Home » Newcomers » Newcomers » CVS hanging
CVS hanging [message #34136] Mon, 14 March 2005 16:15 Go to next message
Originally posted by: lc278.cornell.edu
I'm trying to connect to a CVS repository via SSH2.
I can view the modules in the repository. When I try to update or synchronize
however Eclipse blasts through and then hangs at 42% on one particular file.
I've checked the repository and there is nothing odd about the one file in
question.
The server requires SSH2. I'm using extssh.
Anyone have any suggestions on how I can fix or work around this?
Thanks.
Re: CVS hanging [message #34242 is a reply to message #34136] Mon, 14 March 2005 17:02 Go to previous message
Originally posted by: muhammad.dwyer.gmail.com
First try updating your files using a different client, to see whether the
problem is in the client or the server. For example, you can use a CVS client
like SmartCVS (http://www.smartcvs.com/)
Previous Topic:How to change compiler-compatibility to 1.5? / How to use tiger syntax?
Next Topic:How to get files from IWorkspace
Current Time: Sun Nov 16 00:02:52 EST 2025
Powered by FUDForum. Page generated in 0.10233 seconds
