS icon
instead of the usual icon. Much like the Java provider assumes the
responsibility for showing the contents of its Source folders, the
JavaScript one does the same. There do appear to be some issues
with its responsiveness in that release. Can you try applying any
updates you find--my hope is that you'll see some improvement with
the 3.0.5 WTP update.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
FUDForum. Page generated in 0.06235 seconds
