| ShowViewMenu and activities [message #336239] |
Tue, 02 June 2009 15:41  |
I have a question about the behaviour of the Show View Menu in conjunction
with
activities, a.k.a. capabilities. I have a plugin (say pluginB) which
contributes a viewShortcut and a perspectiveShortcut to a custom
perspective,
which exists in pluginA:
<extension point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension targetID="pluginA.myPerspective">
<viewShortcut id="pluginB.myView">
</viewShortcut>
</perspectiveExtension>
<perspectiveShortcut id="pluginB.myOtherPerspective">
</perspectiveShortcut>
</extension>
I also have a extension for org.eclipse.ui.activities. pluginA is mapped
to one
activity, and pluginB and mapped to another activity. E.g.
<extension point="org.eclipse.ui.activities">
<activity id="activityA" name="Activity A">
</activity>
<activity id="activityB" name="Activity B">
</activity>
<activityPatternBinding activityId="activityA" pattern="pluginA/.*">
</activityPatternBinding>
<activityPatternBinding activityId="activityB" pattern="pluginB/.*">
</extension>
If I have pluginA.myPerspective open, I see pluginB.myOtherPerspective in
the
Open Perspective menu, and pluginB.myView in the Show View menu, as
expected.
When I go to disable activityB in the Capabilities preference page,
pluginB.myOtherPerspective disappears from the Open Perspective menu
(good), but
pluginB.myView remains in the Show View menu (bad).
I was able to trace the issue to the internal class
org.eclipse.ui.internal.ShowViewMenu. In particular, it executes the
following
when it populates the menu:
for (Iterator i = actions.iterator(); i.hasNext();) {
CommandContributionItem item =
new CommandContributionItem(
(CommandContributionItemParameter) i.next());
if (WorkbenchActivityHelper.filterItem(item)) {
item.dispose();
continue;
innerMgr.add(item);
This is the right idea, but WorkbenchActivityHelper has the following
filterItem
implementation:
public static final boolean filterItem(Object object) {
if (object instanceof IPluginContribution) {
...snip...
return false;
Trouble is, CommandContributionItem is not derived from
IPluginContribution.
Therefore, the items are never filtered out.
Am I reading this right? Are there any workarounds for this issue? Any
help
would be appreciated.
Albert Choi
FUDForum. Page generated in 0.03513 seconds
